09-07-2016, 03:42 PM | #1 |
Fuel pump and return question
I have a 2006 LS engine I put in my 65.
Here is the fuel pump I will be getting. http://www.speedwaymotors.com/LS1-Fu...it,103299.html Question is, on the return fuel line. Can I just block off the one from the engine since the pump kit and filter has a return on it? Or do I need to run the return on the engine back and block off the one on the filter?
1965 C10 Project |
09-07-2016, 03:57 PM | #2 |
Re: Fuel pump and return question
That's what I did on mine.on the rail return I got a pushlock to an fitting and put a an cap on it...works great..I'm running a walbro 255 and a vett filter/regulator... the reg dumps right back into the tank..only one line going to the fuel rail..
09-08-2016, 10:53 PM | #3 | |
I guess thats how I will pipe mine then.
1965 C10 Project |
09-09-2016, 12:00 AM | #4 |
No over pressure..the filter/reg prevents that..mine holds around 58 psi on the rails...there's a lot of LS swaps out there setup this same way..
09-26-2016, 11:18 AM | #5 |
Just make sure the inline pump is before the filter/regulator.
That regulator/filter setup is how all the vette's of a certain vintage came from the factory. |
