03-15-2004, 11:45 PM | #1 |
What driveshaft needed?
Ok i have done some searches on here and haven't found exactly what i needed to know. OK i have a '71 long bed with a 350 and a 3 speed. going with newer 350 votec heads and TBI with 700r4. Is there a driveshaft i should start with thats one piece that would be close to being right,little or no modifications? out of a tahoe or sub?
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
03-16-2004, 08:21 PM | #2 |
no one knows?? has no one tried this with a differant shaft?
03-16-2004, 09:10 PM | #3 |
I know a couple of local guys who are trying 1 piece shafts in longbeds but so far no luck just broken parts and a vibration thats kinda like an old ridged frame Harley.
Rest in Peace Ed. Thanks for all the good times. |
03-17-2004, 01:45 AM | #4 |
Lovin' Life in Miss.!
Just curious but by not keep your 2 piece. I am putting in a rebuilt 700r4 when I get the down time. My local drive shaft shop said they would cut it down for me for lees than $50. I want to find another fron shaft so I can keep the turbo 350 as a spare.
The truck... you hear that? No really, you did hear that?!!! |
03-17-2004, 08:26 PM | #5 |
probably will keep the 2 piece was just curious if it was possible since it doesn't seem to people are having good luck with it. Thanks for the replys guys.
03-17-2004, 11:26 PM | #6 |
driveshaft
if you read past articles,i asked about the 1 piece,as i have a 2 piece also......when you change out the tranny with the the 700r4, trl it to a driveshaft specialist and let them take the proper measurements, but you will have to notch the chassis where the carriar bearing is...........3 1/2 aluminum shaft w/ 700 yoke and new u-joints in springfield, roughly 250 bucks, this is the setup i'm going with, 1 piece shaft and 700r4.........
racer6.. slightly burned out, but still smokin'.. |
03-17-2004, 11:34 PM | #7 |
Pretty sure the 700r4 and turbo 350 yoke are the same. The price quoted was for cutting down my old drive shaft and re-using the yoke. Why would the carrier bearing need to be moved?
03-19-2004, 01:46 AM | #8 |
ummm dont know if this helps, but i have a saginaw 4 speed and put a 1 piece in today out of a 73 chevy. it is a tad short, but i drove it to school at 65 and sounded GREAT. no more freaking carrier bearing rattle/squeak/noise. I was soooo happy
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
03-19-2004, 04:39 AM | #9 |
The 700R4 is the same length as a T350 with 9" tailshaft housing such as the ones found on '73-'81 longbed pickups. A shaft from one of those might be close. I think they're just shy of 71" from center to center of the U-joints.
03-20-2004, 12:24 PM | #10 |
Thanks Jim and Ben that will give me somewhere to look!
