Automatic shift linkage
Why can you not find automatic shift linkage anywhere? I have a 1979 with a turbo 350. I went to the junk yard today and got a couple. But I need the bushing that goes in the frame. Any idea where I can get one?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
![]() Join Date: Jul 2014
Re: Automatic shift linkage
I just got mine from the junkyard with the spring both still in good condition. None of the trucks in the yard had the bushing?
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
I got the spring and the bushing. But the bushing is shot.
Look here and look up part#91-431 and #91-432 http://www.classicparts.com/searchprods.asp
I have all of the linkage parts including new bushings. You can pm me if you are interested.
#6 | |
Thanks Chris
Thanks Ray, I got everything at the junk yard yesterday and the bushing shown above will be ordered soon
Would all the linkage from the column to the trans be the same for a 700r ? Someone put a floor shifter in mine and took the column shifter and linkage out. I haven't had a chance to go to the junkyard
Yes. 700R4 and TH350/400 are the same.
Does anyone happen to have a view of the rod that connects between the frame and transmission shift lever? I need to see what all is on the rod that connects to the frame. I know there is a bushing and a spring but is there washers, clip, etc? Stupid me forgot to take pictures or label the parts when I took them off.
