Old 11-13-2016, 06:50 PM   #1
Badoni
What is the max drop in the rear?
What is the max drop in the rear with out cutting the bed floor? 70 gmc, swb with leaf springs. I'm looking for 8, I did 3in drop spindles and 3in drop springs, 6 to 5 lug conversion and drum to disc conversion on the front today. I've bought a flip kit for the rear, but I'm out of time for the day to mess with the back. Thank you for any info.
Badoni is offline   Reply With Quote
Old 11-15-2016, 09:52 PM   #2
Badoni
Re: What is the max drop in the rear?
I'm I missing something here? Not one response..
Old 11-15-2016, 10:42 PM   #3
everettelane
everettelane's Avatar
Sure some one will chime in, i haven't messed with many leaf springs in these trucks just coil springs have you notched the rear frame?
everettelane is offline   Reply With Quote
Old 11-15-2016, 10:46 PM   #4
Badoni
Not yet, I'm trying to see if I can get away with not cutting the bed floor, I bought the flip kit. I don't know if I should get 3in block or the extended spring hanger?
Old 11-15-2016, 11:09 PM   #5
everettelane
Maybe if you measure from the top of the rear differential to the bed floor that should give you some idea on how much drop, but you do need to allow for some suspension travel so it doesn't bottom out every time you go over bumps.
Old 11-16-2016, 10:46 AM   #6
hewittca
hewittca's Avatar
Pretty much this. Alternatively, you could just measure from rear end tube to frame minus suspension travel and that is max drop on an unmodified frame with no worry of hitting the bed floor. If you choose to do a c-notch, that will give you about 2.5" more available space to drop. Bottomed out on a c-notch will put the top of the differential just touching the bottom of the bed floor.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 11-16-2016, 04:10 PM   #7
Mike C
Mike C's Avatar
I have a 69 short step with leaf springs. I did the DJM flip kit and it dropped the truck 7 1/4". I have almost 2" clearance above axle housing and the 1/4" urethane bump pad that came with the kit.
That is the practical limit IME. It is driveable without any real issues at that level but does bounce off the pad on sharp impacts.
My opinion is that 8" is too low without the C notch. 7 is doable.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-16-2016, 08:19 PM   #8
Badoni
Thank you for the info. I can do the notch, but I was hoping to not have to ge in to the bed floor.
Old 11-16-2016, 09:13 PM   #9
Mike C
Mike C's Avatar
I never measured on mine because the frame was the closest interference area, but that would be a deal killer for me. I'm pleased with the look and function of the truck at 7".
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-16-2016, 10:18 PM   #10
Badoni
I may not need 8. I did 6 in the front, so I'm just guessing.
Old 11-16-2016, 11:09 PM   #11
Badoni
I just want the truck to sit level.
Old 11-17-2016, 08:56 AM   #12
Shinysideup
Shinysideup's Avatar
...then go five in the front.
Shinysideup is offline   Reply With Quote
Old 11-17-2016, 12:05 PM   #13
Metaldoc
Metaldoc's Avatar
I went 7 in the rear and I did the frame notch and bed raise. I think 5-5.5 inches would be max without mods. My front has 2.5 spindles and 2 inch lowered springs.
Metaldoc is offline   Reply With Quote
Old 11-17-2016, 02:46 PM   #14
Badoni
I've already did the 3in drop spindles and 3in drop springs. I like where the front is sitting.
Old 11-17-2016, 04:14 PM   #15
STP67-72
STP67-72's Avatar
Is it drivable with the 6 in front. I have always heard 5. 5 1/2 max. Just curious how it rides.
STP67-72 is offline   Reply With Quote
Old 11-17-2016, 04:30 PM   #16
67ChevyRedneck
67ChevyRedneck's Avatar
I went with 6" rear springs and have plenty of clearance with shorter bump stops. I've yet to bottom it out.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-17-2016, 04:30 PM   #17
Metaldoc
Metaldoc's Avatar
It may hit the front inner fenders. My front tires are 29 inches tall and I should go down to 27 tall tire as it just rubs on a big bump.
Old 11-17-2016, 09:40 PM   #18
sKnNyPpY
sKnNyPpY's Avatar
Block only works with coil springs (I hear). Start with the flip and then see if you need the hangers. Here's my experience on a longbed. http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
