Converting to hydro clutch
Hi guys I'm about to get underway with my LS swap in my 1972 c10 but I have run into a problem...
The LS engines do not have a place to mount a traditional Z bar so I am forced to convert to either a Hydraulic clutch or Hydraulic throwout bearing. I have scoured the web and can't seem to find anyone that makes a direct kit for our trucks so I'm hoping there is someone here that will know a little more about this than me. My truck currently has no power brakes either so I am sure I will need to get a booster. Thanks ahead of time!!
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 ![]() |
Re: Converting to hydro clutch
Well i'm on a tight budget, so i used the same setup that was in the firebird i got the motor and trans out of,i just fabricated a bracket beneath the dash in line with the existing clutch linkage.
I'm running mechical linkage with my LS3. Much easier to mount the ball stud than to do a whole hydraulic conversion.
You can mount it many ways, and this bracket is only one of them (it bolts to the bellhousing, requires a little grinding on the block) http://sdparts.com/i-24074894-sdpc-s...nd-trucks.html
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Maybe i should have asked what trans you were going with lol!!!
motor exploder
McLeod makes a nice hyd t.o. bearing. I've using them a couple of times with TREMEC tko-500's, once in a '92 C1500, the other in my '69 C10. Just do some measuring bolt the master to the firewall and connect the pushrod to the clutch pedal with a clevis & turnbuckle. I fabbed mine up in no time. I also have a RAM hyd t.o. setup that I'm about to use with a TREMEC tko-600, and the setup is a little nicer than what's showing below. This go around I used a rod end instead of a clevis, and used Lokar Pedals.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 07-19-2016 at 11:57 PM. |
motor exploder
pics
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Thank you for the responses!!
I have not put an LS in a pickup yet unless you count my current build (72 El Camino) as a truck, like GM did.
On my last 67 chevelle LS swap and my current El Camino ls swap I used a bracket from Tick Performance that installs under the master cyl. and the clutch slave cyl. mounts to that. The remote res. mounts off to the side. That way you are using the factory stuff. Worked fine for me and my buddy.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
