Old 04-01-2017, 11:41 PM   #1
saxart
saxart's Avatar
Is Chevy engine paint color the same as Hugger Orange?
I'm going to be painting my crate engine with an enamel out of a gun (with hardener) Is the orange for our engines the same as Hugger Orange?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 04-01-2017, 11:47 PM   #2
jocko
jocko's Avatar
Re: Is Chevy engine paint color the same as Hugger Orange?
no
Old 04-02-2017, 01:31 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Here's some info. I just found, guy looking for "Chevy Orange Engine"..........Can't speak for years though:
My father is an NCRS judge, and we have done extensive resorations on many corvettes.
I can tell you for a fact the absolute closest match to the factory color is in an aerosol.
The absolute best match to Chevrolet Orange is made by Plasti-kote.
You can go on plasti-kote.com and punch in your zip code..and it will bring up the closest location to whos selling it.
Heres a link to the product website:
Here's another link: The Plastikote is popular: http://www.camaros.net/forums/33-cam...ine-paint.html
http://autobodystore.com/forum/showt...ine-paint-code
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 04-02-2017, 08:07 AM   #4
No, not exactly, but probably close enough for most to not notice. Hugger Orange is also called Red Orange.
I don't see any benefit to using spray equipment vs spray bomb in this case. The engine paint is come seriously tough paint to be from a can. It has ceramic in it and is formulated for precisely this application...hot metal exposed to petroleum products. I've used Plasti-Kote low gloss black for chassis paint and it holds up great. Very tough durable stuff. I understand using spray equipt/mixed paint to get a custom color, but if wanting the engine to be the factory color I would use spray bomb engine paint.
Old 04-02-2017, 09:17 AM   #5
saxart
saxart's Avatar
Thanks for all of the thoughts so far, I appreciate it.
My experience with rattle can vs gun-paint is that you can add a hardener to gun paint and it becomes a much more durable surface against things like gasoline leaks and chips from physical damage. I'm guessing Chevy just used a regular automotive paint when they were hosing down engines prior to putting them in our trucks originally.
Thoughts?
Old 04-02-2017, 09:49 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
As an aside, I've heard that GMC v8 motors were painted a slightly different but similar color - more red than orange. Can anyone confirm this?
Old 04-02-2017, 10:01 AM   #7
Thoughts?
That's what I'm saying. The engine paint is formulated specifically for this use, so it is the ideal mix for hardness, oil/gas resistance, etc. I'm sure the factory paint was nowhere near the quality of this Plasti-Kote engine enamel. They now tout "with ceramic" on the cans now. An engine isn't so big you can't put a quality job on it using spray cans. I just don't see any negatives at all. Prep is the most important thing in making whatever is used to stay on.
Old 04-02-2017, 10:03 AM   #8
saxart
saxart's Avatar
So your saying a rattle can engine paint will stand up to gas leaks? Every time I've seen rattle can paint get gasoline spilled on it, it wasn't pretty.
Old 04-02-2017, 11:06 AM   #9
Bigdav160
Bigdav160's Avatar
I've painted several engines bc/cc with the paint I was painting on the car.
It held up great and much easier to clean than spray can paint.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-02-2017, 11:49 AM   #10
Z10
Z10's Avatar
Red Orange is not the same as Hugger. Hugger is a lighter shade. For example, my truck is Red Orange, the stripes on my 69 Camaro are Hugger Orange. Here's a couple of pics, but a bit hard to tell. But when the car and truck are sitting next to each other, you can tell.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-02-2017, 12:20 PM   #11
davepl
davepl's Avatar
I used PPG Acrylic Enamel; it's the best choice. It's incredibly hard and retains its high gloss for years without a clear coat. Of course you must prime the bare metal with DP90LF catalyzed primer or similar first.
The Acrylic Enamic is being phased out and still contains lead, so get it while you can. I got mine at Wesco, but had to drive around to several to find it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-02-2017, 12:24 PM   #12
davepl
davepl's Avatar
Check this out, a 1969 Bonneville I found that was painted hugger orange from the factory, but it sure wasn't an option on the big Bonneville, so the actual Ditzler/PPG paint code is right on the trim tag. Not something I'd seen before!
Old 04-02-2017, 10:31 PM   #13
saxart
saxart's Avatar
Great comparison! Now to figure out which one should go on an engine.
