Old 04-12-2016, 11:24 AM   #1
1000rrstunna
Choosing a power steering gearbox.. to go high end or not?
I am looking for a new gearbox for my 69... the frame seems to be clearanced for the power steering unit... I was looking at a redhead or the AGR performance boxes but they are about 450$... how are people getting along with the A1 cardone rebuilds ? I am not about cutting corners nor am i about throwing an extra 350$ out the window on a power steering box.... I am using a gm type 2 pump with the Billet Specialties Tru-trac serpentine kit that I have it flows 3 Gallons per minute at 1200 psi... this should be more than enough to power the stock steering gear correct? any advice and experiences appreciated.
thanks
1000rrstunna is offline   Reply With Quote
Old 04-12-2016, 12:02 PM   #2
Lou Boffa
Lou Boffa's Avatar
Re: Choosing a power steering gearbox.. to go high end or not?
I installed an AGR variable ratio box and pump about a year ago. Best upgrade I've made in terms of driving enjoyment. Good road feel. Solid steering.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 04-12-2016, 12:04 PM   #3
1972BlueC20
1972BlueC20's Avatar
I just ordered a CPP 14:1 quick ratio 500 series box. $380
I'll let you know how I like it, installing this coming Sunday probably.
I'll be going from manual to power steering....no matter what I put on there it will be a big difference.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 04-12-2016, 12:19 PM   #4
Kell
Kell's Avatar
My opinion is like most "performance" upgrades, this is way overpriced.
Did a reman IROC box on my 70 firebird a couple of years ago, DIRT CHEAP and performance was great. Quick ratio with more steering resistance. Any "modern" steering box is going to feel better than the old ones.
1970 C10 Longbed, 250 Inline 6, 3 OTT
Kell is offline   Reply With Quote
Old 04-12-2016, 12:27 PM   #5
65 C20
I have a 65 and went with the Cardone rebuilt.
No problems.
I am not sure about the 69 but you may have to weld on an additional 1/4" spacers to the frame where the bolt holes are for clearance on the P/S box, just like thick washers.
Maybe someone with that year can chime in and clear that up.
Looks like 1972BlueC20 is doing it this weekend so he should know.
I am with you on not spending extra money if not needed.
P/S is the best thing I have done to the truck.
Makes those parking lots much easier to navigate.
65 C20 is offline   Reply With Quote
Old 04-12-2016, 12:30 PM   #6
1972BlueC20
No problems.
I'm not sure but it's either 67 or 69 needs to have the bumper bracket notched out a little for clearance when switching to PS from manual steering.
My 72 should bolt right up with no issues I've been told. We shall see this weekend, I will report back.
Old 04-12-2016, 12:33 PM   #7
1000rrstunna
thanks for all the great replies! i'm looking forward to the experience with the cpp unit. as far as i know the 69 and up don't need any mods to the frame inorder to get the unit to fit...
Old 04-12-2016, 12:34 PM   #8
1972BlueC20
this is the one I ordered. Heard good things.
http://www.summitracing.com/parts/clp-cp50014
Old 04-12-2016, 01:20 PM   #9
65 C20
If you look at the discription for the above box it states that it has cast in bosses that eliminate the need for external brackets and shims.
I believe that for A1 Cordone you would need the shims.
Old 04-12-2016, 01:20 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
It's actually 68 and up, but even some early 68's had the "flat" frame area under the box.
It's been a long time since I drove one of these with PS, but from what I remember with the stock box you could turn the wheel with one finger. The advantage you get with the quicker ratio boxes is that the wheels turn faster with less turns of the steering wheel, I don't believe there is any change to the "effort" other than turning the wheel more times.
I've had a stock 1972 complete set up sitting in the corner of the garage for the past 6+ years... waiting on me to dimple the frame...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-12-2016, 01:28 PM   #11
hdff
hdff's Avatar
i replaced my old box with a Red Head, have been happy with it so far. They did not recommend the quick ratio so I went with stock ratio. It's good to me!!
