Old 05-03-2017, 05:35 PM   #1
Lookin4the1
rear end pinion angle issues
I took my 49 gmc on its maiden voyage today to the muffler shop. on the way back i noticed under acceleration the rear end is literally rotating up to 30 degrees from where it is at stopped. needless to say this scared me to death. I will explain what i've done so far below.
1995 s10 frame
3" Belltech lowering leaf springs
1.5" home made set back plates to center the rear tires in the wheel well.
blisten(sp) drop shocks.
i might need pinion angle shim? whatever it is is scary as hell driving it and it starts vibrating pretty violently around 30mph.
Lookin4the1 is offline   Reply With Quote
Old 05-03-2017, 07:44 PM   #2
tinydb84
tinydb84's Avatar
Re: rear end pinion angle issues
Is it moving back and forth of just stuck there? Did you weld the perches on?
David
Instagram: myfabguy
Old 05-03-2017, 07:56 PM   #3
racecougar
racecougar's Avatar
Right, if it's actually rotating back and forth, shims aren't the answer. Are the leaf springs wrapping, is the housing rotating on the tubes, or are the tubes rotating on the spring pads?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 05-03-2017, 08:20 PM   #4
Lookin4the1
the tubes are rotating on the spring pads. i've got everything bolted down tight. If by chance it is the leaf spring wrapping. i'll have that fixed in a few days. i have a set of cal tracs I'm putting on just to be safe
Old 05-03-2017, 08:30 PM   #5
PGSigns
PGSigns's Avatar
The tubes have to be welded to the spring pads. Also the blocks need to be a bit wider than the spring pads. How much is the rear offset from the locating pin? That can have a effect on the spring.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-03-2017, 08:40 PM   #6
Lookin4the1
right around 1.25 inches. on the spring pad. i plan to eliminate any chance of spring wrap with these caltracs
Old 05-03-2017, 09:15 PM   #7
racecougar
racecougar's Avatar
To reiterate: The spring pads must be welded to the tubes.
Old 05-03-2017, 09:16 PM   #8
mongocanfly
mongocanfly's Avatar
Pgsign right..you gotta weld the spring pads to the axle tube..don't rely on bolts to hold it..if its moving that much I'm suprised you havnt broke somethimg yet..30 degrees is pretty drastic..make sure your pinion angle matches your trans angle..usually around 3 degrees
Old 05-04-2017, 12:58 AM   #9
Lookin4the1
i apologize for my idiocracy, i'll post an image so you guys can clear it up for me. I think you're telling me to weld A to B in this photo?
Old 05-04-2017, 12:59 AM   #10
Lookin4the1
the perch is secured to the axle tube because it came stock that way. i have no clue why this thing is rotating now.
Old 05-04-2017, 01:09 AM   #11
mongocanfly
The way your post #4 read it sounded different.. in your picture the perch lS welded to the axle tube..that's ok .don't weld a to b ..from what I see there should be no way that differential will rotate 30 degrees as long as the perches (a) is welded to the axle tube..if it would rotate 30 degrees i would think your u-joints would be broke..if it is 30 degrees then you've got a serious problem elsewhere
Old 05-04-2017, 01:15 AM   #12
Lookin4the1
yeah i'll do some more investigating but I'm pretty sure i have a serious problem. problem is it only does it when accelerating so its hard to actually see my issue.
Old 05-04-2017, 01:21 AM   #13
mongocanfly
Hang a gopro underneath..
Old 05-04-2017, 06:53 AM   #14
PGSigns
PGSigns's Avatar
Post pictures of your entire setup if you can. We may be able to see something amiss.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-04-2017, 07:55 AM   #15
Keith Seymore
Keith Seymore's Avatar
The pinion nose of the axle moves up and down quite a bit under acceleration and deceleration, due to leaf spring wind up.
I had an opportunity to drive my '87 pickup without the box on it and was surprised at how much motion there was going on back there.
Assuming that the perches are welded to the tube it could very well be normal.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-04-2017, 01:43 PM   #16
mongocanfly
This is just a thought..keith is right that there's a lot of movement in the rear..but..does your driveshaft have a slip joint in it? If so do you have the u-joints in time? If not it will shake your teeth out..also, check for bad u-joints
Old 05-04-2017, 10:55 PM   #17
Lookin4the1
drive shaft is all new, it is 2 piece from the s10. all the joints are new. i'm not near the truck it will be next week before i can post a few pictures of the entire setup.
Old 05-05-2017, 12:26 AM   #18
mongocanfly
Won't matter if its all new or not if it isn't timed correctly...get a good pic of the entire driveshaft...are you familiar with u- joint timing?
Old 05-05-2017, 12:34 AM   #19
Lookin4the1
no I'm not familiar with U-joint timing
Old 05-05-2017, 12:44 AM   #20
mongocanfly
The yokes on your driveshaft need to be lined up..here's a video about u joints that explains a lot..https://m.youtube.com/watch?v=gmV4qwLfOMY
Old 05-05-2017, 12:49 AM   #21
mongocanfly
Maybe this'll help explain as well...
Old 05-07-2017, 10:39 PM   #22
Lookin4the1
Old 05-07-2017, 10:39 PM   #23
Lookin4the1
i'll try to phase the U joints on tuesday and take better pictures.
Old 05-07-2017, 10:43 PM   #24
Lookin4the1
Old 05-07-2017, 10:47 PM   #25
mongocanfly
Were the u joints outta phase?
