Old 03-11-2017, 09:54 PM   #1
72tutone
Tilt Gurus need some help
I just scored a tilt column here from an actual 71 pickup. Ive begun tearing into it to swap some parts around.
I'm encountering alot of resistance in the turn signal switch. Ive removed the three retaining screws. But when I pull the left side where Ive pointed isnt coming out. The side Im pointing on is actually on the left side when looking at it. Not sure why the pic didnt rotate
What am I missing here?
Thanks!
72tutone is offline   Reply With Quote
Old 03-11-2017, 10:02 PM   #2
davischevy
davischevy's Avatar
Re: Tilt Gurus need some help
The wiring harness is holding it. Push on the harness from the bottom, and keep working it up.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-11-2017, 10:03 PM   #3
Zeroman
Zeroman's Avatar
I believe you have to remove the housing cover to remove that.
And to remove the cover you need a special puller.
You can search the forum to download the service manual to review the procedure.
Zeroman is offline   Reply With Quote
Old 03-11-2017, 10:54 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Be very careful of the bearings. One of them is not available and the plastic cage is usually very brittle.....
LockDoc
Leon
Old 03-11-2017, 11:19 PM   #5
72tutone
Well pushing in the wires from the column is definitely not it.
Any other ideas? I will check the service manual but I'm sure I'm missing something
Old 03-12-2017, 10:35 AM   #6
72tutone
You are correct there is a puller for the housing. However, I'm just trying to get the turn signal switch out. The puller comes later
Old 03-12-2017, 07:45 PM   #7
72tutone
Making progress on disassembling my tilt column. How do I remove the tilt lever?
I dont see anything on the outside to get this removed. I read to knock off the cover to expose the bearing housing. But I cant do this with the shift lever in place.
Old 03-12-2017, 08:41 PM   #8
davischevy
davischevy's Avatar
It screws out.
See the two flats near the housing.
other Larry
Old 03-12-2017, 08:47 PM   #9
72tutone
Originally Posted by davischevy View Post
It screws out.
The flats meaning the openings in the housing? To the left of the tilt lever is the Prndl indicator. Was that was you were referring to? Sorry I'm not at home to take a look
Old 03-12-2017, 08:49 PM   #10
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
You have been offered some excellent advice from knowledgeable persons.
If you choose to not read the instructions quit typing and start hammering.
CaptRMW is offline   Reply With Quote
Old 03-12-2017, 09:06 PM   #11
72tutone
That was from an earlier post which I replied that I removed it. This is the tilt lever. You can't just remove the housing and the cover with the tilt lever just sitting in there
Believe me... I don't take any comment on here with a grain of salt. That's why I ask on the first place. Trying to be smart like the rest
Old 03-12-2017, 09:29 PM   #12
Dustytrix
Tilt just unscrews to the left. In case thats still in your way.
Dustytrix is offline   Reply With Quote
Old 03-12-2017, 09:52 PM   #13
72tutone
Ok I just check to the left of the tilt. I'm sorry I still don't see where it unscrews from
Old 03-12-2017, 10:11 PM   #14
Zeroman
Zeroman's Avatar
unscrew here.....
Old 03-12-2017, 10:13 PM   #15
Zeroman
Zeroman's Avatar
Here is the thread with the PDF Service Manuals for download
http://67-72chevytrucks.com/vboard/s....php?p=5781194
Old 03-12-2017, 10:21 PM   #16
custom10nut
custom10nut's Avatar
Sub'd for the links page
custom10nut is offline   Reply With Quote
Old 03-12-2017, 10:30 PM   #17
davischevy
davischevy's Avatar
unscrew here.....
Thank you.
other Larry
Old 03-12-2017, 11:58 PM   #18
leddzepp
Moderator
leddzepp's Avatar
Think of the tilt lever as a bolt, and just twist it counterclockwise. It unscrews easily.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-13-2017, 07:20 AM   #19
72tutone
This pic is looking directly down the tilt lever. If there is a screw in here I need new glasses.
Old 03-13-2017, 07:23 AM   #20
72tutone
OMG. It's the simple things in life. Thank you everyone. I was looking for a screw and didn't realize the actual lever was the actual item to loosen. Oy ve. Shoot me now
Old 03-13-2017, 08:56 AM   #21
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Do yourself a huge favor. Box up the column and take it to 70 shortfleet in St.Peters,Mo. save yourself a lot of grief later as you are having problems with the simple part and the difficult part is yet to come.
Old 03-13-2017, 12:37 PM   #22
davischevy
davischevy's Avatar
I was thinking the same thing.
other Larry
Old 03-13-2017, 12:39 PM   #23
davischevy
davischevy's Avatar
How dare you interject logic into this conversation.
other Larry
Old 03-14-2017, 02:27 PM   #24
72tutone
After the overwhelming positive comments, Ive decided to forge forward in this quest of disassembly. I dislike not knowing how to do things, so Ive taken it on myself as a learning project.
Ive removed everything up to the point of removing the bearing assembly housing.
This piece was laying in the bottom of the bowl.
Ive looked at the exploded diagram and I dont see anything anywhere as to describe what this is. I dont think its the shoe release as the tilt is working fine.
Could this be the plate in the support assembly? I havent even made it into that yet.
Old 03-14-2017, 04:12 PM   #25
randy500
You almost had me stumped...I think that is the plate that slides in a slot below where the tilt pointer sits, supports the tilt pointer inside the bulb and is swaged into the bowl, you can epoxy it back in.
randy500 is offline   Reply With Quote
