Inner fender firewall brackets
Hi again all,
Sorry for the newbie questions lately.. On the firewall, the inner fender brackets (90 degree ones, with 2 small bolts onto firewall and one large bolt onto inner fender).. on the driver side, the bracket is on the wheel side of the fender. On the passenger side, its on the engine bay side.. is this normal, or has someone put my truck back together a bit weird? ![]() I don't have a detailed factory shop manual for the truck (56 3100) unfortunately and can't find conclusive pics on google ![]() Thanks in advance |
Re: Inner fender firewall brackets
Just to add some more detail..
My issue is that the clutch mechanism is rubbing on the inner fender. Thats when i noticed the bracket is on the wheel side. The lower edge of the inner fender was angling in towards the frame rail, it was not parallel to the frame rail like the passenger side was. Curiousity got the better of me, and I undid the bracket, and flipped it, so the bracket is on the engine bay side. It gave me an instant inch or so of clearance around the clutch, and also the fender is now parallel to the frame rail to match the passenger side. Could my inner fender be a poor quality repo part that has got the mounting "bump/boss" (hard to describe) on the wrong side? Picture below is with the bracket now on the inside, which i believe is not factory... |
I once had a similar question ...
they're both mounted in the same way, so not mirrored : ![]() I thought it was wrong as well since the gaps between the frame and the inner fenders were different ... I ended up 'bending' the inner fender on the drivers side, to get the gaps even ... <update> the snip of my assembly manual doesn't show ... link here
'56 Chevy stepside shortbed SBC350 - TH350 12-bolt rear |
Thanks for the reply - agreed, my options are to bend the fender or mount it mirror image to the passenger side. I'll figure out which one works/looks better and go for it. From this though, I am assuming my inner fenders are not original! Judging by the rubbing marks on the clutch lever, its been like this for quite some time.. mega dodgy.
#5 | |
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
A320 Pilot/USAF Retired
I believe they are both mounted with the nut on the right as you look at them from the front.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
