Old 04-02-2004, 05:34 PM   #1
shavedchevy
shavedchevy's Avatar
rough idle at startup
here's the deal..... I've got a stock 1986 350 with a lot of miles on it, when I start it up in the morning (after sitting for more than 5 hours) the thing just doesn't want to stay running, so I give it a couple quick revs and it fixes that problem.
Then when I leave it for about 5 or so minutes it gradually builds its idle up to about 1750RPM ( which is just roaring with my mufflers) so I rev it up once and it brings tthe idle back down around the 750 RPM mark about where it should be. Then all is fine
My question is, was thi normal with this style of engine or is there some kind of quick fix I could do to prevent this. It's really not all that bad when it does it when it's cold out but when its warm out I do't want it to run like this.
Dennis
shavedchevy is offline   Reply With Quote
Old 04-02-2004, 05:54 PM   #2
TIMSPEED
TIMSPEED's Avatar
Sounds like a normal functioning choke...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-03-2004, 12:56 AM   #3
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
I have a E-brock 1406 and mine was acting the same way. I took apart the choke and found that it was gummed up and not working properly. After cleaning it up a bit, it fixed alot of those issues. It not perfect but its better.
Hope this helps.
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
