Old 02-26-2018, 03:31 AM   #1
Spf79
Spf79's Avatar
Re: 1972 Build thread.
Originally Posted by SeventyOne View Post
SPF79 - where can i get the spacers that go on the top of the front shock mount?
Those came with the truck, stock item?... I think? Lets say this, they were there when I took it apart. I had actually forgotten about them and then had to look all over the place once I found myself installing new shocks.
I have seen similar spacers at an Ace hardware, If you google bolt spacer a lot comes up. Other places to look... Grainger industrial supply, and Fastenal. Let me know if you need any measurements for those little fellas.
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 02-27-2018, 08:21 PM   #2
SeventyOne
I had custom aluminum spacers made because i dont know what happened to mine when i took my truck apart. It's always bugged me that I wasnt using the right part though. But maybe a spacer is a spacer is a spacer...
SeventyOne is offline   Reply With Quote
Old 02-27-2018, 11:45 PM   #3
Spf79
Spf79's Avatar
Spacer is a spacer buddy. I had stacked up washers in there for a bit until I found mine. Lol.
Old 02-26-2018, 03:08 AM   #4
Spf79
Spf79's Avatar
Originally Posted by DeadheadNM View Post
Looks excellent!
Thank you sir!
Old 02-26-2018, 11:11 AM   #5
simicrintz
Really coming along nicely!!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 02-26-2018, 08:10 PM   #6
jaros44sr
jaros44sr's Avatar
Nice build so far!! I like the touch of red around all the black and grey. Hope you don't mind me stealing it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 02-27-2018, 03:04 AM   #7
Spf79
Spf79's Avatar
Why thank you sir! I don't mind at all!!
Old 02-27-2018, 03:08 AM   #8
Spf79
Spf79's Avatar
Thank you!!
Old 02-28-2018, 04:48 AM   #9
Spf79
Spf79's Avatar
Installed my extra deep aluminum transmission pan tonight. With the installation came another item added to the "I didn't think about that" list...
I think I will have to change the front drive line around since it looks like my new pan may not allow for the big CV joint to clear. (Sad face)
I still need to get the drivelines altered... so there is my silver lining.
I guess I will have to hold the CV joint in place and see what it looks like later this week.
Old 02-28-2018, 11:10 AM   #10
simicrintz
So here is my very important question: How are you going to keep all that beautiful work clean once you are driving your rig?!
-Bruce
1971 K5 Blazer 4WD
Old 02-28-2018, 01:42 PM   #11
SeventyOne
I'm dealing with custom shafts right now. What trans are you running?
I've got a 700r4 (moved the engine forward and left the Tcase in the stock location) and I know with a stock pan and a CV it's going to be maybe .25" clearance. I think a deep pan isnt an option for my set up....I'll be watching this.
I'm also running 6" alcan springs - whats your lift?
Old 02-28-2018, 04:18 PM   #12
Spf79
Spf79's Avatar
I was searching on another off road forum and saw that a guy used a long yoke set up making the drive shaft small through that area... running it without a CV... not sure this is a good option for me. Another fella ditched the aluminium pan for a chrome pan and then beat it in with a soft mallet... not sure that is in the cards for me either... I plan on heading down to the driveline guys tomorrow to pick some brains. My lift is a bit of a mash up... 4" soft ride up front, and then Sky Jacker's version of the 4" soft ride in the rear. I added in the ORD 1" add-a-leafs at all corners to get me at 5" overall.
I will let you know what they say.
Old 02-28-2018, 04:26 PM   #13
SeventyOne
700r4 as well?
I swear when i did this research years ago (my project is a looooong one) i determined a CV joint with a stock pan cleared...now im unsure.
Old 02-28-2018, 04:05 PM   #14
Spf79
Spf79's Avatar
Well sir, in lush green western Washington state I will have about 9 months a year to detail it out for the summertime cruising. Lol.
I don't plan on running a top, strictly using this thing for summer play time. I plan on getting down to the dunes with it maybe once a year and that will be about as dirty as it gets.
Remember, I have issues.
Old 03-08-2018, 02:03 AM   #15
Spf79
Spf79's Avatar
My pulley and bracket set up arrived today.
Install actually went smooth.
I should see my drivelines next week.
The front driveline will not have a CV, looks like I will run a 2" shaft. That should leave me plenty of room between the driveline and tranny pan.
Sadly the driver side header will not fit. I have to notch the frame a bit, but even with that - the collector points into the spring shackle making that a real tight fit. Not sure what my next move is... I don't want to cut into the frame just to see what I thought was a tight fit become a not fitting situation.
With that said, has anyone used or looked at Sanderson exhaust manifolds before?
I may go this route and use these headers in another project down the road. See the picture I pulled from another site... Thoughts?
I will post some picks of the drivelines once I pick them up and get them installed.
Old 03-08-2018, 02:10 AM   #16
bbrriiaann1973
I had the same problem with the headman headers I installed. Had to notch the frame. No big deal. I am never going to sell it so I don't have to ever explain why I did it
That was about 12 years ago and no problems with frame
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 03-08-2018, 02:16 AM   #17
Spf79
Spf79's Avatar
Were yours mid length or full drag length? I'm not worried about notching the frame, just worried that once I do I will be in the same situation with a header that is now not useable do to the shackle location. Lol
Old 03-08-2018, 02:25 AM   #18
bbrriiaann1973
Full
Brian Ritter
Old 03-09-2018, 11:15 PM   #19
simicrintz
I run the Sanderson block huggers on my Jeepster. Quality header and great fit!
-Bruce
1971 K5 Blazer 4WD
Old 03-09-2018, 11:31 PM   #20
Spf79
Spf79's Avatar
Awesome! You have any pics?
Are you running the v6?
Old 03-10-2018, 02:02 AM   #21
simicrintz
I can take some (will probably post crooked!). I had these on the stock 225 and put them on the 252 (4.1) that is in there now; worked great and fit both. I know the engine is dirty (took the Jeepster to Moab a while back and have not cleaned it since) but you should get the idea. Let me see what I can post tomorrow.....
-Bruce
1971 K5 Blazer 4WD
Old 03-10-2018, 02:07 AM   #22
Spf79
Spf79's Avatar
Thank you sir!!!
Old 12-13-2019, 03:00 AM   #23
Spf79
Spf79's Avatar
Update.
I've been away for a while, lost in the land of home improvement for the Wife.
Finally... I'm getting back to fun stuff.
I am getting my Blazer body back from the blaster this weekend in a light primer. I plan on moving my body and misc body items to my boss's house in order to start the body and paint process. Yay!
I'll update once I get some progress.
Merry Christmas!
Old 12-13-2019, 08:25 PM   #24
7D2N
7D2N's Avatar
It looks to be in really good condition coming from the blaster. If you don't have to fight rust you are almost finished. I will be following along.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 12-14-2019, 02:57 AM   #25
Spf79
Spf79's Avatar
I was immensely pleased with the condition of the body in regard to rust. My friend is having his 76 F150 being done at the same time, he has not been as lucky. Lol, he had a bullet hole in his cab as well... it made me laugh, if it is not rust, or dents - then it is bullet holes. Ha!
