Old 06-13-2017, 04:32 PM   #1
c10jmac
Just another bagged and ls swapped c10
this is where it started. 71 long bed.
c10jmac is offline   Reply With Quote
Old 06-13-2017, 05:28 PM   #2
c10jmac
Re: Just another bagged and ls swapped c10
Picked up the 5.3
Old 06-13-2017, 05:30 PM   #3
c10jmac
Got it moved over to its build spot
Old 06-13-2017, 05:32 PM   #4
c10jmac
Started pulling it apart
Old 06-13-2017, 05:36 PM   #5
c10jmac
Got the cab off.
Old 06-13-2017, 05:39 PM   #6
c10jmac
Notched out the front cross member
Old 06-13-2017, 05:42 PM   #7
c10jmac
Got the lower control arms ready for the bags.
Old 06-13-2017, 05:43 PM   #8
c10jmac
Oh yeah, I am turning it into a short bed.
Old 06-13-2017, 05:44 PM   #9
c10jmac
she cut up
Old 06-13-2017, 05:45 PM   #10
c10jmac
Got everything tacked. Double checked all measurements and everything is perfectly level.
Old 06-13-2017, 05:47 PM   #11
c10jmac
Frame welded and a reinforcement plate is welded in in the inside. Started mocking up the trans cross member.
Old 06-14-2017, 05:37 PM   #12
tinydb84
tinydb84's Avatar
Whats the cross member notch for?
David
Instagram: myfabguy
Old 06-14-2017, 06:36 PM   #13
c10jmac
The notch will get me 3'' closer to the ground. You can buy the drop members, but i have a lot of time on my hands.
Old 06-14-2017, 06:51 PM   #14
tinydb84
tinydb84's Avatar
I didn't even notice it moved up in the frame. I just saw the front cut.
What are you doing for steering?
David
Instagram: myfabguy
Old 06-15-2017, 11:51 AM   #15
Jstrumpf
Awesome work so far.. Coming along nicely.
Jstrumpf is offline   Reply With Quote
Old 06-15-2017, 04:01 PM   #16
c10jmac
The factory steering will work with this setup. I did section that front part for clearance. I will add a power gearbox.
Thank you!
Old 06-15-2017, 09:35 PM   #17
hewittca
hewittca's Avatar
Seen it a thousand times, boring. Just kidding! Thanks for sharing your build. Looks like it's going to be a nice truck. I like your method of raising the front crossmember. I haven't seen that exact approach before.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-16-2017, 08:48 AM   #18
c10jmac
I have saw this way done a couple times. Once I get everything mocked up, ill see if it meets my goal for how low i want it to be. If not i will Z the frame up front.
Old 07-05-2017, 04:56 PM   #19
c10jmac
Started building the transmission cross member.
Instagram @c10josh
Old 07-05-2017, 04:58 PM   #20
c10jmac
I went ahead and z'd the frame. Started boxing in the front portion of the frame.
Instagram @c10josh
Old 07-21-2017, 11:32 AM   #21
c10jmac
Started building the step notch.
Instagram @c10josh
Old 07-21-2017, 11:35 AM   #22
c10jmac
She going to be low. Still a lot of work to do on the notch. 4 link is next.
Instagram @c10josh
Old 10-31-2017, 09:29 AM   #23
c10jmac
Turned the axles down so I could use 2001 Silverado rear disc brakes. Just need to fab the mounting bracket.
Instagram @c10josh
Old 11-14-2017, 06:45 PM   #24
DEADMAN01
did you buy a 4 link kit for the rear or make your own?
DEADMAN01 is offline   Reply With Quote
Old 11-16-2017, 01:04 PM   #25
c10jmac
Its a switch suspension 4 link kit.
Instagram @c10josh
