Old 09-09-2016, 05:51 PM   #1
Jason7121
Jason7121's Avatar
Booster mounting
Does anyone know if booster brackets can be taken off and booster mounted directly to firewall without causing issues. I don't care for how far they stick out.
Jason7121 is offline   Reply With Quote
Old 09-10-2016, 02:47 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Booster mounting
I don't really see why you couldn't if your bracket unbolts from the booster. Mine is riveted so no luck for me there. Besides, The bracket gives just enough room for the clutch master to get in there right beside it. Post pics if you do. Im sure it will help clean up the engine bay a little.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-11-2016, 09:54 AM   #3
my56chevytruck
my56chevytruck's Avatar
I guess it depends on how it's made to be mounted. I've put mine directly to the firewall but that's how it is to be installed. hope this helps.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 09-11-2016, 11:10 AM   #4
Jason7121
Jason7121's Avatar
Wow nice firewall. Thanks for help guys.
Old 09-11-2016, 10:14 PM   #5
Jinxy81
Thinking the same thing on my build lol...that thing is wayyyyyyy out there!
Jinxy81 is offline   Reply With Quote
Old 09-16-2016, 01:38 AM   #6
crakarjax
crakarjax's Avatar
Go manual, no booster! I just switched to manual on my Chevelle and the MC cost me $9 shipped via warehouse deals. I can't give a straight up comparison because I went to discs in the front at the same time, but the pedal feel is pretty good and not as glitchy as power.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 09-16-2016, 02:00 AM   #7
Jason7121
Jason7121's Avatar
Thanks everyone for the ideas. My truck had manual brakes and was scary to stop at times. Think I got it all figured out just going to run the system in my picture.
Old 09-16-2016, 08:06 AM   #8
ERASER5
ERASER5's Avatar
The bracket has a link system mounted in it. Chevy used the same hole in the brake pedal for both manual and power brakes. The linkage made the necessary difference in pedal/push rod ratio.
You can mount the booster directly to the firewall (you may need to drill holes), but you really need to address the pedal ratio. Drilling a new hole in the pedal is the normal way to do it.
http://www.mpbrakes.com/
These guys have tech section with tons of important info.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
