It followed me home?
wheel selection sux!!
I am trying to find some rims for the k5 and nobody makes wheels for a locking hub. Anyone have some ideas? I am trying to stay away from this style
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I wanted to put 1 of these style wheels on the Jimmy when i had it. Their all American Racing wheels.
67-72 parts collector,…
![]() Join Date: Nov 2002
Centerline?
Have you looked at Centerlines new wheels? I would find the wheel I liked and mill the center cap for the lock- outs.
#4 | |
Re: wheel selection sux!!
Chuck '85 Chevy Silverado 4X4 ![]() '91 Chevy 4X4 Suburban ![]() http://www.cardomain.com/memberpage/545941 |
Happy to be here
![]() Join Date: Mar 2000
#6 | |
See the problem he has a lot of the current trucks have a cenetral lock so the hug is small like a 2wd. 8 Lug selection just sucks to begin with if you looking for a real HD wheel. D and E rated tires are narrow. The stock factory rim is 6.5 inches. I am about to give up and go with either the MT style like at the top or go with a OutlawII. I can get both of them in the weight rating I need. I can also get matching rims for the Airstream the truck pulls.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#7 | |
Re: Re: wheel selection sux!!
#8 | |
Re: Re: Re: wheel selection sux!!
BE CAREFULL on theoffsett. The 88 up trucks are mor of a fwd offset. You want something 4 inches or less back space. \ The other problem is these trucks are hub centric from the factory. The newer trucks are as well BUT their hub diameter is smaller. If you can it would be best to machine it so be hubcentric again. I didn't drive my truck today so I'm worthlesss on a measurement.
#9 | |
Re: Re: Re: Re: wheel selection sux!!
Lug centric = lug nuts center the wheel.
Hub centeric= hub centers the wheel. What width rim are ou going with? You going to wheel it? What size tire? I'm running a 15x10 rim with a 35x12.5 tire. The tread is just under the fenders on the front but the sidewalls buldge out. The rear tracks 3 inch's less so the side walls are not as far out. Not sure if this will let you direct link. This has a shot down the sied that you can et an idea of how the tires is to the body. http://www.coloradok5.com/stcreview/stc9.jpg If not it's in here. http://www.coloradok5.com/stcreview.shtml Here is a side shot. Only one I have on my work computer. Mrs Reaper driving. ![]()
Ohh and that's a 4 inch back set wheel. JUST clears the tre's on the tie rod.
I will be running a 33*12.5 on 15*10 wheels. Not much offroad just some light trails if that, its just a DD. Thanks for the help
4 inch is what you want then for a 10 inch. It will keep the airborn crud down and it should keep you from getting hassled by the man.
If you were running more trails then go with a 8 inch. Helps keep the bead from poping at lower pressure if your crawling. We need to hook you up with Steve and TJ. They go wheeling every once in a while. Here is a nice shot of steve on a sunday drive.
#14 | |
#15 | |
#16 |
Mudslides 'r my specialty
cochino,
Summit has $20 in Summit Bucks for each Weld Stonecrusher wheel you buy. (says so in the front cover of the March-April Edition) Just a thought.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
#17 | |
wheel link
#18 | |
Re: Re: Re: Re: Re: wheel selection sux!!
#19 | |
E.H.F.D Engine #2
grrrrr.... ![]()
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
#20 |
Well I made a decision on what to get for the 3/4 burb last night.
We tow with it and it has a set off good Michelin's E rated hwy tires on it with a easy 20k left on them. they are a 235 85 16. Big time limited us in wheel selection. Have to go with a 16x7 max. Not much in that range with a 3k or better weight rating. It was down too the outlaw II (055) or the 589 knock off's in the first post. going with the 589's. Also decided on the rims we are going with on the camper. they sort of look like OutlawII without the rivets. Nobody makes a OutlawII style with over a 1900lb rating and that would be at max weigh if we did that. www.Rjays.com has a set of aluminum mods with a 2540 weight rating for $92 each shipped. http://www.rjays.com/Wheels/hi-spec-wheels-01.htm
#21 |
post some pics once you get them. I think I have given up, I am going to have to go with the same damn wheels everyone else has. I cant find the width and the offset in any wheel under $350. I can get a full set of 4 eagle wheels shown above shipped to my house for under $375.
#22 | |
#23 | |
they are also on ebay for $380 buy it now
#24 |
Thanks! I'm all over that.
#25 |
check the ebay auctions first!!! I just saw a set they sold for $340 shipped.
