Old 03-14-2004, 07:56 PM   #1
71Rat
ran out of money
71Rat's Avatar
Exclamation clutch pedel removal?
in a week or 2 i should be ready to put my enigine and trans back into my truck. the thing is i am converting to a 700r4 from my 3 speed sag. i would like to remove my clutch pedel. but i cant figure out how it comes off and the easiest way to remove the spring without breaking something or hurting anyone.
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 03-14-2004, 09:12 PM   #2
krue
Designated A-hole!
krue's Avatar
From what I understand, messing with that spring is a good way to lose a finger or worse. Somebody on here got hurt pretty bad trying to do it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-14-2004, 10:01 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
It would be eaiser to work on the petals out of the truck. To remove them you will need to drop the steering column and unbolt a few bolts that hold the brake booster on. I'll try to take a pic tomorrow of the petals out of the truck so you can see what it looks like...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-14-2004, 10:57 PM   #4
71Rat
ran out of money
71Rat's Avatar
i have a set of pedels out of the truck... but i have like 4 rivits holding mine onto the firewall and didnt feel like drilling them out. if i take the setup out i am just going to put the otherone in..... but i thought it would be easier to just take it apart in the truck.
Thanks for all the help
Rat
Old 03-15-2004, 02:51 AM   #5
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Why would you change out the pedals with another set???? Standard and auto pedal setups are the EXACT same thing!!! The only difference is is that the clutch pedal has been removed by undoing the spring, the rod clamp and by sliding the rod out of the housing. I have done this conversion on several trucks and also done the reverse by changing an original auto to a standard, you just slide the clutch pedal assembly into the housing and hook it up.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-15-2004, 02:55 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
How butch you wanna be? You could use the 'ole hot wrench. (cover carpet before doing this....don't ask me how I know .)
Old 03-15-2004, 02:55 AM   #7
cduster
I thought the pedals were different. Isn't the brake pedal wider with an automatic?
Dan
cduster is offline   Reply With Quote
Old 03-15-2004, 03:05 AM   #8
Longhorn Man
Nope, not untill 73.
Old 03-15-2004, 03:07 AM   #9
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Its been a while, but you unhook linkage theres a clamp on the rod unhook spring with vise grips and slide the cluch pedal and rod out of the center of the brake
sneakysnake is offline   Reply With Quote
Old 03-15-2004, 03:09 AM   #10
Firefighter
What he said!!^^^^^^ 67-72's had the exact same size pedals for the clutch and the brake even the auto was the same size, because as I had said before on the clutch removal that is all that they did at the factory just left the clutch pedal out.
Yellville, Ar. USA
Old 03-15-2004, 03:24 AM   #11
cduster
That being the case, gas axe for mine! Thanks, Dan
Old 03-15-2004, 11:21 AM   #12
71Rat
ran out of money
71Rat's Avatar
i knew they were the same but i got the auto set up for free so why wouldnt i take it? thanks for the reply's hopefully this weekend i can get it out.
Rat
Old 03-15-2004, 01:13 PM   #13
junkyardjohn
junkyardjohn's Avatar
Bowtie:
BLACK N BLUE IS RIGHT ... IT TAKES ALL OF ABOUT 10 MINUTES TO REMOVE THE CLUTCH PEDAL. WHY ANYONE WOULD CUT ONE OUT WITH EITHER A SAW OR A TORCH IS BEYOND ME. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-15-2004, 01:20 PM   #14
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
There is an indention in the cab behind the insulation that the top spring mount fits in to slide it out. You will have to fold back the insulation to find it, but once you do, it takes about 5 min to get out. Other then that, its really simple to unbolt and remove.
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 03-15-2004, 01:23 PM   #15
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Let's remove a little mystery from this one:
Step 1: remove bolt and nut
Step 2: pry arm off of shaft
Step 3: push shaft and pedal to the left out of bushings
DONE!
Total time should be less than 15 minutes, including removing and replacing instrument cluster.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-15-2004, 06:19 PM   #16
Putter
More Cowbell....
Putter's Avatar
Oh yeah....thanks for the visual aide. I am in the process myself. That helps a ton.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 03-15-2004, 06:19 PM   #17
Putter
More Cowbell....
Putter's Avatar
Old 03-15-2004, 06:52 PM   #18
71Rat
ran out of money
71Rat's Avatar
thanks for the picture and everything.... lots of help.
Just one more question.... how do i get that spring off? or do i even have to take it off? in your picture i didnt see a spring
Thanks a lot
Rat
Old 03-15-2004, 06:57 PM   #19
Tx Firefighter
I grabbed mine with dikes and pulled it and it popped off. It's not a man killer spring, just a little attention getter spring.
Old 03-15-2004, 08:50 PM   #20
Steven Sellers
Steven Sellers's Avatar
Originally posted by Tx Firefighter
I It's not a man killer spring, just a little attention getter spring.
LOL at TX Firefighter
2008 Buick Enclave(wifes new non wrecked)
1996 Jeep Cherokee
2002 2500HD 6.0L (traded)
1998 Jeep Grand Cherokee(wifes/wrecked)
1977 DJ5 postal jeep(mmm lots of fun)
1988 Toyota 2wd p/u(DD, blewup 199,000)
1991 Toyota 2ed p/u (sry just cant break these things)
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end".
Steven Sellers is offline   Reply With Quote
Old 03-15-2004, 11:10 PM   #21
project1971
project1971's Avatar
excellent! i will be doing this to mine soon also.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 03-15-2004, 11:57 PM   #22
Longhorn Man
You can't call them that anymore...they are women in comefortable shoes.
Old 03-16-2004, 01:58 AM   #23
72 CustomCamper
huh ???
Hey Andy,sounds like you've been listening to Robin Williams ...
Chuck
Old 11-25-2004, 11:20 PM   #24
hobby67stepside
Was that spelled COMEfortable shoes on purpose?
hobby67stepside is offline   Reply With Quote
Old 11-26-2004, 12:03 AM   #25
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Cut it off and go
A 3" or 4" die grinder makes a nice clean cut right up by the shaft...no fires like the torch. Why wouldn't you want to cut it? It is not worth anything to keep.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
