12-22-2016, 06:13 PM | #1 |
Gas tank fill too slow
Filling add on gas tank takes forever...fuel back-up in line to tank shuts off station pump. There is a vent tube connected.
12-22-2016, 06:22 PM | #2 |
Re: Gas tank fill too slow
Is that a PVC elbow?
That elbow bend looks too sharp to flow well. Is the flexible rubber hose ribbed on the inside also? That could cause turbulence in the flow also.
53 Chevy Pickup |
12-22-2016, 06:30 PM | #3 |
I would change the 90 for a 45. If that hose is a radiator hose, be careful! Gas rots them out pretty quick and then you have trash in your tank, fuel lines and, eventually your carb!
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
12-22-2016, 06:38 PM | #4 |
Yes it is a PVC elbow (only thing I could find to fit my needs) and the ribbed hose is for fuel not a radiator hose, thought it has smooth inside but had better double check that. Tried 45 elbow but caused too much of an uphill in line to tank.
12-22-2016, 06:40 PM | #5 |
That pvc elbow has got to go. That is not safe. It is 100% your slow fueling issue anyways.
12-22-2016, 06:56 PM | #6 |
I agree the PVC should go...but what can I use to plumb this thing? Tried other metal elbows; exhaust tubing; copper fittings...nothing correct size.
12-22-2016, 07:02 PM | #7 |
All about them K’s
Could you modify a filler neck from another vehicle to make it work? On my 3100 I used an 80s k5 filler for my stepside fender mounted fuel fill.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-22-2016, 09:01 PM | #8 |
I'd try an exhaust shop, find the size you need and have it bent or welded to fit your application. Good luck
12-22-2016, 09:23 PM | #9 |
is the vent line clear?
12-23-2016, 10:21 AM | #10 |
My thought also , and a brass or copper elbow
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
12-23-2016, 10:24 AM | #11 |
i had a custom gas neck made from muffler tubing... i agree with old51sedan !!!
12-23-2016, 01:04 PM | #12 |
Check that the vent line has no low spots in it to cause it to hold fuel, thus making it useless. I had this problem on anold motorhome i had a while back. Good luck.
Andy |
12-23-2016, 05:33 PM | #13 |
If this is a Blazer tank, there should be another vent port on the passenger side. Connect a hose with a rollover vent to it and stick it up in the bed side. It will allow air to flow out when filling and air to flow in when in use. I actually had to put two of these vents in to get mine to fill properly, one on each side of the tank.
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
12-23-2016, 05:39 PM | #14 |
Also agree on the exhaust pipe. I have used this company for some hard to find things.
http://www.fillernecksupply.com/90-d...eatured&page=1
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
12-23-2016, 05:42 PM | #15 |
Oh and forgot to say make sure you don't have any kinks in the tubes. Kind of looks like the rubber hose has a bit of a kink in it.
12-26-2016, 02:07 PM | #16 |
Thanks for all the help and suggestions for this problem, as soon as fuel level drops I'll take truck to local exhaust shop to have them make up new fill tube. Just curious as to why using PVC elbow is such a bad thing, not like it is submerged in fuel all the time...we do use plastic gas cans.
12-26-2016, 02:41 PM | #17 |
It's a different type of plastic. Just like rubber lines different plastics are engineered to work with different chemicals. It doesn't have to be in direct contact with the fuel. Many times the vapors are just as hard on parts as the chemical is.
12-30-2016, 05:12 PM | #18 |
Before and After
I moved my tank last year, I was told by an old timer to get as much vent as possible to avoid the backing up of fuel when you fill the tank. My tank had 2 extra lines so I used them both as vents. I ran them all the way up to the fill cap area.
To change your 90 degree PVC, go to a parts store ( I went to Acklands-Grainger) and get them to look up 90 degree fuel fill hose. They are surprisingly easy to find. the first place i checked had 4 in stock. in two different sizes. They run around $30 CAD, peace of mind.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
12-30-2016, 06:00 PM | #19 |
I do have a capped off elbow on top of tank I could use for another vent line, will use that and still have muffler shop rig up something for fill tube. Thanks!
01-20-2017, 07:19 PM | #20 |
May have problem resolved, local muffler shop bent a pipe for me and welded it.
01-22-2017, 09:25 PM | #21 |
Back together.
01-22-2017, 09:27 PM | #22 |
That's much better looking! How's the flow?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-22-2017, 11:19 PM | #23 |
Hey everyone.... I have been in the plastics field for over 30 years, and can tell you why not to use PVC fittings. PVC has extremely poor chemical resistance, (why it's easy to glue) and gasoline will absolutely destroy it in no time. The only plastics good for fuel lines are nylon. HDPE, used in gas tanks, will also work. Most new fuel lines are nylon, and tanks are blow molded PE. Some issues with PE and vapor barriers, so lots of new tanks are multi layer. Your hose should be Viton rubber if you're ever going to have any ethanol fuel (even 5 or 10%) as the ethanol will attack EPDM rubber as well.
Glad you got one bent at the muffler shop, that's always my go-to move for fuel neck issues. There are lots of chemical resistance charts on-line for plastic and rubber. You can search simply with those criteria on google, "chemical resistance chart for plastics / or rubber"... Thanks for listening. |
01-23-2017, 06:34 PM | #24 |
The flow is 10 times better, not perfect but much better, now able to hold the nozzle without it clicking off.
01-24-2017, 02:24 AM | #25 | |
Maybe it's the photo...kinda hard to tell, but it looks like the hose between your new filler, and the tank is slightly "uphill"? Like the end of your filler neck is lower than the tank opening. If so, I imagine that would slow the flow somewhat.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
