Old 04-16-2004, 03:10 AM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
what makes an hei an hei?
is it the chip or the coil location? and then how do you tell the differance?
I'm seeing some distributors for a 350 being called a 350 but it has a vac advance on it and i thought that that wasn't HEI. Am i right?
then if i get one w/ a chip how do you wire it up? in a 68? thanks, sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 04-16-2004, 03:15 AM   #2
Sweet72
Sweet72's Avatar
Stock gm hei distributors are easy to id. They'll have the coil and module on top of the distributor cap, and yes they have vac advance too. They're larger in physical size than a points dist.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-16-2004, 03:17 AM   #3
whitesswj
Embrace the Redneck
whitesswj's Avatar
ok then, which is better, chip or vac advance hei's?
'01 Camaro
Old 04-16-2004, 03:44 AM   #4
Russell
Professional Grade
Russell's Avatar
vac advance HEIs if you don't like computers...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
