Old 04-07-2004, 09:30 AM   #1
2kwik4u
Newbie Checking in....
Just wanted to drop in and say hello (didn't see a newbies forum) so I figured this was the next best one.
Just got a '70 GMC from a friend, that in all honesty is in need of some TLC. Paying him $650 for the truck with no motor (he's keeping the motor for another project). Overall plans for the truck for the next year is to make it a sound daily driver, then after that it will become the next project vehicle for me. Most likely with a frame off resto, and all kinds of upgrades. I have a 700R4 tranny that needs a rebuild to be ready for work, and am trying to source a TBI 350 for cheap from a local junkyard (carburators and I don't get along ).
Heres some pics for your viewing enjoyment.
The red Xtreme in the background of the first pic is mine as well. As soon as the '70 is up and running somewhat reliably it is getting a complete "redo" of sorts.....Going from a 2.2 4cyl 5spd 2wd setup to a Vortec 5.3/4L60E/AWD setup....should make for an interesting truck I think.
Also theres links in my sig for the gallery on both trucks.
2000 S10 Xtreme
1970 GMC SWB Step
2kwik4u is offline   Reply With Quote
Old 04-07-2004, 09:33 AM   #2
Putter
More Cowbell....
Putter's Avatar
Welcome/welcome from Central Mississippi. Tons of info here to help you along. Ask anything you want, 'cause these folks have 99% or more of the answers.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-07-2004, 09:36 AM   #3
2kwik4u
Wow, quick response.....thanks for the welcome.....
you don't happen to know if there is an online place I can go read about production numbers do you???
2000 S10 Xtreme
1970 GMC SWB Step
Old 04-07-2004, 10:11 AM   #4
Putter
More Cowbell....
Putter's Avatar
I am just kinda' sitting here catching up on the new stuff that was posted overnight. I look at this all day at work, but don't tell my boss. Hang tight, cause there will be a ton of WELCOME posts coming your way in a little while. The folks here are super and eager to help you out if you need it. You will get like two pages of welcome posts.
Old 04-07-2004, 10:21 AM   #5
boogie
Welcome from Texas. I also obtained a 71 swb and own an 2001 extreme. Mine has the 4.3L v6, would love to put a 350 in there. Good luck on your project.
I didn’t write the script, I’m just stuck in it!
2001 Chevy S-10 Xtreme
1971 GMC C-10 "Well.. Part Atleast"
boogie is offline   Reply With Quote
Old 04-07-2004, 10:28 AM   #6
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Aloha from Tennessee!
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 04-07-2004, 10:34 AM   #7
gr8scott51
gr8scott51's Avatar
Howdy...
to both of you new bies from soggy western Washington.
If you use the search function you may find some previous posts on VINs and decoding block, rear end, etc. ids.
good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 04-07-2004, 10:41 AM   #8
rigo
Flake Daddy
rigo's Avatar
Another hello from Texas....nice to have you aboard!...
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 04-07-2004, 10:41 AM   #9
GMan69
GMan69's Avatar
Here's another Mississippi welcome headin' your way. Nice trucks. The '70 looks good in the pics.
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 04-07-2004, 10:51 AM   #10
Warbones
Navel Inspector
Warbones's Avatar
Welcome from Ks! Your truck looks pretty solid and should make a fun project. Sounds like you have some nice plans for it.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 04-07-2004, 10:51 AM   #11
outlawchevy
outlawchevy's Avatar
hello and welcome from south louisiana.
(If all else fails get a bigger hammer)
outlawchevy is offline   Reply With Quote
Old 04-07-2004, 12:24 PM   #12
Putter
More Cowbell....
Putter's Avatar
Not trying to go too far off the train of thought, but where in Southern Louisiana OutlawChevy?
Old 04-07-2004, 12:32 PM   #13
72LOWBOY
Welcome to the board from southern Florida!
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work.
68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife
38 Chevy Coupe on the back burner
LIFE IS GOOD! SMILE
72LOWBOY is offline   Reply With Quote
Old 04-07-2004, 01:00 PM   #14
2kwik4u
Overall goals are 3 years from now to have this truck as a tow/show vehicle for the Xtreme. All 3 painted red ('70, Xtreme and open car trailer).
The '70 is most likely going to end up with a 6.0L/4L80E combo out of a newer 2500HD truck. That should provide enough power to pull around a 4k lb truck/trailer combo. I am seriously considering doing a MILD airbag setup on the suspension, in hopes that it will help with the trailering aspect of things, as well as adding a little weight carry capability.
I am thinking that I will most likely go through the entire truck in a year or so and start the "resto" of sorts. I'm a big stickler for doing things RIGHT the first time, as well as making sure things are 100% done on each project.
First mods I think are going to be a new seat, as well as a blazer gastank/marker light filler......I hate that tank being behind the seat very much badly. The front already has the 5-lug/disc brake conversion, as well as a new front sway bar. The buddy of mine that I am getting the truck from has the parts to replace the rear trailing arms/springs/axles to convert to a 5-lug back there as well.
For some reason I have ALWAYS like this body style. even though the truck isn't worth much in it's present state, I'm feeling pretty motivated to get started on it, and make it ALOT nicer. I'm thinking paint is in it's near future as well.
2000 S10 Xtreme
1970 GMC SWB Step
Old 04-07-2004, 02:21 PM   #15
juju808
juju808's Avatar
welcome from denver....
...juju...
juju808 is offline   Reply With Quote
Old 04-07-2004, 02:41 PM   #16
shortymac83
hmm...
shortymac83's Avatar
hey from Indy!
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 04-07-2004, 04:24 PM   #17
dtlilly
dtlilly's Avatar
Another warm welcome from Tennessee.
dtlilly is offline   Reply With Quote
Old 04-07-2004, 04:30 PM   #18
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Hey from St. Louis. Another GMC to the list!!
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 04-07-2004, 04:34 PM   #19
krue
Designated A-hole!
krue's Avatar
Welcome from South Mississippi! GMC, swb and a stepside! You got a winner there!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-07-2004, 05:29 PM   #20
Yukon Jack
Yukon Jack's Avatar
Welcome from me too!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-07-2004, 09:46 PM   #21
Blue Beard
Blue Beard's Avatar
Welcome form SW Washington State.....
Looks like a good truck to start with....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-07-2004, 09:50 PM   #22
Bryan68custom
Welcome from North Texas.
2004 Extended cab LS silverado
2001 Buick Lesabre
1968 Chevy Custom 10 LWB Anniversery model
2008 crew cab lt (rolling on dubs)
"The nice part about living in a small town is when you don't know what you're doing, someone else always does"
Bryan68custom is offline   Reply With Quote
Old 04-07-2004, 10:40 PM   #23
Big J
Its lookin' like a Blazer!
Big J's Avatar
Thats a nice project truck. Welcome from a fellow Kentuckian! I think Custom Classic Truck magazine is doing a tpi install, it might be a source for some info. Good luck!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 04-09-2004, 01:05 PM   #24
Swbman
Welcome aboard for the great midwest Tulsa, Oklahoma that is. and 650. for a solid truck without an engine and tranny is a pretty fair price IMO.Now the work begin...
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 04-09-2004, 01:15 PM   #25
jorgensensc
jorgensensc's Avatar
Welcome from Houston!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
