Old 09-15-2017, 11:31 PM   #1
custom10nut
custom10nut's Avatar
What is the White called?
What is the name of the White used on the roofs of our trucks?
I know it's not just White.
custom10nut is offline   Reply With Quote
Old 09-16-2017, 12:24 AM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: What is the White called?
Just "plain" white as I see it. Looks like 67-68 had two varieties. http://paintref.com/paintref/model/w...evyTruck.shtml
I found a thread where they call it "frost white".
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-16-2017, 01:22 AM   #3
71sierragrande
Petroleum User
71sierragrande's Avatar
521 white. I've heard some call it ivory, or maybe thats the wheels
71sierragrande is offline   Reply With Quote
Old 09-16-2017, 01:30 AM   #4
71CHEVYSHORTBED402
According to the link posted above, ivory (526) and white (521) are two different colors. Looks like both were available on a 67-68. 69-72 just the 521.
Tony
Old 09-16-2017, 01:38 AM   #5
71sierragrande
Petroleum User
Old 09-16-2017, 07:27 AM   #6
Frost white, by name. Ivory is an off-white leaning toward a shade of cream. Color codes varied with solid color and the 2-tones offered by the color was the same.
Old 09-17-2017, 10:07 PM   #7
custom10nut
Thanks to all for the info.
Frost White is what I've seen it called.
I'm about to replace my wind shield and have to do a little touch up around the opening. I just wanted to be able to paint it, but not have it contrast too much with the old color
Old 09-18-2017, 10:58 PM   #8
68c10airstream
68c10airstream's Avatar
Printed the sheet from the paint charts and you may need this info
521= white, 93-21667 is dulux, 817L =lucite (L=lacquer i think), and 817=duco
526=ivory, 93-93774 is dulux, 4195L=lucite, 4195 duco.
With this info you should be able to use these dupont brand codes and cross them over to whatever brand paint you will use.
From memory dulux was a old school enamel that almost never dried, stayed pliable. This was replaced by centari (trade phrase was "the weight lifter" play on words because you could add an activator and have a hard quick setting acrylic enamel.
Lucite was a very popular lacquer.
Duco=???
68c10airstream is offline   Reply With Quote