Old 04-02-2017, 10:55 PM   #14
1972RedNeck
1972RedNeck's Avatar
I have never heard this and can't confirm it, but I have always thought GMC V6's look more red than Chevy engines.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 04-02-2017, 11:08 PM   #15
I'm not saying body paint won't hold up, I'm saying spray bomb engine enamel will. Not all spray paint is the same. This is paint made for engines. You can put all the spray bomb on you want. It's only less paint if you put less paint on. Mine are juicy smooth and clean up just as good as any other paint. Use what you want, same with others. I know what I'm saying and just wanted to help out.
Hugger Orange and Red Orange actually are the same color on '72 GM Trucks. If it's different on your Camaro it's either because car colors vary from trucks or your paint mixes aren't the best example of accurate mixes. PPG uses a different code for Hugger Orange '69 cars and '72 trucks. And they call it Hugger Orange but my '72 K/20 Cheyenne Super had Red Orange on the SPID
What's in a name? On that chart both Chevy Trucks and Internationals had Flame Red and those aren't the same color
Old 04-02-2017, 11:26 PM   #16
El Dorado Jim
I painted my engine with rattle cans, VHT brand in chevy orange....there is also a chevy red-orange paint, not sure when that was used, but I love the original chevy orange....seems to be good paint from what others on here have said...I got mine at autozone. Soooo Art you are getting ready to put your engine in?
El Dorado Jim is offline   Reply With Quote
Old 04-02-2017, 11:32 PM   #17
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Many years ago I had done code 72 mixed up into some aerosol cans to do just this.
However, after painting my block, I can say that it seemed a bit too bright.
I liked the look but I'll assume that a small bit more red in the 72 might have achieved the result I wanted.
That color is still on my 396 block from my Camaro.
I'd post a pic of it but it may take some time to post it.
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 04-03-2017, 02:03 AM   #18
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've heard that too, but I have no data on GMC paint codes, or if it's available from VHT or DupliColor.
Old 04-03-2017, 09:00 AM   #19
geezer#99
geezer#99's Avatar
Neither one!!
If you want your motor to look chevy orange after a summers worth of use then paint it ford engine red. The red fades to a more chevy orange. The chevy orange gets a yellow tint to it.
geezer#99 is online now   Reply With Quote
Old 04-03-2017, 11:38 AM   #20
davepl
davepl's Avatar
Originally Posted by geezer#99 View Post
Neither one!!
If you paint it with Delron Acrylic Enamel it'll still be orange when it's Geezer's age. But it's about $300 in materials and you wind up with enough to paint 5 motors, let alone the gun. Still looks wet and shiny and there's no clear coat on top of it either. Just good old leaded paint from the 1960s, and it's harder to find every year. This was 3-4 years ago and I had to hunt stores for it then!
Old 04-03-2017, 11:54 AM   #21
geezer#99
geezer#99's Avatar
It's not 'age' dave, it's 'wisdom'!!
While your motor looks great, not everybody will buy all the paint and equipment to paint it when it's easier to just use a rattle can of whichever they want.
Old 04-03-2017, 12:04 PM   #22
davepl
davepl's Avatar
I've done plenty of "rattle-can-rebuilds" in my time too :-)
Old 04-03-2017, 01:28 PM   #23
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Putting $300.00 worth of paint on a $1300.00 engine is like putting a $50,000.00 saddle on a $20.00 horse. I won't hold my breath waiting for the Bloomington Gold Gurus with their color swatches to write me up for the wrong color on my engine. Art go get the VHT engine rattle can paint and hurry up or the warranty will be up before you get to drive it.
CaptRMW is offline   Reply With Quote
Old 04-03-2017, 01:59 PM   #24
djeCST
djeCST's Avatar
This is a great topic that always guarantees a lively discussion. I love how passionate Chevy owners are about the color of their engines.
Unless you're going for a 100 point restoration, pick the one you like and go for it. Most people can't tell the difference anyway.....
Let's see some photos once you get it all painted up.
Dennis
'70 CST/10
'55 Bel Air wagon
djeCST is offline   Reply With Quote
Old 04-03-2017, 02:23 PM   #25
davepl
davepl's Avatar
I don't care what the Bloomington Gold guys do or think. I have my own quality standards. Yours are different.
