Old 10-05-2016, 11:41 PM   #1
JMD
JMD's Avatar
Brand new steering shaft, still lots of play
Hi all,
Working on my 67 k10 with power steering, I recently installed LMC's "tilt column install kit" which includes a rag joint, intermediate shaft, and a U-joint for the end of the column. The DD intermediate shaft slips in to the rag joint just fine and everything looks nice. However, the slip joint has a severe amount of play (severe for a brand new part anyway) that will translate into a few degrees of slop at the steering wheel. I don't see how I could have installed it wrong, is there something I'm missing? Does the sleeve need to be crushed a bit or maybe filled with silicone?
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 10-06-2016, 09:15 AM   #2
joeydurango
joeydurango's Avatar
Re: Brand new steering shaft, still lots of play
My guess is simply poor manufacturing tolerances on that part. The repro stuff out there - particularly from LMC, in my experience - isn't that great.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 10-06-2016, 09:38 AM   #3
JMD
JMD's Avatar
I feel the same about LMC, some stuff is great, some stuff is not...I should be able to put that sleeve in a press and crush it a little bit, right?
Old 10-06-2016, 10:11 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
? Are you sure that's where your play is coming from? That *looks* like a snug fit to me, are you sure the play isn't in your steering box?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-06-2016, 10:38 AM   #5
joeydurango
Good point... also double-check the intermediate shaft slip joint, as they can easily have some play.
Old 10-06-2016, 10:45 AM   #6
Shinysideup
Shinysideup's Avatar
I agree on that thought. A little play in all the joints can add up as well.
Shinysideup is offline   Reply With Quote
Old 10-06-2016, 02:06 PM   #7
JMD
JMD's Avatar
That's definitely where all the play is coming from, everything else is rock solid. Maybe I can find some metal shims to jam in there? What's the purpose of that slip joint anyway?
Old 10-06-2016, 02:19 PM   #8
indymachinist
The purpose of that slip joint is in case of a front end crash that needs to be able to compress to stop you from eating the steering wheel.
You could probably pinch it lightly in a vice to smash it a bit tighter... not sure that I would do that vs. just sending it back and getting a better one though.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 10-06-2016, 03:56 PM   #9
leddzepp
Moderator
leddzepp's Avatar
This.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 10-06-2016, 08:36 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
Heat it red hot, then quickly cool. Should snug it up a bit. Or crush/bend slightly. Or put a small tack weld on it.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-06-2016, 09:54 PM   #11
JMD
JMD's Avatar
Originally Posted by leddzepp View Post
This.
I promise you guys it's not the gear box or anything in the column, it's this slip joint If I grab each piece and twist in opposite directions the slop is very obvious and I can hear a loud "clunk". Plus the box and column are also brand new...
I guess tomorrow I'll put some heat on it and see if I can close that tolerance up. Seems ridiculous that I'm having to do this to new parts. I'd return it but I already cut the shaft down to size so I doubt they'd accept it.
Old 10-15-2016, 10:37 PM   #12
JMD
JMD's Avatar
Just an update, some heat and a vice did the trick!
