Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 03-17-2016, 05:07 PM   #1
Frugalmeyer
Parting - 1972 4WD Blazer
Pulling the suspension in "Mid June". I will pull the drivetrain earlier if a can have most of it sold.
I am posting this thread in advance because once I pull the Blazer in the garage to begin the conversion I do not have much room to store the parts I pull and need them gone. I am going to be replacing the 4WD suspension and drivetrain with 2WD, 5 Lug, LS powered and vintage air.
I will be selling all the 4WD suspension, drivetrain, wheels and tires and A/C system.
Frugalmeyer is offline   Reply With Quote
Old 03-17-2016, 05:08 PM   #2
Frugalmeyer
Re: Parting - 1972 4WD Blazer
I will be keeping the A/C control and dash vents.
Old 03-17-2016, 06:37 PM   #3
1972 Jimmy
1972 Jimmy's Avatar
Interest in the evaporator mounted in front of the radiator. What shape is it in??? Any broken fins??
1972 Jimmy is offline   Reply With Quote
Old 03-17-2016, 07:04 PM   #4
Brave71
I need vac canister, inside and outside vac actuators, all brackets for actuators, also flapper in cowl.there is a couple of rods that hook to actuators l need.how much to 89015..thanks
Brave71 is offline   Reply With Quote
Old 03-17-2016, 07:21 PM   #5
Arrington01
Arrington01's Avatar
What gear ratio are the axles?
Arrington01 is offline   Reply With Quote
Old 03-17-2016, 09:00 PM   #6
Frugalmeyer
Looks like RAZ axle code but not sure. Photos attached.
Old 03-17-2016, 09:25 PM   #7
Arrington01
How much
Old 03-17-2016, 10:55 PM   #8
bluek5
bluek5's Avatar
Does it have a skid plate and cross member for the transfer case? Also how about the gear reducer for the speedometer cable. Would need them shipped to 84043.
Thanks, Paul
bluek5 is offline   Reply With Quote
Old 03-18-2016, 12:05 AM   #9
Frugalmeyer
Transfer cross member and skid plate.
Old 03-18-2016, 01:52 AM   #10
RedRoad
RedRoad's Avatar
Interested in the cowl vent flap assembly. Stick or auto? Looking for single bend shifter if stick.
RedRoad is offline   Reply With Quote
Old 03-18-2016, 05:23 AM   #11
tristan
Possibly interested in all of the AC components mounted to the inside and outside of the firewall plus the compressor, brackets hoses, and other bric-a-brac that you aren't keeping. I don't need the condenser, controls, diverter box or dashboard stuff.
tristan is offline   Reply With Quote
Old 03-18-2016, 05:40 AM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'd be interested in the following pending condition pics and cost w shipping to 87107:
Radiator
Fan shroud
Fuel tank skid plate w attach bolts
Linkage from shift lever to tcase and or tcase shifter bolt
Hei distributor
Engine oil dip stick
Metal hose strap affixed to inner RH fender w screws
Old 03-18-2016, 11:58 AM   #13
hold24
I would be interested in a bed mat if its a clean one or even has it
thanks
hold24 is offline   Reply With Quote
Old 03-18-2016, 08:45 PM   #14
1972 Jimmy
1972 Jimmy's Avatar
Is the 4x4 shifter Chrome if so what condition and price?
Old 03-18-2016, 09:18 PM   #15
Frugalmeyer
No Bed mat.
Old 03-19-2016, 03:42 PM   #16
1970
1970's Avatar
Interested in
front leaf spring hanger brackets
bump stop brackets
upper shock brackets
rear spring front brackets
radiator core brackets
1970 is offline   Reply With Quote
Old 03-19-2016, 04:52 PM   #17
72chevynut
72chevynut's Avatar
Please put me in line for the AC vacuum ball tank and bracket. Shipping would be to 40353. Thanks
Michael
72chevynut is offline   Reply With Quote
Old 03-20-2016, 05:18 PM   #18
leddzepp
Moderator
leddzepp's Avatar
Please list prices per forum rules ASAP. Thank you!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-20-2016, 09:20 PM   #19
Frugalmeyer
I am new to this board and will read the rules and try this again. Sorry for any inconvenience.
Old 03-21-2016, 02:00 AM   #20
walkintall54
interested in drive shaft.
walkintall54 is offline   Reply With Quote
Old 03-21-2016, 10:56 AM   #21
extd56
extd56's Avatar
are you selling the hatch
extd56 is offline   Reply With Quote
Old 03-21-2016, 08:26 PM   #22
tristan
I'm giving up first dibs on the AC equipment to any of you guys who may have an immediate need. If no one needs them then I may be baaaack....
Old 03-21-2016, 08:50 PM   #23
Frugalmeyer
Radiator 85.00 plus shipping. No leaks.
Fan Shroud 55.00 plus shipping. One hole drilled in center top.
DeadheadNM has first dibs.
Old 03-21-2016, 09:08 PM   #24
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thank you - I'll take the radiator pending ship cost to 87107 if it's a 4-row Harrison for auto tranny K5. I'll pass on the shroud but would be interested in the clips that mount the lower shroud to the rad support if present and curious about remaining items on the list. Best, Pete
Old 03-21-2016, 10:31 PM   #25
Frugalmeyer
DeadheadNM
Looks like a 3 row factory radiator. Clips will go with the fan shroud.
