Old 07-20-2016, 11:06 PM   #1
Trevor
Trevor's Avatar
No-limit relocation kit shocks at an angle Why ?
I'm researching my rear shock relocation options, and I like the looks and theory behind the No-limit outboard mount location, but don't understand why the upper mount is placed so far back that it puts the shock at quite an angle and therefore in an arc opposite to that of the trailing arms arc (a double no-no).
Is it to maximize shock length ? or does the stock panhard bar frame mount interfere ? Or is there something else I'm missing ?
I may just fab my own so any insight would be appreciated,
Trevor is offline   Reply With Quote
Old 07-21-2016, 02:26 AM   #2
ck5566
Re: No-limit relocation kit shocks at an angle Why ?
watching for some answers here. FREE BUMP
ck5566 is offline   Reply With Quote
Old 07-21-2016, 04:10 AM   #3
dflarsen77
Active Member
On their website, they have an article (it sounds like it was written by a 3rd party magazine, but it doesn't give anyone credit) about the install:
http://nolimit.net/tech-center/67-c1...on-kit-1963-72
In the article it says:
"By far the biggest mistake made by the engineers at General Motors during the early sixties was the shock placement on the trailing arm suspension. But who knew that these trucks were going to be pushed to the limits of performance driving. No Limit found the cure for the shock placement mishap that gives C-10 enough “body roll” to make someone sea-sick. By re-locating the shocks “outboard” rather than inboard of the frame, your C-10 will become more stable in the turns. Also by moving the shocks behind the axle, they complement the ride quality as well as they can now control the “wheel hop” that many trucks are prone to."
I know zip about suspension geometry specifically, but their flowery speech sure makes it sound awesome.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 07-21-2016, 04:59 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: No-limit relocation kit shocks at an angle Why ?
Well I have the kit on my 71 and I'll say this. The truck handles way better and I have min body roll.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-21-2016, 06:32 AM   #5
GR8-68
GR8-68's Avatar
Never seen or heard this, this is why we love this forum Thanks Andy for the feedback and pics, I will be ordering mine soon
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-21-2016, 09:06 AM   #6
DaHos
DaHos's Avatar
It actually keeps them more vertical .........
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is online now   Reply With Quote
Old 07-21-2016, 09:44 AM   #7
Wingnut Way
Got this kit on my 63 with 5 in drop coils in the back. Love it rides better than stock 😎 as far as the angle Idk I'm not that smart. I'd say something to do with the travel of the trailing arms, they have a fulcrum point where they attach to the frame, making the rear end travel at a radius instead of completely vertical up and down movement. I'm sure it ant much of a radius but I assume the angle is the best compensation for that....? Or there was just a reference point hole there to go off of for the customers ease of installation. Lol not sure just my thoughts good question
Wingnut Way is offline   Reply With Quote
Old 07-21-2016, 10:32 AM   #8
im4darush
Have this kit on a bagged 68 SWB and the difference in ride/handling is very noticable.
im4darush is offline   Reply With Quote
Old 07-21-2016, 10:37 AM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Subscribed to remember these. This looks like a good option instead of having my rear shocks dang near laying flat to the stock mounts with a lowering kit.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-21-2016, 11:38 AM   #10
Andy4639
Old member
Andy4639's Avatar
Other than the LS motor and cruise control it's one of the best mods on my truck!
By the way I took the rear sway bar off the truck after installing it.
Old 07-21-2016, 11:48 AM   #11
ck5566
Gary
I am curious to know at what point you need this done? Nobody has said any thing as of what the amount of lowering was used like for a 1" lowering or a 2" lowering or a 3" lowering and so on 3", 4", 5".
I guess my point is at what point does the Suspension need the shock relocation done to correct the problem when lowering these trucks rear Suspension as much as some people like them.
Mine I will be using only a 2" lowered/dropped rear Coil Springs and the fronts will have only a 1" lowered/dropped Coil Springs.
Will I be OK with my small drops or will I still need to do the Shock relocation deal? My truck will NOT be going into turns at High Speeds at all, its a Truck not a Corvette! It does look like the information above is useful for the Extreme Drops.
Old 07-21-2016, 11:52 AM   #12
Wingnut Way
Kit is for any ride height including stock. Different drops different shocks. Affects ride quality greatly. Suspension geometry bla diddy bla bla. I recommend the kit works great
Old 07-21-2016, 01:49 PM   #13
Andy4639
Old member
Andy4639's Avatar
Mine was for 4" drop static in the rear.
The kit itself is worth it even for a stock ride because it moves the shocks to the outside of the frame for better ride quality. Hardly any body roll at all.
Old 07-21-2016, 02:02 PM   #14
Wide Open
These are only made for 2WD trucks I take it?
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 07-21-2016, 02:08 PM   #15
Wingnut Way
Trailing arm setup only. I think all K trucks were leaf correct me if I'm wrong
Old 07-21-2016, 02:11 PM   #16
Wingnut Way
I wouldn't say all half tons ether, gmc were leaf also if I recall correctly
Old 07-21-2016, 02:13 PM   #17
dflarsen77
Active Member
Here's the post when No Limit first made them:
http://67-72chevytrucks.com/vboard/s...d.php?t=444925
Interesting stuff. I really didn't know about these, but now that I do, I'm definitely going to get them. They cause a scrub line issue though. If you want to use drop blocks, and this kit, you'll need a 17" wheel or more.
David Larsen
1970 Chevrolet C-10
Old 07-21-2016, 02:15 PM   #18
Wide Open
OK thanks. That's what I figured after reading the article and only mentioning the trailing arm/coil suspensions.
Would be nice to move the shocks outboard on the leaf trucks too. I suppose something can be fabricated.
1972 K10
2002 Z06
2007 Escalade
Old 07-22-2016, 06:29 AM   #19
Outside of this kit, they recommend shock relocating at 4" or more drop. The other options help correct the angle in original location. This kit is newly engineered to locate shocks outboard like on newer vehicles, which is a benefit at any height for stability, and a correction for lowered angles.
Old 07-22-2016, 06:00 PM   #20
ck5566
If just wanting to re angle the rear shocks I wonder if this Kit from Brothers would work just as well.
Old 07-22-2016, 08:00 PM   #21
elf w/capital T
very smooth, just make sure to get the right shock length
elf w/capital T is offline   Reply With Quote
Old 07-22-2016, 10:27 PM   #22
Andy4639
Old member
Andy4639's Avatar
For the difference in price go with the No Limit kit. Much better kit.
Old 07-22-2016, 11:00 PM   #23
midniteblues
midniteblues's Avatar
Wow Andy,your rear tires sure are close too the inner fender huh.
Signing on too this one too see what the op comes up with, you all know why...
Ck, those are pretty much the standard aftermarket relocators same as ece's relocators.
There is a write up in the fac section on how too make these out of the oe mounts.
If Ya have the tools they are very easy too make from box tube.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 07-22-2016, 11:39 PM   #24
Boyd67
Boyd67's Avatar
I'll have to try and remember these no limit ones when I lower my truck
Boyd
-67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie
Boyd67 is offline   Reply With Quote
Old 07-22-2016, 11:45 PM   #25
70cst
70cst's Avatar
This would be right up "WES"'s ally ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
