07-03-2017, 08:56 PM | #1 |
travel limiting front suspension
would limiting front suspension hurt or help me?
https://youtu.be/QtBMSvhp7tI |
07-04-2017, 08:33 AM | #2 |
Re: travel limiting front suspension
Looks like its working pretty good for those conditions. If it were on a prepped track it may be different. Do you want to do wheelies or just go fast? Also I forgot if you had the hood on in the video. It will change things a little.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
07-04-2017, 02:02 PM | #3 |
yes hood is on no inner fenders.
not so much looking for wheelies just go fast n to keep weight transferred Last edited by prostreet1967; 07-04-2017 at 02:13 PM. |
07-04-2017, 02:05 PM | #4 |
combo is 5.3 twin s366 66/73 .91 at 210# injectors th400 ptc converter Jake's 1-2 brake 9" with 3.89 gears ladder bars with 33x16 slicks
07-05-2017, 11:16 AM | #5 |
I have always been told to keep as much travel as possible but use a shock that will control it. Meaning you may need to work with someone like Santhuff on custom valving. Make full tight real tight and full loose something that will transfer the weight when riding on marbles..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-05-2017, 01:04 PM | #6 |
cool I'll look into some shocks soon. seems to be doing ok so I'll leave it for now. thanks guys
07-07-2017, 09:44 AM | #7 |
prostreet1967 how fast you running with that setup?
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
07-13-2017, 12:10 AM | #8 |
havent been on track n years. may try it on track soon to fine tune it.
got it leaving on 20# n 26#total. seen similar setups n similar weights mid 5s |
08-07-2017, 04:11 PM | #9 |
I've seen some grudge racers use cables or even chain and grade 8 hardware to limit front travel
08-12-2017, 09:46 AM | #10 |
Registered Truck Offender
I think you need some track testing to see 'IF' you need limiting or not. On a nose heavy vehicle you want as much pitch rotation as you can get. So like Shane is saying controlling how fast it rotates is tuning to traction.
On a strut chassis we use a limiter just to keep the suspension from 'bottoming out' in the strut. With a strut running anywhere from $300 to $900 side you don't want to beat it up with no ' suspension stop' . Then having the limiter,,, it's one more tuning tool to get lost in.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
