![]() Join Date: May 2016
I purchased a set of American Racing chrome rims for my 70 Chevy C10. They are 6 lug. I took it in to a shop to have some work done on the carburetor and the mechanic says they are not the right size rims. He said that the studs are not long enough. When the lug nuts are on there is not enough tread to secure the wheel on the vehicle and it dangerous. Can anyone offer any advice on this? Is there anything I can check or do to keep from having to change all the studs. I hate to not be able to use the rims but I need to make sure they are secure for the road. If there is nothing I can do with the rims I will have to try and sale them and go back to the steel wheels. Thanks in advance Ron
Re: Wheel Question
Maybe spacers with longer studs? Picture is for illustration only, make sure to do your homework and buy the right ones for your truck.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
![]() Join Date: Dec 2013
Re: Wheel Question
studs are cheap , you can change them out in your driveway or have your mechanic do it .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Re: Wheel Question
Re: Wheel Question
X3...you will be happier with the results
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 08-08-2016 at 05:13 PM. |
#6 | |
Re: Wheel Question
In my part of the world his licence is at stake and he would be held responsible if a liability occurred. For a closed lugnut you want it to engage the threads 1 1/2 times the width. For a 1/2 inch stud you need 3/4 inch of attachment. A 7/16 inch would be about 5/8 inch. Check them yourself. Maybe your studs are ok but you need longer shank lugnuts. |
laying low
![]() Join Date: Mar 2001
Re: Wheel Question
Post a pic of your wheels then a pic of your wheel in place on the truck. Maybe we can better help figure out what you need. Replacing studs is no big deal if thats all it needs. You said chrome wheels so we can assume they are steel?
Re: Wheel Question
See pics. These are American Racing Rims
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Wheel Question
Those wheels would look good if they were nicely polished. That said, I wouldn't drive that truck around the block with so few threads holding the wheels on. As Grumpy and others said above, just get longer studs.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Re: Wheel Question
If you are up to the task, you can find new studs here. Be careful with what you have, I would recommend changing back to the steel wheels if you still have them, and then look at getting new longer studs. If you are not up to picking the new studs you should definitely get a decent mechanic to help you out. What you have right now is not safe to drive for sure.
http://www.dormanproducts.com/catalog/2006_hardware.htm
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
Re: Wheel Question
Or get the right lugnuts for your wheels.
If yours look like the ones in this seat type chart on the left, you need to use the ones on the right side of the chart. That will give you plenty of thread engagement. http://www.brandsport.com/howdoifirilu.html |
Re: Wheel Question
Re: Wheel Question
So are there lugs that I can get that will offer more contact with treads and be safe to drive. I like the rims and I don't want to have to replace all 24 studs. Like someone said I could go back to the original steels. I do have them but would need to get them sandblasted and painted. I just want it to be safe! Thanks to all. I'm new to the site and trying to learn as I go on things.
Re: Wheel Question
Change the nuts like Geezer said......
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
#15 |
Re: Wheel Question
Just like this.
http://www.ebay.com/itm/Otis-Inc-LA-...RRCEiA&vxp=mtr |
#16 | |
Re: Wheel Question
