Old 03-26-2016, 06:23 PM   #1
yoshi
yoshi's Avatar
AD hood alignment
On my 49 I have this gap in front of the cowl, should the gap be smaller? If so how do I adjust it? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 03-26-2016, 06:24 PM   #2
yoshi
yoshi's Avatar
Re: AD hood alignment
Another pic
yoshi's 49 project
Old 03-26-2016, 06:39 PM   #3
mphudak
This should help you out.
http://www.stovebolt.com/techtips/bo...alignment.html
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 03-27-2016, 05:54 AM   #4
yoshi
yoshi's Avatar
Found this http://youtu.be/Ye5MY06ZN-4
yoshi's 49 project
Old 03-27-2016, 01:00 PM   #5
MARTINSR
MARTINSR's Avatar
The big thing is how does it fit at the front? Panel fit is all about the WHOLE thing, not just one or another. If you move the hood back to fix that cap the front gap at the fender right above the grille is going to tighten up, big time. The gaps along the fenders are going to widen, big time. So it's about all of them, not just that hood to cowl. If you tighten that gap up you may need to bring the fenders back too. They may also need to be widen them at the front, it may be way more we are talking about than that hood to cowl you have pictured.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-29-2016, 09:19 AM   #6
Iceburgh
Iceburgh's Avatar
tough to tell with the pic but some of that could be caused by the hood springs.
They are easy enough to unbolt and see if it is better. If so you might want to think about a hood prop.
But to get that back you will have to start out front and get the fenders and grill to move back with the hood.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 03-29-2016, 10:32 AM   #7
MARTINSR
MARTINSR's Avatar
The hood is forward not up, it has nothing to do with the springs.
Brian
1948 Chevy pickup
Old 03-29-2016, 12:10 PM   #8
yoshi
yoshi's Avatar
Front passenger side
yoshi's 49 project
Old 03-29-2016, 12:11 PM   #9
yoshi
yoshi's Avatar
Rear passenger side
yoshi's 49 project
Old 03-29-2016, 12:12 PM   #10
yoshi
yoshi's Avatar
Front drivers side
yoshi's 49 project
Old 03-29-2016, 12:13 PM   #11
yoshi
yoshi's Avatar
Rear drivers side
yoshi's 49 project
Old 03-29-2016, 12:14 PM   #12
yoshi
yoshi's Avatar
Front
yoshi's 49 project
Old 03-29-2016, 01:03 PM   #13
MARTINSR
MARTINSR's Avatar
You have way more than just "hood alignment" you have the whole front end you will need to work with.
To start with, your rad support is over to the right, a lot! That's "right" as you sit in the truck looking forward, "right" is "Passenger" side.
Moving the rad support to the left may fix most of the problem but it may also need to go down, or the cab up. The whole fender rad support also looks like it needs to go back.
Brian
1948 Chevy pickup
Old 03-29-2016, 02:10 PM   #14
yoshi
yoshi's Avatar
How do I go about adjusting rad support?
yoshi's 49 project
Old 03-29-2016, 02:41 PM   #15
MARTINSR
MARTINSR's Avatar
On a stock truck it would be the two bolts at the bottom of the support to the frame. But I will put money on it you have a sub frame under it or something like that. So I can't explain without some photos of where it mounts. But basically you need to loosen up the rad support and move it. This often would also take loosing up fender to cab bolts and fender to rad support bolts.
Brian
1948 Chevy pickup
Old 03-29-2016, 03:00 PM   #16
yoshi
yoshi's Avatar
Yes I know the 2 bolts that you are referring to, I have an original Mll setup
yoshi's 49 project
Old 03-29-2016, 03:45 PM   #17
MARTINSR
MARTINSR's Avatar
AWESOME! Ok, the bumper may need to be moved too. But those bolts will allow you to move the rad support sideways. But it also may need to go back too. Which would require loosening all the fender to cab bolts. Realistically you need to get the hood where it goes (back) and then move the rad support and fenders until they fit it.
That is what you do before paint, now, you are going to want to do a little dance with all the parts. Move the rad support over, move the hood a little better, see where you are, move it a little more, check the hood, and on and on. This is going to be a little project.
Brian
1948 Chevy pickup
Old 03-29-2016, 04:17 PM   #18
yoshi
yoshi's Avatar
"Move the hood a little better" is that by using the method with the wood block in the video above?
yoshi's 49 project
Old 03-29-2016, 05:00 PM   #19
MARTINSR
MARTINSR's Avatar
I'll have to watch that video when I have sound as I don't right now. I don't understand it at this point how is he tightening the bolts when it moves?
Don't try to explain, I'll just watch it later.
I do know one thing, I don't know how in the living hell you end up with a stunningly painted cab (dig that firewall!) while having the front fenders and hood unpainted? HUH????
But I will watch it tonight and get a better idea.
Brian
1948 Chevy pickup
Old 03-29-2016, 05:08 PM   #20
yoshi
yoshi's Avatar
Brian I bought the truck like this, everything was painted but not fitted or even trial fitted
yoshi's 49 project
Old 03-29-2016, 05:10 PM   #21
yoshi
yoshi's Avatar
But I'm getting there
yoshi's 49 project
Old 03-29-2016, 07:08 PM   #22
MARTINSR
MARTINSR's Avatar
Not trial fit! YEOW, you are doing miracle work! After finishing that up you will be the master.
Brian
1948 Chevy pickup
Old 03-29-2016, 08:54 PM   #23
Iceburgh
Iceburgh's Avatar
Brian
Well good luck
1953 suburban build
Old 03-30-2016, 12:45 PM   #24
yoshi
yoshi's Avatar
This is my friends truck, looks like he may have a similar problem
yoshi's 49 project
Old 03-30-2016, 01:35 PM   #25
MARTINSR
MARTINSR's Avatar
That one photo tells us as close to nothing as you can get. It looks more like something is holding up that side of the hood at the grille like too long of a rubber bumper or something, that is ALL it tells us.
Brian
1948 Chevy pickup