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 04-12-2016, 02:18 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I used Cardone from a local autozone. Works great, no leaks for years now. It was around $120 with exchange iirc.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-12-2016, 02:27 PM   #13
CastIron
CastIron's Avatar
I got one off of a mid 70's C10 and it bolted right up to my 69 GMC. I went from manual steering to power. I don't see any big advantage to getting a "high performance" steering gear for normal street driving. In my opinion, the best way to assure good performance is to make sure to keep the truck well maintained. In other words, replace any worn parts before you upgrade to performance parts.
CastIron is offline   Reply With Quote
Old 04-12-2016, 02:34 PM   #14
1972BlueC20
did someone tell you NOT to get the quick ratio?
I may have heard wrong, but I was told that a quicker ratio unit is more like a later model 80's box and that it will have more road feel. I heard the original boxes on these trucks where weird feeling and lacked road feedback.
I may be completely wrong.
Well, either way...I've already ordered the box and if I don't like it I will send it back and get an A1 Cardone from Autozone or the like. They are def cheaper but I don't mind spending money on good parts...Im already so upside down on this truck I can never sell it even if I wanted....couldn't stand to take that kinda loss!
Old 04-12-2016, 03:41 PM   #15
1000rrstunna
some great information in here! I will wait for your results 72' im in no hurry frame is still at the sandblaster!
Old 04-12-2016, 05:12 PM   #16
joeydurango
joeydurango's Avatar
Redhead all the way. I went stock ratio on the shortbed, trying out the quick ratio on the longbed - haven't rolled it out of the garage yet but I'm expecting it to drive great!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 04-12-2016, 05:27 PM   #17
davepl
davepl's Avatar
All I know for sure is I have the original box and it's about 50 turns lock to lock. If you have power steering and the option for a faster ratio, I'd recommend it.
In my Camaro I have a Saginaw 500 series box (200s Tahoe, basically) and its got a nice feel, good on-center, generally "newer" feeling than the old box.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-12-2016, 07:30 PM   #18
BigMike
BigMike's Avatar
^^^LOL! Mine is the same thing. Feels more like I'm steering a school bus. I will eventually get the AGR quick ratio setup. Mine is actually 4 turns lock to lock & I hate it. The AGR one is a more modern ratio from what they told me (been a while). My son's 72 Nova is 2.5 lock to lock and handles amazing from a steering aspect.
Initially I was going to go with a CPP 500 series...until I read the reviews online, no thank you.
BigMike is offline   Reply With Quote
Old 04-12-2016, 08:32 PM   #19
67 chevelle
67 chevelle's Avatar
I put a 78 box in my 68 , its faster , less turns , and has different valving , to stiffen the steering in the centered position , payed around 100 bucks for it , works excellent
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-12-2016, 11:37 PM   #20
1972BlueC20
what is the problem with the CPP 500 box? I can't seem to find any bad reviews after doing a few google searches.
Just wondering since I am expecting this box to arrive Friday and it wasn't cheap.
Old 04-13-2016, 12:51 AM   #21
67ChevyRedneck
Sounds good, that's what I remember, is that the wheel too easily moves side to side.
So why the 78? I looked up the p/n and they're a 77-79 truck part. Just a good mix of ratio, etc. that fits without modifications? Do the stock 68-72 hoses work/fit?
Jesse James
Project "On a Dime"
Old 04-13-2016, 02:26 AM   #22
BigMike
BigMike's Avatar
I googled it over a year or so ago. Many were complaining about leaking issues months after install, some were excess play and others were the box was way too tight feeling. Most of the issues IIRC were with Tri-fives, Novas and Camaros Series 500. When I did my research it was enough to sway me from getting one. And I am a big CPP fan with a lot of their parts on my truck. It seems like a relatively low number that have issues so you possibly won't have any problems. If I get time I'll see what I can find on them again.
Old 04-13-2016, 03:48 AM   #23
68ls1
68ls1's Avatar
I like my AGR, good improvement over the stock box
68ls1 is offline   Reply With Quote
Old 04-13-2016, 07:44 AM   #24
67 chevelle
The 78 box has worked flawlessly for me , direct replacement from what I can recall , I had a cpp 500 box in a chevelle it was "ok" , very stiff at first , got better with time
Old 04-13-2016, 08:23 AM   #25
dirish
dirish's Avatar
I put a redhead quick ratio box, from a vendor on this site.
Best investment so far! My Blazer is now fun to drive, before
It was sketchy at best.
dirish is offline   Reply With Quote
