Re: 1965 LWB Stepside Build
Also received the other electric oil gauge in yesterday. I worked on it yesterday and finished it today. It was a little easier to put in and I like it a little more...so this one stays and the other goes to my friend. This one also came with the correct sending unit which is nice.
![]() ![]() ![]() Join Date: Jan 2018
Looks like it's going to be driving soon!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Wow you have come a long ways buddy... That is going to be road worthy real quick.
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039 She may not be the prom queen but at least she puts out.. |
#4 | |
I got overwhelmed sometimes with the enormity of the build. I knew nothing when I started this and I still know most of it. ![]() With the help of this board and all the good and knowledgeable members, I may just get her back on the road. My goal is to be moving forward and reverse and stopping by the end of the month...in the meantime finish the A/C install and start putting it back together. John is milling my bed wood out of walnut...I need to nudge him I think. ![]() |
OK, so I got a new cut off tool and put it to use today. I am going to repair the radio hole in my truck, but also do some other stuff as well. I drilled out the spot welds on the ashtray hole and then cut out the opening. I am going to flush the hole and install my new center vent trim I got from Restomodair.com. After I cut the opening, I needed to see what it would look like. I LOVE this vent...I had been looking at it for a long time and finally bit the bullet and bought it. Now on to flushing the patch panel, cut the patch panel for dash installation and then cut and weld in the patch panel. Woohoo I am excited.
Forgot to add the pictures... |
On hot days like this...I am reminded of my favorite shop tool...a LARGE fan my dad put together back in the 50's. Like anything back then you made due with what you had. Large motor, fan blade and a Standard Oil cast iron lollipop sign base and post. I do not remember a time in my life without this fan. Moves a lot of air and looks great while doing it!
Moving right along...cut out the patch panel for the ashtray to smooth out the dash. I don't think it is too bad of a fit for a first try. First time for everything...hope to get it welded next week.
Sandblasted and sanded my door panels today...and got one painted. I need to fill in 2 unlevel holes before I paint the other. The PO had a door pull installed (cabinet pull) and it was not level...
I can't decide if I am going to paint the inner portion of the panel green or leave it all silver. Anyway...here is the passenger side panel painted and the drivers side ready for primer after I repair the hole. |
Continued painting the door panel. I masked it off and painted green to make it two tone. I really like the result. I also patched the 2 holes on the other door panel today, so hopefully get paint on that one this week. Here is the process I did to the painted door.
I used 1/4" tape to go around the edge where I wanted the stripe. All in one loop for each layer...then masked off the rest with blue painters tape. Then painted the green...3 coats and when the last coat was fresh, pulled the tape. Now just need to clear coat it and it will be finished. I think the green will be a nice break on the silver door. |
The fan is way cool! Great idea for the panel, looks good.
I like the green, that's a nice touch to break up the silver
Thanks, I like the panel a lot! I LOVE the fan. The best feature is if wasps are flying around, they usually get sucked into the blades and I see them lying on the ground near it...no more pesky wasps! LOL
Thanks Christian! |
Dang man, love the build! Very detailed. Makes mine look way amateur! Another question for you, on your emblem restoration is the silver just painted?
Posted via Mobile Device |
#14 | |
The silver on the emblem is the factory plating. I just polished it some. |
#15 |
Got the 2 holes patched in the drivers door panel and painted the silver today. Hopefully will get it masked and be able to paint the green tomorrow.
Also ordered copper nickel brake line today to finish the brake lines up to the proportioning valve from the Tees. I bought the Eastwood brake line flare tool so I am anxious to use it. |
#16 |
Finished the drivers door panel this morning. I took some more detailed pictures of the 1/4" tape line if anyone is interested. I put 3 coats of green on and just like last time as soon as the 3rd coat was laid down, I peeled off the tape. Looks eerily similar to the last one...which was my goal.
#17 | |
#18 |
Loving the green also! Is the 503 paint out of a can and what brand?
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#19 | |
#20 |
Had to rework my e brake crossmember since my transmission sits further back than OEM. I am going to flip the e-brake crossmember over and still have it in the OEM location. I had to cut a small notch in the e-brake crossmember to fit, but should work fine. After I notched it, I cleaned it up and painted it. Should be able to install it tomorrow.
#21 | |
#22 |
I did! I originally had the engine in the factory mounts, but the distributor was really close to the firewall and my rams horn manifolds hit the firewall, so I moved the engine to the forward position. I used the POL perches for forward location. I like how the engine sits so much better now.
#23 | |
#24 | |
Did a little cleaning yesterday on one spring...still have to do the other. It is going from this to this...much better. |
#25 |
Got the crossmember for the e-brake installed this morning. I still need to connect the cables. I can't find on of the clevis pins, so no point in installed 2 of them...plus I need to order a new rear ebrake cable. The passenger side is frozen and won't move.
I determined it is hard to take pictures on your back. haha Here is the crossmember installed and you can see where I had to notch it below the IFS logo on the trans crossmember. Fit like a glove. |
