Old 05-20-2017, 03:45 AM   #1
Greg R..
Talking 235 or 250
how can i tell what size straight 6 i have.. grandpa replaced the engine on his car 15 years ago and doesn't remember if he replaced with the same engine or not... thank you in advance,,,,this forum is great !!!
Greg R.. is offline   Reply With Quote
Old 05-20-2017, 06:00 AM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 235 or 250
I'm guessing that you mean 230, not 235.
The 235 was used from 1950-1962. Then it was replaced with the 194/230/250/292 family.
Here's some casting numbers. Might be other websites with better info:
http://www.castingnumbers.info/site/...cks/t/Inline-6
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-20-2017, 08:05 AM   #3
GRX
GRX's Avatar
Re: 235 or 250
Those two engines are very different. Easy way to discern them is the 235 has 2 large freeze plugs on the driver side, the 230/250 blocks have 3.
Quick way to tell a 230 from 250 is remove a spark plug and look at the pistons. 230 has flat tops with four valve reliefs, the 250 has dished pistons.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 05-20-2017, 10:33 AM   #4
68Gold/white
Re: 235 or 250
The 235's had two studs with acorn nuts holding the valve cover on. The 230/250 engines had bolts on the perimeter of the valve cover holding it on.
Correct? GRX
68Gold/white is offline   Reply With Quote
Old 05-21-2017, 01:27 PM   #5
GRX
GRX's Avatar
Correct? GRX
Partly. The 216 and older 235s had the two center studs. Was changed to 4 outer bolts some time in 1954.
Old 05-21-2017, 06:21 PM   #6
Greg R..
Re: 235 or 250
this block has 3 freeze plugs
Old 05-21-2017, 06:56 PM   #7
68Stepbed
68Stepbed's Avatar
Re: 235 or 250
The 235 also has a single lifter cover. The 194/230/250/292 engines have two side by side covers. I believe the 292 has slightly larger covers.
216/235's have only 4 exhaust ports. The 250 has 6 exhaust ports.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-22-2017, 02:20 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 235 or 250
GregR: So you have a 230 or 250. One way to check is to find the ''Dress number'' stamped into a machine pad behind the distributor. The 2 or 3 letters at the end can be decoded. I.E.: F0626UH = Flint, MI, June 26th, UH -=292 1968. Find these numbers and get back to us.
It will be easier than pulling the head and mic-ing the bore.
68Stepbed: The 292 L6 has much larger side panel lifter covers -- 6'' tall. The 230/250 covers are just under 4'' iirc.
Old 05-23-2017, 03:56 AM   #9
Greg R..
Re: 235 or 250
thank you .. i will check it out ,,and report back
