Old 01-29-2017, 11:59 AM   #1
dme922
dme922's Avatar
Door glass not sealing
I put all new glass and felt in my doors and my windows are lacking about 1/8 to a 1/4 of an inch from sealing at the top. I already checked to see if the window frame was hitting the fuzzies/anti rattle seals and it is clearing just fine. Any suggestions?
dme922 is offline   Reply With Quote
Old 01-29-2017, 09:05 PM   #2
chewychevy67
Re: Door glass not sealing
I got my new glass to and it is quite a bit thinner than the original glass. I have not installed any of it yet. I'm going to follow this thread
chewychevy67 is offline   Reply With Quote
Old 01-29-2017, 09:09 PM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: Door glass not sealing
There is a metal tab right where the vent windows attach ( holds both halves of the door together) these tabs often break or rust through allowing the door to separate in this area that's why only '72 trucks have the dimple/screw to hold these areas together. Here's a picture. I tried to find a picture showing the tab but haven't found one just yet. This is probably the issue your having.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 02-07-2017, 11:16 AM   #4
dme922
dme922's Avatar
My doors are new but i appreaciate the help. Any other ideas??
Old 02-07-2017, 12:21 PM   #5
Hart_Rod
Hart_Rod's Avatar
Ben
Wonder how hard it would be to add the screw on non-72 doors?
Hart_Rod is offline   Reply With Quote
Old 02-07-2017, 12:30 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Are your window regulators new too? There is no reason that the windows shouldn't roll up higher than the top of the door if nothing is hitting or binding. Are you sure that the replacement glass isn't shorter than the originals?
LockDoc
Leon
Old 02-07-2017, 12:33 PM   #7
LockDoc
LockDoc's Avatar
Rob, You would have to weld a tab to the inside of the outside door skin for the screw to tap into.
LockDoc
Leon
Old 02-07-2017, 04:09 PM   #8
Hart_Rod
Hart_Rod's Avatar
When I put new door channels in my last build, the windows were pretty hard to roll up that last quarter of an inch. I ended up putting a little lithium grease on in the channels.
LockDoc
Thanks Doc. Would you happen to have a picture of the tab?
Old 02-07-2017, 04:20 PM   #9
dme922
dme922's Avatar
I used the original regulators. I measured both the old and new glass and they measure the same. Is it common for the glass channel to come above the anti rattle felt?
Old 02-07-2017, 04:21 PM   #10
Hart_Rod
Hart_Rod's Avatar
Not above, but should be close. Can you post pictures?
Old 02-07-2017, 04:26 PM   #11
dme922
dme922's Avatar
I will tomorrow. If the felt that goes in the door channel was a bit thicker it would be fine. I used repops which a lot of people seem to like.
Old 02-07-2017, 05:27 PM   #12
dme922
dme922's Avatar
Just another note to add my original doors had some metal clips in the door channel under the felt. What were they for
Old 02-07-2017, 10:54 PM   #13
LockDoc
LockDoc's Avatar
I know I took one and posted it at one time but I can't find it on here and I can't find it on my computer. I will take another tomorrow if I still have a stripped '72 door out there.
LockDoc
Leon
Old 02-07-2017, 10:57 PM   #14
dme922
dme922's Avatar
I have the metal clips but i did not know what purpose they served
Old 02-07-2017, 11:10 PM   #15
LockDoc
LockDoc's Avatar
I wonder if they might have been for the door ventshades that are at the top of the window openings on some trucks. I know there are clips that hold some of them on but I don't know what they look like....
LockDoc
Leon
Old 02-08-2017, 09:05 AM   #16
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
FWIW... I had replacement glass for my doors that was reproduction and when I layed it over my original glass, the repop glass was about 1/8 to 1/4" smaller at the top rear quarter. I ended up searching out OEM new old stock to solve that problem.
Tom Vogel is offline   Reply With Quote
Old 02-08-2017, 01:37 PM   #17
dme922
dme922's Avatar
Thanks. I am taking the glass out today. How hard was it to find new oem glass?
Old 02-08-2017, 04:05 PM   #18
randy500
Used glass should be easy to find, post want to buy in the parts section. The glass may not be going all the way up due to the run channel on the top back and inside the door. There is a small angle transition on the back inside door run channel and sometimes its not all the way pushed into the channel, this is just below the window opening inside the door at the rear.
randy500 is offline   Reply With Quote
Old 02-08-2017, 05:28 PM   #19
dme922
dme922's Avatar
Here is a pic with the original glass on top of the new. It is a bit different in that corner.
Old 02-09-2017, 10:35 AM   #20
dme922
dme922's Avatar
Could i get some pics of how your glass is set in the sash channell? I would like to compare to the placement of mine.
Old 02-09-2017, 10:40 AM   #21
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTHere is a pic with the original glass on top of the new. It is a bit different in that corner.[/QUOTE]
That is exactly what I am talking about. Call Wes at Classic Heart beat.He can help you. http://www.classicheartbeat.com/years.htm
Old 02-09-2017, 10:42 AM   #22
dme922
dme922's Avatar
Thanks. Where did you buy the one you had trouble with?
Old 02-13-2017, 09:00 AM   #23
Hart_Rod
Hart_Rod's Avatar
LockDoc
LockDoc - I took a picture of my doors (they are aftermarket doors). Is this the tab you were talking about?
Old 02-13-2017, 12:09 PM   #24
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I wish I could remember, but I can't. I tossed them and was able to get the OEM from Wes.
Old 02-13-2017, 04:23 PM   #25
dme922
dme922's Avatar
Was the glass you got from Wes made by oer?
