Old 05-31-2014, 07:56 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
coolant temp sensor
I have the ls engine coolant sensor hooked to the ecm, but what about the one for my gauge how can i get a sensor on my engine for it?
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 05-31-2014, 08:13 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: coolant temp sensor
I used the spacer in the back of the passenger side head for my gauge.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-31-2014, 11:13 PM   #3
fastpace
Where did you put the one for your fans then?
I have my fans on the back of the passenger head, the ECM on the front of the drivers head, and then my guage we were going to weld a bung into the water pump but we haven't done anything yet. For right now I'm just using a bluetooth OBD2 scanner with my phone to keep an eye on it.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 05-31-2014, 11:58 PM   #4
ls1nova71
ls1nova71's Avatar
What gauge are you running? That will be a factor in what sender you use.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-01-2014, 07:08 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: coolant temp sensor
The fans are controlled by the ECU which feeds off the sendor in the drivers side head.
Old 06-01-2014, 03:05 PM   #6
whitels1
whitels1's Avatar
What I did
http://carburetorssuck.com/?p=238
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-01-2014, 06:24 PM   #7
1970 C10 MJW
i am using the factory gauge
Old 06-02-2014, 10:11 AM   #8
JJH Jimmy
JJH Jimmy's Avatar
Call me a chicken, but i didn't have enough balls to drill and tap the head to a 1/2" NPT. So i drilled and tapped the water pump.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-02-2014, 02:04 PM   #9
scss02
I just started a thread on how I solved my problem.
Easy Coolant Temp Sensor Fix
Hope tis helps
scss02 is offline   Reply With Quote
Old 06-02-2014, 06:56 PM   #10
Jon01
Jon01's Avatar
Autometer makes everything you need, if you search my username there's a thread I posted in that contains all of the part #'s you need to use their adapter and sender with the stock 67-72 gauges.
I have one in my truck and the gauge is nice and linear in it's action and about vertical at 210* which is exactly where it should be with these motors.
Jon01 is offline   Reply With Quote
Old 06-03-2014, 03:09 PM   #11
woodwright
Enjoying left field
woodwright's Avatar
The PO stripped the hole in the front of the drivers head, so I drilled and tapped it to 1/2" NPT and put the stock 5.3 sensor in the rear of the passenger side. It was pretty easy. I put grease on the bit and tap to keep the bits of aluminum out of the head.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 06-03-2014, 05:25 PM   #12
Billett
Billett's Avatar
I did the same as Andy. Drivers side is for PCM which controls fans, pass side is for gauge. I actually get a different reading between the two. It's been as much as 20 degrees at some times.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 06-03-2014, 09:37 PM   #13
Jmiller022
Jmiller022's Avatar
I drilled and tapped the top of the water pump.
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 06-03-2014, 11:35 PM   #14
Billett
Billett's Avatar
I drilled and tapped the water pump for the steam vent lines.
Will
2024 Toyota Sienna
Old 06-04-2014, 06:32 AM   #15
Andy4639
Old member
Andy4639's Avatar
Talking Re: coolant temp sensor
I also have the scan gauge 2 in the truck so I have 3 readings and yes the passenger side is always higher than the computer readings about 18 degree most of the time.
Old 06-04-2014, 11:16 AM   #16
woodwright
Enjoying left field
woodwright's Avatar
Is that gonna mess me up having the ecu sensor in the back hole?
Clint
Old 06-04-2014, 10:51 PM   #17
66LSx
66LSx's Avatar
Having a sensor in back is no different that the one in the front of your driver side... No... no negative effects.
Guage adapter after removing the passenger side rear cylinder head OEM fitting is: (m12x1.5 - 1/8" NPT)
Autometer 2277
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 06-05-2014, 01:41 PM   #18
Billett
Billett's Avatar
Yup that's^ the same thing I did. And good to know I'm not the only one with temp variation between the two. I'm not worried since my e-fans run off the pcm anyway so when I check my gauge I just look at it and subtract about 15 degrees in my head. I haven't had any overheating problems since the new rad anyway though.
Will
2024 Toyota Sienna
Old 06-05-2014, 09:13 PM   #19
Mr. 250r
Mr. 250r's Avatar
Took the stock temp sensor from my 91 350 had it milled down to fit the passenger head, plugged right in, voila.
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 06-06-2014, 08:16 PM   #20
Pillow
Pillow's Avatar
Good info!
What 1/8 npt auto meter / vdo sender works with our 67-72 gauges though. With the Autometer. 2277?
Thanks! Should help the OP as well.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
Old 06-07-2014, 09:12 AM   #21
lutronjim
Does any of the late model cars/trucks use an idiot light. I am installing a lc9 in my 70 swb and just want to get a switch to make idiot light work. The right head is plugged on the back with a m12x1.5 bolt and washer.
lutronjim is offline   Reply With Quote
Old 06-11-2014, 10:46 PM   #22
Pillow
Pillow's Avatar
I'll answer my own question here:
Autometer 2277 adapter.
Auto Meter 2259 Short Sweep Electric Cyl. Head Temp Sensor (340°)
'79 Porsche 911 SC
Old 06-12-2014, 10:55 AM   #23
lutronjim
Wouldn't the adapter keep the sensor/switch from going into the coolant?
Old 08-19-2016, 11:31 AM   #24
preciador6
Nice
preciador6 is offline   Reply With Quote
