07-28-2016, 09:36 AM | #1 |
Cutting 3 cabs up...
I am cutting 3 cabs up this weekend. There is no titles to these. There is lots of good metal left. One has a really nice firewall, I just don't know how to cut it out to be able to reuse it. So I will cut pieces out of too. I will get pics up later today or tomorrow.
I also have a 1969 GMC LWB chassis that will get cut up to be hauled away... Thanks! Jimmy
Jimmy Hoelzel |
07-28-2016, 10:15 AM | #2 |
Re: Cutting 3 cabs up...
Looking for the jamb tag below the vin.
07-28-2016, 01:46 PM | #3 |
2 of the cabs are GMC's...not sure if the other has any tags on it.
I will check tonight. Thanks! Jimmy
Jimmy Hoelzel |
07-28-2016, 05:58 PM | #4 |
how's the floors?
07-28-2016, 06:11 PM | #5 |
looking for good kick panals, both sides and the floor on the driver side foot area
1967custom |
07-28-2016, 06:20 PM | #6 |
This what your looking for?
Jimmy Hoelzel |
07-28-2016, 06:24 PM | #7 |
Sorry Larry, most of the floors are gone.
I have a cab that has perfect kick panels, but I am not sure how to remove them?
Jimmy Hoelzel |
07-28-2016, 06:32 PM | #8 |
wow is thst a hornets nest?? i need all that floor too thats in the pic all the way to the seat mount riser.
you could just sawz all it all off in one piece
1967custom |
07-28-2016, 06:39 PM | #9 |
LOL...just insulation hanging down. How many inches of floor pan? And how do I ship these?
Jimmy Hoelzel |
07-28-2016, 07:11 PM | #10 |
Interested in one of the firewall sections under the heater box and up to the wiring gutter just above heater box. Some pics of where mine is rotted for reference.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
07-28-2016, 07:14 PM | #11 |
Also need some patches for the lower front windshield channel on both sides. Thanks.
07-28-2016, 07:19 PM | #12 |
Hi Kieth. One of the cabs has a perfect firewall... Just wasn't sure how to remove it in one piece. And how is the best way to ship?
Jimmy Hoelzel |
07-28-2016, 07:29 PM | #13 |
Jimmy, I probably only need about a 15x15 section of the firewall where the heater box is! A cutoff wheel or sawzall would make quick work of it if you don't mind cutting it up. I think ups or fed ex would be fine for shipping. On the lower window channels, I would need about a 8" section on each side of the cab where the factory seem is.
07-28-2016, 07:50 PM | #14 |
Don't mind cutting any of it up at this point. I just need to make sure I can ship the pieces. I only have one that has the bottom of the windshield intact. I will go get a couple pics.
Jimmy Hoelzel |
07-29-2016, 06:29 AM | #15 |
Thanks Jimmy, let me know!
07-29-2016, 09:16 AM | #16 |
what year and what do the gmc tags look like? i could use a bottom one
07-29-2016, 09:26 AM | #17 | |
Thanks! Jimmy
Jimmy Hoelzel |
07-29-2016, 09:31 AM | #18 |
thanx
07-29-2016, 12:28 PM | #19 |
im thinking the floor about 8 inches in (towards the gas pedal) and all the way to the where the floor has that vertical hump under the bench seat right in front of the seat. if you have a cell that gets pics ill send you a pic of what im looking for.
505-907-6836
1967custom |
07-29-2016, 01:01 PM | #20 | |
Jimmy Hoelzel |
07-29-2016, 01:27 PM | #21 |
ok ill do that when i get offa work
1967custom |
07-29-2016, 01:58 PM | #22 |
Could I get a cut of the gas fill hole. Mine was welded shut, and not very good. I would like to get it to look original again. Could also use a cut of the filler neck and a cap if you have that. Thanks
07-29-2016, 02:09 PM | #23 |
I will see what I have, some have been welded up already. I know I dont have any spare tanks or caps.
Jimmy Hoelzel |
07-29-2016, 02:14 PM | #24 |
Thank you
07-29-2016, 03:33 PM | #25 |
need a cut around the heel of the gas pedal area say 8" right .left ,up & back of the 2 ball sockets of the gas pedal area ! anything good there in a cab ?
