06-22-2016, 05:55 PM | #1 |
Dial indicator ???
I'm looking to buy a good quality dial indicator . What brands should I consider or stay away from ? I am a Toyota technician and I have access to the shops tools however I want to buy my own.. I just would like some opinions ...
72 C20 Longbed 05 1500 Z71 |
06-22-2016, 07:21 PM | #2 |
Re: Dial indicator ???
I have all of these and this is the order in which I like them..starrett..best,,, mitutoya...2nd best but real close to starrett,,, brown and sharp..3rd best
06-23-2016, 05:42 AM | #3 |
I also prefer the 0-100 thou per revolution..easier to read..I had a 0-200 but the marks are to close together to see easily...got rid of that sucker first chance i got...
06-27-2016, 01:07 PM | #4 |
what kind of dial indicator?
07-05-2016, 03:35 PM | #5 |
Starrett and Mitutoyo are your two best bets.
Fowler or Brown and Sharpe aren't bad, but I would go with one of the other two if you can afford it. Stay away from cheap ones if you want repeatability. |
07-05-2016, 09:38 PM | #6 | |
07-06-2016, 01:33 PM | #7 |
ebay and craigslist are full of good starrett stuff
i sold all of my 3''-36'' inside and 0''-16'' outside micrometers a while back w/ original cases and paperwork for peanuts but better to pass them on to someone that could need/use them
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-06-2016, 01:57 PM | #8 |
That's some big stuff you had there ogre..its a shame what this stuff costs new versus what you can sell it for..I know from experience that if you buy it new the cost of it will make you take very good care of it..even if its 20 yrs old its usually just like new..I've still got a box full of machinist tools I've had close to 30 yrs now and it all still looks brand new..I'd hate to think how little it would bring if I was to ever sell any of it.
07-06-2016, 05:41 PM | #9 |
If you get something used you may want to have it calibrated or at least checked.
If you don't have access to gauge blocks you may want to ask to use some at a local machine shop. If it is reading off you may need to send it in to get it calibrated/rebuilt/fixed. Anything is better than giving you wrong data. Think of how much an improperly sized bearing can cost you. |
07-06-2016, 07:45 PM | #10 |
Yeah I will be buying a new one. I really hate buying used stuff If I don't have to..
07-07-2016, 12:59 PM | #11 | |
If you're not doing high precision work or inspection, I wouldn't think you would need a high priced indicator. There are several brands that are very accurate and inexpensive and there are some cheap ones out there that are junk as well. I think you could get a combo set with an indicator and magnetic stand that would work just fine without breaking the bank.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
07-07-2016, 01:49 PM | #12 |
A1971Blazer,
By no means is it life or death precision but Toyota has new A/C compressors where dial indicator is used to measure the magnetic clutch air gap. I have needed one when replacing a bearing on a RAV4 Transfer case . There is always The oh so fun brake rotor runout measurement when vehicle is new/under warranty I was considering the Trick Flow kit/ cam degree wheel on Summit Racing but the reviews were not so great..
07-07-2016, 02:10 PM | #13 |
for general automotive work i would probably recommend something like this
http://www.centraltools.com/dials_clamp.html and get a magnetic mount to go with it |
07-07-2016, 02:36 PM | #14 | |
Thanks for all the input https://www.amazon.com/Mitutoyo-64PK...ator+with+base
07-07-2016, 02:42 PM | #15 | |
What style does your service department have?.....If that type works for you then go with it....all major tool suppliers carry a large assortment of different styles......just a matter of choosing ......the top brands will cost more and be more accurate, but may not be necessary for your application. I use a fairly cheap one to set up ring and pinion sets.....it has a mag base and has gotten accidentally knocked off onto the floor more than once......I don't like dropping my high dollar indicators on the floor.....
07-07-2016, 02:50 PM | #16 |
The shop has one with a flex arm/vise grip style. We mainly use it for brake rotor runout for warranty brake jobs... I will order a flex arm for mine also. I will not be using it everyday, once a month if that , But I am a tool junkie
07-07-2016, 03:32 PM | #17 |
i have a couple with flex arms but they can be sensitive to movement. i prefer something more rigid when possible
07-11-2016, 11:45 AM | #18 | |
like mongocanfly says 20 yr old precision stuff is usually well taken care of and sells for $.10 on the dollar
07-11-2016, 04:31 PM | #19 |
That mitutoyo is overkill for automotive work.
I work for NASA and am responsible for some hardware that is currently aboard the ISS. I have access to some of the most accurate metrology tools that exist, but with that being said, I just rebuilt a 12 bolt rear end using a harbor freight 0-1" travel indicator and mag base. |
07-13-2016, 06:44 PM | #20 | ||
09-08-2016, 10:37 AM | #21 |
I have been a machinist for 7 years. Dad has been a machinist for almost 40 years. I have a lot of starrett and mitutoyo and brown and sharpe. They are all nice quality and all repeat how they should. I have always preferred starrett. Now, if you can get your hands on an INTERAPID, those are very nice and i would take that over any brand i mentioned above. Tesa is also a good brand
09-12-2016, 11:25 AM | #22 | |
Some other guys have mentioned the cheepie brands and generally for a one-off use kinda thing they would likely be ok if you have the ability to test and confirm their accuracy through the range. However, I would not use them for machining close tolerance parts no matter what.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks Last edited by mmiddle; 09-12-2016 at 11:33 AM. |
09-21-2016, 12:02 AM | #23 |
Just to add some more to the Starrett vs Mitutoyo debate, it seems like our company follows a general rule of thumb.
If it is a digital display (digital calipers, profilometers, etc) it will generally be a Mitutoyo. If it is a mechanical or scale based display (dial calipers, dial indicators, micrometers, depth micrometers, etc) it will generally be a Starrett. Each has their strong suit. Personally, I do not like the way a Mitutoyo micrometer feels and I don't care for the way the cylinder lock engages. Their digital calipers however are excellent and honestly, pretty affordable considering the quality you get. One badly fit bearing can pay for a few nice measuring tools in a few short seconds. |
