1952 Chevrolet 3100 on s10 frame with LSX- build thread
So I figured I might as well make a build thread. I started out with a 1984 single cab long bed S10, a front clip, a cab from a 52, a short box from a 49 and a 1999 4.8 litre and a 4l60e. I paid 300 for the s10 delivered, 800for the clip and cab and title, and 300 for the 49 box. The truck will be matte bright white with gloss black grille, bumper, door handles... All the trim. Cab is sound deadened with fat mat. I have Dakota digital vhx gauges, vintage a/c, stern beast 20" wheels, tanks Inc fuel tank and set up, psi wiring harness... And a bunch of other nice parts for it, I designed custom hood emblems also. Pics coming!
Here is the 52 parts hat I started with . ![]() Here are the truck parts ![]() 4.8 with 120,000 on it ![]()
My build thread for the bagged 91 http://67-72chevytrucks.com/vboard/s...d.php?t=654179 Build thread for the slammed 52 http://67-72chevytrucks.com/vboard/s...=1#post7683427 |
Re: 1952 Chevrolet 3100 on s10 frame with LSX- build thread
I read everyone else's posts and changed he measurements a little because I want my truck on the ground but with no air ride... So here are some of the mounts I made
Some weld action ![]() ![]() ![]() I made some panels and brad rolled them for the firewall ![]() Seat installed and column mocked up ![]()
In having a local upholster do my seat, door panels and headliner kind of similar to this
![]() These are the wheels I have 20x9 Stern Beast wheels. I wanted a somewhat modern resto mod type look ![]() These are the headlights which I think will be awesome against the matte white ![]()
Trans painted
Motor painted, did the valve covers matte white. I used a 1970 gm fleet bright white and then sprayed a matte clear on top ![]() Intake cover, it rid of the vortec ![]() Here are the logos I designed and had a friend cut them out with a cnc laser, these will be gloss black on the sides of the hood ![]()
Hand made trans crossmember, it's now bolted through the side and the top
![]() More weld action ![]() Frame painted with chassis saver-I'm gonna drive this thing ! ![]()
Dash primed after I filled some holes and built a small cubby hole
![]() Had to check one of the gauges out ! ![]() After I had it mostly mocked up ![]() I did 3" drop lower control arms and 3" blocks in the black Most of he body work done, I hand made the front part of the floors and trans tunnel as well as shaved the hole for the fuel fill ![]() That's all for now.. Should have my interior back in a week or so and I'll use it painted and hopefully done in a month, maybe a little longer.
![]() ![]() Join Date: May 2015
Looks like a good start to a great build..love the new hood emblems..what's your ride height? That looks mighty low..that wouldn't work where I live..haha
Thanks ! I'm going to stain the wood black also.. And do gloss black steel
strips in between the wood. I've never seen a matte white with gloss black trim 47-53... Ever. So I hope it turns out like I'm hoping ![]()
At the front of the running boards it's right around 5 inches off the ground. I think it looks lower in the picture than in person.
What do the dots mean?
Sorry bout that..everytime I post and hit my back button it will double post my original..it didn't use to do that but here lately every time I post I have to go back to the home page or it will double up...so if I catch it in time I just hit edit and put dots in it cause I can't erase it..
Oh haha no problem
Yep it looks lower than 5"..I'm shooting for 5-6 in on mine..yours looks like 3 or 4..
#15 |
Looking good man. I'm interested to see how your firewall came out with your custom bead rolled panels.
#16 |
I will snap a pic tomorrow
#17 |
Looks really good! I'm at 5.5" under the front of my running boards and 3700 miles into it the closest it's come to hitting anything was pulling on to the 4 post hoist for the alignment.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#18 |
That's awesome ! I like them low. The last truck I built I did air ride, and it was cool but I didn't think it rode the way I thought it should. I did a manual valve setup on it. If I did it again I would do electric valves and height sensors so it stays at ride height no matter what when you set it. I drive quite a bit. I live a hour away from friends and family so the stuff I build has to be reliable. I did the LSX because I wanted the power, reliability and gas mileage .
#19 |
![]() Join Date: May 2007
great work! looks amazing
#20 |
![]() Join Date: Mar 2011
Looks great, I'll hang around for more updates...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#21 |
A320 Pilot/USAF Retired
Nice build!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#22 |
Upholsterer sent me a picture of one of my door panels today
#23 |
Seat finished, just have to pick it up !
![]() Doors painted bright white and matte clear coated ![]()
#24 |
Looks good, Will be following this build
My chevy 51...... http://67-72chevytrucks.com/vboard/s...d.php?t=541148 www.knutselracing.nl |
#25 |
Thanks ! Hoping to have it on the road in a month or so
