Re: building a mule
couple more pics of the front and rear ends |
Re: building a mule
Re: building a mule
Last year i found a front end from a 73 k10 that had all the power steering and disc brake set up i was looking for. iI got it cleaned up and replaced allo the seals and bearings brake rotors calipers and upgraded to warn locking hubs
Re: building a mule
would love to have that truck ... nice score ...
dont want to hear excuses, i want to hear solution(s) |
![]() Join Date: Dec 2004
Re: building a mule
looking good! what are the dimensions of the shop?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
Re: building a mule
24x24 with 10 foot walls and bunus room trusses lots of storage upstairs.
of course i wish i had built it bigger but so far i havent run out of room. i move my 4 wheeler and lawn moweres out when im home and park them in the shop when im gone for a couple months |
Re: building a mule
of course i wish i had built it bigger but so far i havent run out of room. i move my 4 wheeler and lawn moweres out when im home and park them in the shop when im gone for a couple months. the last couple of pictures were taken the day before i left for the fishings season so i had already moved stuff back in to get ready to go. |
Re: building a mule
I spent a bunch of time with my local tire shop mechanic trying to figure out lift options and got absolutly nowhere except a free set of rear leaf springs that are heavy duty and almost new. Probably wont even use them. All i want to be able to do is stick some 33s on the truck with no rubbing or bumping.
Re: building a mule
My goal was to have the wheels and tires under the frame by the end of the year but my fishing season is going really slow right now probably wont even be back to montana till mid november which happens to be rt in the middle of bird hunting. so not being sure how im going to work out the suspension and running short on time might not get to it till spring.
Maybe some of you guys have some input on the suspesion stuff? |
60-66 Nut
Re: building a mule
The original springs will provide plenty of lift to clear 33" tires.
Re: building a mule
I will also have a cab to get rid of in the future that may have some value to somebody when im finished with it i dont want anymoney for any of my stuff but im not wanting to have to ship it or haul it
Re: building a mule
Moscow, you're sure giving that thing the treatment. Was the undercoat on the frame meant to protect it from chipping? Looks nice. Are going to scrape it off where things bolt to it?
Re: building a mule
when i put the por 15 on it looked fine although there were a few spots with runs. por 15 has no uv protection and not great for scuffs and scrapes so i took some of that spray on perma tex stuff and shot a bit of it on the bottom and i really liked how it looked figured what the heck and did the whole thing. its not real thick anywhere and i keprt it to a minimum where there was bolt padads and such. we will see how it goes
Re: building a mule
OK. cool. Hope it works out well. Look forward to seeing your progress.
#15 |
Re: building a mule
has anybody installed one of the early classics fuel tanks in our trucks I bought one gently used from a member and there is no instructions. I messed with it a bit and nothing seems to land any where that makes sense
Any help would be great. |
#16 |
Re: building a mule
#17 |
60-66 Nut
Re: building a mule
Is it a '69-'72 blazer tank or is it a fabricated aluminum tank? What about it doesn't fit or line up?
#18 |
Re: building a mule
Its an Early classics fuel tanks supposed to fit our trucks problem is i have no idea how or where it is supposed to fit
#19 |
![]() Join Date: Aug 2004
Re: building a mule
Is this it?
https://www.earlyclassic.com/node/1394 And information on how to put it in. https://www.earlyclassic.com/node/1417
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#20 |
Re: building a mule
Nice thank you so much the link was perfect I didn't realize the frames were different k10 vs c10 that was my problem and they want me to remove the x member again thanks
#21 | |
Re: building a mule
#22 |
Re: building a mule
I have made some progress!!!
Got the fuel tank basically in needs some fine tuning but at least its not laying on the floor anymore!!! |
#23 |
Re: building a mule
I've got the front end kind of mocked up waiting for some new springs. I found an outfit that used to have them as a stock item but now they are special order 10 week lead time. which is fine for me because im back at sea until the end of november |
#24 |
Re: building a mule
also got some parts from CaptainFab motor maount set up he had laying around my wife stopped in to see him and pick up the parts. She said he was a very nice guy and that he had a "neat old truck" he was working on. Thanks Cap |
