03-08-2016, 01:21 PM | #1 |
Project "Hulk Jr"
Hello guys. As some of you know I am building a truck "Project 68 k10 LWB..aka "The Hulk" " which will now be a '70 K20 with a 67/68 front end and 1/2 ton running rear.
This is a new thread on the original Hulk truck.... So the story starts like this. My son wanted a 4X4 and I told him i would not buy him one but if he could find someone to trade the 4 wheeler for it I would do it. So what does he find..... a 68 K10 LWB 8 hours away so after a little coordination we traded the guy a 4 wheeler (Articat 500) that we never used for the dark green 68 K10 for my youngest son. He called it "the Hulk" which was the reason for the project name. History on the truck: I got is from the second owner and he got it from the original owner the original owner own a gravel pit at the California/Oregon border. As I started doing homework on what was needed to rebuild the truck I figured that I did not want to tear a good truck apart to only use a few pieces for the build and get stuck with random parts. Not in a hurry I was able to locate all the parts to build a complete truck. This thread will be on the original Hulk truck Now Named "Hulk Jr" Its has the original 307 engine, a SM465 and Rockwell T-221. no power steering, no power brakes, 4 wheel drums. base model... The plans are to update the running gear, braking system, add power steering and replace the front axle to get front disk brakes. The nice thing is I have most of the big parts laying around from other projects spare parts. engine, axle, brake booster, steering box, etc. the plan is to keep stock stance I am looking for a 700R4 and a 208/241 t-case. I will try and post updates to this thread and not join the 2 threads. Wish me luck!!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-08-2016, 01:23 PM | #2 |
Re: Project "Hulk Jr"
a few more pictures
03-08-2016, 02:05 PM | #3 |
a few more pictures
03-08-2016, 03:36 PM | #4 |
This is the motor I am going to rebuild for the 68. It can from the c10 I put the Ls in.
03-08-2016, 03:39 PM | #5 |
This is the cluster I am going to use in the truck. Factory tach dash with a vacuum gauge. Just need to replace the bezel.
03-08-2016, 10:23 PM | #6 |
I like this truck! plus it looks like its in great shape, super platform for a build.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-09-2016, 12:57 AM | #7 |
Thanks rat. I am not going to go crazy with this one more of a driver with updated parts. I got a call the sbc 350 is ready to to be picked up. I am going to try and get it this week.
Now I just need the trans and t-case
03-09-2016, 11:06 AM | #8 |
Sweet truck great find I'm in!
Brett 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
03-09-2016, 11:55 AM | #9 |
Hey Brett, this is the truck that started the other thread just went a different route, but decided to just rebuild this and make it a reliable hunting vehicle. I found a few more photos of it when the guy I bought if from worked on it... I will post them soon.
03-09-2016, 11:57 AM | #10 |
Here are a few of what the PO did before I got it.
03-09-2016, 11:58 AM | #11 |
last 2 I have from the PO
03-10-2016, 12:38 AM | #12 |
This is of the '90 10 bolt front axle I rebuilt. Nothing fancy.
03-12-2016, 08:57 PM | #13 |
Look what I picked up.... Also picked up the np208 and 700r4 from a local wrecking yard. I got the transfer case ,trans, crossmember, shifter linkage for both. Front swaybar with brackets. And 4x4 shifter. Plus a few others odds and end. 400$
Thought that wasnt bad. Now I have to rebuild the tc and have a trans shop rebuild the trans.
03-12-2016, 11:01 PM | #14 |
Progress!!
03-13-2016, 12:04 PM | #15 |
I'm guessing your boy is way excited!
03-16-2016, 12:44 PM | #16 |
He is but I think its more about getting his license...
Should I paint the motor Chevy orange or keep it black?
03-16-2016, 05:35 PM | #17 |
1 vote for black!
03-16-2016, 06:15 PM | #18 |
GM BB red orange
03-16-2016, 11:19 PM | #19 |
Toss up, I like the black with black Edelbrock manifold and black carb, but i'm a chevy orange kinda guy.
03-16-2016, 11:35 PM | #20 |
Thanks guys. I asked a friend of mine why machine shops paint most engines black. He said "it hides oil leaks". I laughed, he looked at me said "I am not kidding..." So sounds like I am going to tape it off and paint it Chevy orange.....
03-16-2016, 11:52 PM | #21 |
So the New/old intake manifold I had was a spread bore and I think I am going to go with the Fitech injection system. I had to order a spread bore to square bore adapter. I spent 100$ this afternoon from Jeggs and rockauto for little things. Gaskets, fuel pressure regulator, thermostat, oil pan bolts, trans mounts etc. still need a thermostat housing. Plus I am sure I will need a bunch of other stuff....
03-17-2016, 08:56 AM | #22 |
Good choice most of my builds have been chevy orange also, I've been pondering the same question myself lately. I think your engine guy is right about hiding the oil leaks (easier maintenance) its also believed that black will dissipate heat quicker.
03-17-2016, 12:37 PM | #23 |
Here some pictures I took of the tear down of the Transfer case. Its a NP208C out of a 1986 3/4 ton Suburban with a diesel.
03-17-2016, 12:40 PM | #24 |
I did check the chain and had to order one. Inside the transfer case smelt like it got hot. Than is why I wanted to completely rebuild it. I hope after I clean it up I don't have to replace any major components
03-20-2016, 12:42 AM | #25 |
Of course i think Chevy orange is a great choice! Trust in your ability to not build a leaker!
