08-25-2016, 12:34 PM | #1 |
Fuel line pictures
Does anyone have a photo handy of factory fuel line routing from pump back. It's a 82 swb single tank. I'd like to reuse my factory lines they are in good shape but I'm sitting here scratcHong my head tryin to figure out how these things lay in
08-25-2016, 02:40 PM | #2 |
Re: Fuel line pictures
No pics but mine ran from the tank across the crossmember to the passenger side rail and then up the inside of the frame rail to the pump..
08-25-2016, 05:41 PM | #3 |
Yeah I kinda know the general way it goes but being there is no engine in and I stripped down the frame I don't know which holes in frame clips mount in
08-25-2016, 07:07 PM | #4 |
It shouldn't be to hard to figure out.get the line in place and it should be obvious which holes you need to use as long as your lines not bent all out of shape..all my line clips were bolted with those self starter bolts and the lines were about in the middle of the frame.the rear brake lines were running along the same path on the frame rail..mines runs on the drivers side now so a pic of mine won't do you much good..
08-25-2016, 08:57 PM | #5 |
Thanks for replies
