Old 07-16-2017, 02:05 PM   #1
F.A.A.benny
For those guys restoring their factory ac and heater boxes
Thought I'd post a video for you guys thinking about doing this to your boxes. It can be done to look very nice. Basically showing a before and after final assembly of the boxes describing all the parts that go to it.
https://youtu.be/Ickwhdl-1Hw
F.A.A.benny is offline   Reply With Quote
Old 07-16-2017, 02:35 PM   #2
Lanman1972
Lanman1972's Avatar
Re: For those guys restoring their factory ac and heater boxes
On my list of things to do, thanks
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 07-16-2017, 03:10 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-17-2017, 01:12 PM   #4
F.A.A.benny
No problem. I have a couple more videos uploaded on YouTube. Plan on making some more that might be helpful to some guys.
Old 07-17-2017, 01:44 PM   #5
1SG.Rob
1SG.Rob's Avatar
Subbed
1SG.Rob is offline   Reply With Quote
Old 07-17-2017, 01:59 PM   #6
In The Ten Ring
I did this, not as well though. I wish I could have removed my internal door (flapper) but guys on here talked me out of it. I was able to repaint the outside side, at least that won't rust.
In The Ten Ring is offline   Reply With Quote
Old 07-17-2017, 02:07 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
First rate Benny, no question.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-17-2017, 02:40 PM   #8
35boulder
35boulder's Avatar
Thanks for uploading your product. Looks nice. Are you refurbishing for others?
Thanks again.
35boulder is offline   Reply With Quote
Old 07-18-2017, 10:56 AM   #9
F.A.A.benny
Thanks Tony
Old 07-18-2017, 03:37 PM   #10
engineer_gregh
engineer_gregh's Avatar
Benny I couldn't have finished my rebuild without your help. First rate! Thank you sir.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 07-19-2017, 03:55 PM   #11
F.A.A.benny
Originally Posted by engineer_gregh View Post
benny i couldn't have finished my rebuild without your help. First rate! Thank you sir.
Old 07-19-2017, 06:51 PM   #12
mattfranklin
mattfranklin's Avatar
On my list. Subscribed.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 07-20-2017, 07:21 AM   #13
engineer_gregh
Benny if you can please post pictures and document the work you do on apacheIvan's truck. Of course with his permission. His truck is a great example of what a lot of folks are dealing with on their A/C.
Greg Smyrna TN
Old 07-20-2017, 10:10 AM   #14
hdff
hdff's Avatar
Benny refurbished my ac box and heater box. He did a great job!
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 07-20-2017, 11:32 AM   #15
RenoKeene
Florida Edition
RenoKeene's Avatar
Hi Banny, sorry I forgot to let you know we received the A/C unit you sent us (I have yet to install it). You do excellent work, thank you very much.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 07-21-2017, 09:57 PM   #16
F.A.A.benny
No problem. Send me some pics when it's installed if you can.
Old 07-21-2017, 11:10 PM   #17
ApacheIvan
ApacheIvan's Avatar
Benny said he doesn't service the AC I was going to take it to him for help..
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-21-2017, 11:12 PM   #18
ApacheIvan
ApacheIvan's Avatar
Hey Benny, what did you use on the outside of the box once you had it all clean. I stripped all the paint off mine, it looks very light, did you use any clear over it or use any product once you have it clean?
Dale - ApacheIvan
Original Owner
Old 07-21-2017, 11:37 PM   #19
F.A.A.benny
I guess i shouldn't have put it that way. What I meant by not doing service work is that I primarily do restoration of the parts. I can and have taken jobs when it was a complete restoration with installation where the owner is in no hurry. And that's pretty much the only service type jobs I take. Because the parts restoration jobs take up most of my time. And yes the housings are bead blasted and cleared.
Old 07-22-2017, 12:01 AM   #20
F.A.A.benny
ApacheIvan, if you would like to take it to a place that works with r12, check out McCain's A/C auto repair in Dallas. They work on classics and still work with r12.
Old 07-22-2017, 12:05 AM   #21
ApacheIvan
ApacheIvan's Avatar
I will look them up. Do you think I should just get the r12 muffler, disassemble everything and clean it out, buy a new drier and put it all back together dry?
Dale - ApacheIvan
Original Owner
Old 07-22-2017, 12:12 AM   #22
F.A.A.benny
You can do that. Then just take to them and have them charge it
Old 07-22-2017, 12:20 AM   #23
ApacheIvan
ApacheIvan's Avatar
Do you recommend I put oil in the system when I put it back together? When I put it together the first time the guy that put in the r134 said I was supposed to pre-oil the compressor, put oil in the condenser and drier. Is that right? If so, I think our systems are supposed to have 8oz of oil. Do I put all 8 in before sealing it all up? then they just put the R12 in it?
Dale - ApacheIvan
Original Owner
Old 07-22-2017, 12:27 AM   #24
F.A.A.benny
I would do that but it's 11 oz
Old 07-22-2017, 12:42 AM   #25
ApacheIvan
ApacheIvan's Avatar
Thanks, so put all 11 oz in before sealing it up? You actually put oil in the drier too?
It is 3.25lbs of R12 yes?
Dale - ApacheIvan
Original Owner
