Old 06-25-2016, 06:58 PM   #1
71GeneralMotorsCorp
Fan switch problems, Please help!!
Hey guys, got a quick question.. I've got a 69 Chevy c10.. Factory A/C truck. (It works too!) Since i've owned the truck, the high speed on the fan has never worked.. Driving it one day, the fan stopped blowing entirely and wouldn't turn on. So, i thought "Simple fix!!" BOY, WAS I WRONG!! I am entirely lost on what to do and what to replace..
Before everything, i checked the fuses! ALL are good and non-blown..
-First, i got a new fan switch from LMC.. plugged it in, and nothing. (NO wiring plug anymore.. P.O. changed to spade connectors..)
-Secondly, Bought a fan motor relay switch and installed it.. nothing.
-next, i decided to see if the fan motor itself was bad, hooked a wire from battery to terminal and it powered on just fine.. ( no noises or vibrations..)
-After that I decided to go back to the plug on the fan switch and test for voltage.. (NO POWER AT ALL ON ANYTHING when switched on..)
Do any of you guys know what in the world could be causing this? it's 103* outside and i'd love my A/C back!! Maybe a wiring diagram of that area would be fantastic..
"Repetition penetrates even the dullest of minds"
71GeneralMotorsCorp is offline   Reply With Quote
Old 06-25-2016, 07:39 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Fan switch problems, Please help!!
The electrical section has all the wiring schematic's. Sounds like your main wire has come off if you have nothing at the switch.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-25-2016, 08:08 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Check this thread http://67-72chevytrucks.com/vboard/s...d.php?t=658012 or search the board for "fan high speed".... there are quite a few threads about this.
Maybe this will help too
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-25-2016, 08:44 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Bad resistor....
LockDoc
Leon
Old 07-17-2016, 12:30 PM   #5
jamesmadconductor
jamesmadconductor's Avatar
I stumbled across this thread after realizing that every other thread just dealt with non-functional high fan speed, but low and medium were fine. I believe that we may have the same problem; high used to be intermittent, and now I have no fan at all. I'm thinking that it's actually the resistor, as LockDoc has suggested. Have you tried this yet? I'm likely going to get into it today, if I can find the resistor. Let me know, thanks.
-James-
James
1949 Chevy 3800 Panel Truck
1971 Chevy C20 Cheyenne BB402
1958 Cadillac Series 62
1958 MG-A
1940 LaSalle Series 52 Coupe
1912 Ford Model T
jamesmadconductor is offline   Reply With Quote
Old 07-17-2016, 01:36 PM   #6
Thundarr
Thundarr's Avatar
My truck had the same exact issue when I bought it. It is definitely the resistor. Once you find it under the dash, its a cheap and easy fix.
Dont forget to do the heater hose shutoff in the engine bay too. It really helps cool the cab down.
Lost of posts on the site about both issues.
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 01-16-2020, 06:42 AM   #7
Simple10
Simple10's Avatar
Unhappy Re: Fan switch problems, Please help!!
What was the verdict? My fan works on high but not medium or low now ..... and if I have it on high, when I stop the truck it won’t start again untill I flick the switch to off position...... it’s doing my head in!!
Simple10 is offline   Reply With Quote
Old 01-16-2020, 11:26 AM   #8
LockDoc
LockDoc's Avatar
If the blower only works on high speed you are probably needing a resistor for the heat blower motor circuit. The reason the blower works on high speed but not low or medium is because the resistor is only used on low and medium speeds. The resistor for the heater is located on or inside the heater box on the inside of the truck, depending on if it is A/C or not. A/C resistor would be item #1 inside the heater box in the first picture below, and non-A/C would be item #4 on the outside of the heater box in the second picture. (from the assembly manual)
Pretty easy to change it. Unplug the connector by prying up on it with a small screw driver working from side to side, and remove the two 1/4" screws. I would recommend using a little dielectric grease on the spade terminals before you plug the connector back in.
LockDoc
Leon
Old 01-16-2020, 02:26 PM   #9
toolboxchev
Part of the problem to look at is the cable adjustment. Watch how hard you move those levers as they are made out of a pot metal.
Look into the Never Pop Kit available in steel levers.
toolboxchev is offline   Reply With Quote
Old 01-16-2020, 07:40 PM   #10
Simple10
Simple10's Avatar
LockDoc
I’ll check it out �� toolbox .. thanks ...mines air con
Any specific resistor I have to order or ask for?
Old 01-24-2020, 06:33 AM   #11
Simple10
Simple10's Avatar
I haven’t taken my old resistor out as yet ... but does it look like https://rover.ebay.com/rover/0/0/0?m...2F192417359832
Old 01-24-2020, 07:09 AM   #12
Andy4639
Old member
Andy4639's Avatar
Should look like this. #5 in the picture.
Old 01-24-2020, 11:30 PM   #13
Simple10
Simple10's Avatar
From previous pictures it appears you go in through the top through the glove box, is that right?
Thanks this appears to be it?
Old 01-25-2020, 12:47 AM   #14
Simple10
Simple10's Avatar
Old 02-04-2020, 07:11 PM   #15
Simple10
Simple10's Avatar
Anyone know the part number ? I can’t find a fan blower resistor on rockauto.com
Old 02-04-2020, 07:59 PM   #16
Andy4639
Old member
Andy4639's Avatar
Angry Re: Fan switch problems, Please help!!
Not rock auto but here it is.
https://www.classicmuscle.com/392905...hoCqIEQAvD_BwE
Here it is on E bay.
https://www.ebay.com/itm/173648437597
Old 02-05-2020, 12:20 AM   #17
Sheepdip
Sheepdip's Avatar
GM #: 3929055
It was a generic switch used in that era on the A/C equipped trucks, Corvettes, Camaros etc
Sheepdip is offline   Reply With Quote
Old 02-05-2020, 01:38 AM   #18
Simple10
Simple10's Avatar
Thanks for the help guys appreciate it, rock suck I emailed them asking for a link because I couldn’t find it in their category they wouldn’t send me one And said we created it so you could search pretty much ....to keep the cost down.
Old 02-20-2020, 07:22 PM   #19
Simple10
Simple10's Avatar
Well the part finally turned up......now off to put it in ...... really can’t see how these fail, it’s just a piece of steal with two springs... be interesting to see the one that comes out.
Old 02-20-2020, 07:44 PM   #20
LockDoc
LockDoc's Avatar
Let us know if that fixes it or not.
LockDoc
Leon
Old 02-20-2020, 10:10 PM   #21
Simple10
Simple10's Avatar
LockDoc
Waste of time did nothing at all
Old 02-20-2020, 10:55 PM   #22
Steeveedee
Who Changed This?
Steeveedee's Avatar
Those are just resistors. I didn't look up-thread. Did you change out the relay?
~Steven
Simi Valley, CA
Old 02-20-2020, 11:39 PM   #23
Simple10
Simple10's Avatar
So over this crap ... put the new Part in didn’t work so i left it in there 20 minutes later the air conditioning doesn’t work at all no more cold
Old 02-20-2020, 11:41 PM   #24
Simple10
Simple10's Avatar
I know what they are everything has been tested fan switch works on high but not medium or low which indicates it is a resistor when it’s not
Old 02-20-2020, 11:51 PM   #25
Simple10
Simple10's Avatar
Oh well got the aircon back on cold ... oops plug fell off
