Does this look like a stock 402
pic
Re: Does this look like a stock 402
aftermarket intake, carb and air cleaner-what else is modified??
I have no idea. It's sitting in a 70 SWB GMC.
The bed doesn't match the rest of the truck
pics
![]() Join Date: Oct 2009
It doesn't have the funky angular truck alternator bracket - looks like a passenger car bracket. Could've been changed out - but that's the first thing that jumps out at me when it's missing.
Is that long looped rubber line the fuel line?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
![]() Join Date: Mar 2003
Looks exactly like my 396. Only now the 396 is a punched out 454. Pull some numbers off the block
![]() Join Date: Feb 2009
If by 402 you mean all inclusive then no (e.g., air cleaner, fuel line, manifold). A lot of original parts though. I thought the 70 valve covers had a twist on oil cap. They switched to push-on at some point, 70 or 71 I suppose.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-19-2016 at 01:12 AM. |
#10 | |
Roadtrip!
![]() Join Date: Feb 2003
The truck looks decent so I would expect a short bed conversion with the other box on it. And the a/c brackets are mia also.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
has the lazymans rubber fuel lines good for fires
