![]() ![]() ![]() Join Date: Jan 2018
Re: 1965 LWB Stepside Build
Dadgum, that's quite the gift! That'll look great on top of the dash
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
OK, so I have been bored lately...without my truck back yet! UGH! I haven't had a whole lot to do on the truck side. I was in my shop today and I saw this bow tie I made years ago out of carbon fiber...so I thought I would take a picture as a nod to Chevy for making awesome old trucks, but I guess when they made them, they were new! LOL
Dropped by the shop today to check on my truck.
WE HAVE EXHAUST! ![]() ![]() ![]() They just need to button everything up and I will have it back. Was very hard letting someone else touch my truck after 3 years of working on it... They need to wet sand and polish the dash where the welded in my patch panel and put the windshield back in ...they took it out to paint the dash. The engine bay is real clean how they ran the wiring and such for the vintage air. Here are a few pics I took. Will take better ones in the sunlight when I get the truck home. I also cranked it and Oh My Gosh it sounds good! Can't wait to get it back so I can drop the bed on it and cruise! Last edited by roll_the_dice; 10-29-2020 at 02:22 PM. |
Moderator
![]() ![]() Join Date: Aug 2011
Great progress, thanks for the updates.
Looking good! it will be together before you know it now.
Before you put bed back on I would hit all the welds of exhaust with some high temp paint (personally I would paint whole system from mufflers right up to tips) I know with the exhaust getting spray from tires the welds can start rusting pretty quick. |
#6 | |
Thanks...good advice! Never thought about the welds rusting...since it is stainless pipe I "assumed" I was fine. Good call! |
Yeah I mean as long as they used stainless wire to weld it up it wont rust through or anything but might still get specks of rust through weld and at hangers. I know some shops just weld the stainless with standard wire and that rusts so better to throw something on it either way for me lol.
Thanks for showing how the exhaust was run. That's almost exactly what I was thinking about doing with my truck once I get to that point of needing it done, so it's good to see that it will all clear. Did you use 2.5" pipe?
#9 | |
It is 2.5" pipe...I like how it is run. I didn't want anything super fancy... $$$. Sounded good too. I will shoot a video of the sound after I get it back. |
![]() Join Date: Mar 2011
It looks like you had better luck than I did with the shop you chose. Nice work. Where does it cross to the outside of the frame? I would also recommend putting some high temp paint down.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#11 | |
I will be honest, I was so excited to see and hear the exhaust, I didn't look to see where it crossed. I "assume" it is angling back directly out of the manifold, maybe that is how they got around the starter. I will look when I get it back. |
As most of you know my truck is in the shop getting exhaust and having my vintage air charged. I got a call from the shop Friday at about 1PM saying my new condenser is leaking. It is new, but also 3 years old..since I just got around to installing it but have had it since May of 2017. I called the place I bought it from and they said I had to go through Vintage Air, they could do nothing for me. So I called Vintage Air not really thinking I could get it replaced under warranty. I had to leave a message. Shane from VA called me back within 30 minutes and I told him the situation...and said it is out of warranty by a few months. Shane said, that's OK, we are going to take care of you! He found my original order and asked where I wanted it sent...About an hour later I received an email with shipping notification...and today I received it! I could not believe I got it so fast. They are in TX and I am in GA. Any build I do in the future will have Vintage Air in it...their customer service was above anything I expected! Thanks again Shane and Vintage Air!
#13 | |
That's good to hear. I love hearing good things about a company I'm considering purchasing from
#15 | |
Yeah, it is nice to know you picked the right company for your hard earned money! |
#16 |
It's Better With Nitro
Awesome progress! And, Vintage Air has always been good to me, too, on some of my oddball requests and part replacements.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#17 |
Thanks Vince! Yeah, VA replaced decals I didn't receive 3 years later also. They seem to want to take care of their customers for sure! Just wish I could buy directly from them instead of someone else so they would get a bigger slice.
#18 |
OK finally got my truck back the day before Thanksgiving, but it wasn't running great...so the last week I have been dialing in the EFI and doing some minor things. Today, I got a major thing done...finally put the bed back on it. 3 of my buddies from Church came this morning to help me. Only took a few minutes to get it on and the bolts through the wood bed. You know you have good friends when they get under your truck to help line things up!
Here are a few pics of the process and the finished product...although the truck isn't finished, my wife and I did go for a quick cruise late this afternoon. Was so nice being able to get in and go...Now just need to button some things up..front bumper, seat belts, etc. |
#19 |
Heck yeah man! The truck looks great!
#20 |
![]() Join Date: Apr 2017
Love it...Always nice to have friends help....Looks great Andy!!!!
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
#21 |
Looking good!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
#22 | |
#23 |
Got some things done this week....installed the front bumper..finished wiring the tail lights and license plate I also had an old Chevrolet script valve cover. I painted it Detroit Diesel Green. I then sat it over my existing valve cover to see what it would look like. I LOVE it. So now this made up my mind...I will be getting script covers with PCV and breather. I need to save my money for these though...they aren't cheap.
#24 |
I also bought some sail panels and I sat one on today to see what it would look like. Not sure if I will use them or not...They are from a 60-63, not 64-66...which I am not sure I care, but since step sides never had them...not sure if it looks weird or not. So before I put them on with screws, I need to decide.
#25 | |
By the way AWESOME build! great work sir!! |
