Old 08-09-2016, 04:42 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Recommended Clutch Fan?
My OEM fan clutch is showing signs of wear and I plan to replace it before long. It's weeping a bit of fluid near the shaft and the fan has a tiny bit of wobble. Online shopping has turned up several that will fit, but I'm not sure if some are better than others. Any that you like, or any that you would avoid? Right now I'm leaning towards an ACDelco 15-80245 which *may* be an identical replacement. Thanks.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-09-2016, 07:04 PM   #2
davepl
davepl's Avatar
Re: Recommended Clutch Fan?
I bought this one - not the cheapest but I too wanted ACDelco. Amazon lists it as a direct fit, but it's not cosmetically identical to the old ones. Close though.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-10-2016, 10:03 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, they show that as correct for your big-block GMC, and 15-80245 for my SBC.
So you are happy with the way yours works? Engages and disengages when it should? Curious because I have read about some units being too aggressive (for lack of a better word), locking up too early and staying locked for too long, creating power loss and extra noise.
- Mike -
RIP El Jay
Old 08-11-2016, 09:21 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I have a Real AC Delco brand new in the box that you can have for $75 plus shipping. I paid way over $100 bucks when I bought it.
Tom Vogel is offline   Reply With Quote
Old 08-11-2016, 09:37 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The one I have been looking at claims to be AC Delco. If you don't mind my asking, is there a difference between yours and that one? What's the p/n on yours? Thanks.
- Mike -
RIP El Jay
Old 08-11-2016, 11:26 AM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Hows this? if you cant read it, the number is 22050676 This a Real GM clutch fan, not a chinese knockoff... Dayton Ohio, USA made.
Old 08-11-2016, 01:49 PM   #7
davepl
davepl's Avatar
No complaints from me. Works as expected. Seems just a bit tighter than my (probably still working) original, as you'd probably think it should.
Seems to tighten up an appropriate amount for the heat load.
Old 08-11-2016, 03:24 PM   #8
jr1000yarder
I just got mine from GM. Part #19189681
1969 396
Says made in USA on the clutch....
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 08-11-2016, 04:07 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thanks for the feedback, guys, I appreciate it. And thanks for the offer, Tom. That unit may do the trick but it does look different than mine, and the p/n is different. I'm going to do more digging before I commit.
- Mike -
RIP El Jay
Old 08-11-2016, 04:15 PM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Mine is for a smallblock.
Old 08-15-2016, 03:23 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Update, and I'll keep it brief. There are three types of thermal fan clutches -- standard duty, heavy duty, and severe duty. Good explanations / illustrations here: http://www.haydenauto.com/featured%2...s/content.aspx
My K20 uses a heavy duty unit but I could not find one. Virtually all are standard duty, and a very few are severe duty. Went to my local NAPA and another customer overheard us and suggested looking up the part for a slightly newer K30. Bingo! NAPA p/n 271303, fan clutch #2747. Made by Four Seasons in Lewisville, Texas.
Tom, I have to pass on yours. It is a standard duty and not recommended for my K20.
- Mike -
RIP El Jay
Old 08-15-2016, 06:22 PM   #12
samkost
samkost's Avatar
Tom,
Is the Delco clutch fan you have, a thermal or non-thermal?
I made a similar post about replacing mine and wonder if the part you have is a direct replacement. Forum members answered suggesting that I get a thermal style for replacement.
Sam
samkost is offline   Reply With Quote
Old 08-15-2016, 08:10 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Guys, if I may, Tom's Delco above is a standard duty thermal. The above link clearly shows how to make the determination.
- Mike -
RIP El Jay
Old 08-15-2016, 08:27 PM   #14
samkost
samkost's Avatar
Thanks for clarifying Mike.....I went to that site to read the differences but it obviously didn't sink into my thick skull
I'm learning.....
Old 08-17-2016, 03:50 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Just to follow-up. I installed the new fan clutch yesterday. With the old one off, I could see it had seeped out a lot more fluid than I had thought. The shaft and the rear of the unit were heavily coated with built-up gunk. On a side note, I had also been unsuccessfully chasing what sounded like an occasional fan belt squeal. It would only happen around 1200-1300 rpm.
Took her out for a test run this morning. Temp gauge stayed at the lower end of normal, which is right where it usually reads. Went up the mountain and it climbed to a bit below halfway, typical for the situation. And I cannot create the 'squealing fan belt' noise. I suspect it was coming from the old fan clutch since it had lost a significant amount of fluid. Everything seems to be working just like it's supposed to.
- Mike -
RIP El Jay
Old 06-10-2017, 08:00 PM   #16
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Saved for reference.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-10-2017, 08:42 PM   #17
davepl
davepl's Avatar
I ordered this Delco one for my 402, but when it arrived it had the Severe Duty style and shape, not like pictured.
Old 06-10-2017, 10:01 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Severe Duty *might* be overkill (stay engaged too much, extra roar, use a bit more fuel) or it might be just what that big engine wants. Are you planning to keep it, or return it and get a Heavy Duty unit?
- Mike -
RIP El Jay
Old 06-13-2017, 12:48 PM   #19
davepl
davepl's Avatar
It doesn't seem to run too much or make any additional noise, so I kept it and am running it!
Old 11-07-2019, 10:44 AM   #20
FoxCustom
FoxCustom's Avatar
Stocker, Great info on the heavy duty clutch. I currently am running a fixed blade setup in my '87 V20 and I'd like to level out the temp especially since it's getting cold here.
I'm having trouble finding the actual fan blades themselves to run with this clutch! Any recommendations?
FoxCustom is offline   Reply With Quote
Old 11-07-2019, 11:15 AM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The OEM 7-blade fan on my K20 with factory A/C might be the best possible choice. Mine is 18" diameter but your '87 might be different (and some big-blocks use a 19.5" fan) so the first step is to measure yours. Original fans sometimes come up for sale on the parts board here. Aftermarket suppliers like Summit, Brothers, and Classic Industries are worth a look too.
- Mike -
RIP El Jay
Old 11-07-2019, 12:15 PM   #22
rpmerf
rpmerf's Avatar
Junkyard would be your best bet if you got any nearby with square bodies. Otherwise, I know Summit Racing has them. I bought one for my truck a couple years back.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-07-2019, 01:02 PM   #23
RustyBucket
RustyBucket's Avatar
I bought one from Advance a few years ago .. a Dorman product. Local store got it from their warehouse same day. You can probably get their part number from the website and avoid the dread "kid at the counter" interaction.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 11-07-2019, 02:54 PM   #24
FoxCustom
FoxCustom's Avatar
Cool, I'll keep my eyes peeled for an original fan and then just have that NAPA heavy duty clutch ready to go once I find it. I believe my current fan is around 19 3/8"-19 1/5" OD.
Thank you for the info!
Old 11-07-2019, 04:04 PM   #25
FoxCustom
FoxCustom's Avatar
Advance.... Oooooh that's a tough one
Okay, I'll check with them - i did see some Dorman repops out there so I'll investigate as to which part number will work for me.
Thank you, guys!
