12-24-2017, 04:14 PM | #1 |
Axle on Leaf Spring Placement
I have a 53 3100 with a S10 frame and 12 bolt axle and have a placement question.
Does the axle center-line need to be lined up with the pin/bolt of the leaf springs? Can it me moved forward and inch or so with a new/modified bracket? When I moved the leaf spring mounts I did my best to center the wheels in the fenders, but they may be a little to the rear. Its not bad, but something others probably won't notice. Another reason is the length of driveshaft - many premade ones are maxed out from my axle to trans. The M20 I am using is a little shorter than other trans (so I have read) and don't want to use a jointed driveshaft. I have searched some on this - and either I am not using the right terminology or the images are not visible due to the photobucket thing. Thoughts?
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
12-24-2017, 04:49 PM | #2 |
Re: Axle on Leaf Spring Placement
http://diy4x.com/product.php?product...cat=250&page=4
http://www.ruffstuffspecialties.com/...hantiwrap.html http://offroaddesign.com/catalog/14b...ingperches.htm here ya go . very comon in the off road world to do . some do 1" plus or minus . others do 1" or 1.5" and you weld it on what way you plan to move it .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-24-2017, 04:51 PM | #3 |
Perfect. This is exactly what I needed, thanks.
12-24-2017, 04:59 PM | #4 |
just make sure you get top plates to work with the axle moved . if 1 moves the other has to move . or the u-bolts will be at a crazy angle .
12-24-2017, 05:02 PM | #5 |
Yes, the whole thing will move as a unit. The perches are only tacked onto the axle tube, I wasn't sure on the angle of the engine/trans to set the pinion angle so replacement/modification should be easy.
12-24-2017, 05:19 PM | #6 |
what i am saying is you need new u-bolt plates along with the perches that weld to the tube .
if your center pin hole is no longer centered then the u-bolt plate needs the same off center in its self . = stock plates will NOT work anymore . http://diy4x.com/product.php?product...cat=250&page=4 http://www.ruffstuffspecialties.com/...25GM-UPLT.html http://offroaddesign.com/catalog/Rear%20U-Bolts.htm part way down the page is plates .
12-24-2017, 05:34 PM | #7 |
Yes, we are on the same page. I need to get new U-bolts as the ones I have are old and off of who-knows-what. Just something laying around for mock up purposes. I'll just add those plates on to "The Never Ending List".
12-24-2017, 07:27 PM | #8 |
o.k. just wanted to make sure you have it covered in 1 order .
