#1 | |
Re: Post Your Craigslist Finds
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I've seen that with tires on spids before. Probably aplant thing. I think the roof was painted at some point cause with the 481 paint it should have a white roof. Looks like great truck and if the Canadian diollar wasn't at 30% + exchange I'd be seriously looking at this truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#3 | |
![]() Join Date: May 2016
![]() Join Date: Oct 2009
and on the A and C pillars which clearly show the old white as well. I'm assuming all the blue (and the roof) was (re)painted blue at some point, except for maybe the inside of the bed. Must been an earl scheib masking job. But don't really care about the paint, just what's underneath - looks pretty solid.
exactly what greg said - roof originally white. same with tires - for some odd reason they get listed sometimes, incl the spare. maybe someone figured out way back when that we'd be oohing and ahing over SPIDs 40 some odd years later, so they wanted to fill a few more lines...
![]() Join Date: Aug 2013
#8 | |
#10 | |
" *!~!* 1969 Chevy C10 / 350 with 3 speed / NO Rust - truck 100% - $8900 (Lovettsville) "
No rust? Hmm ... Looks just like someone switched beds on my 69 long stepper, right down to the color and toolbox. Would be cool to have them parked side by side at my place but can't swing the funds right now. ![]()
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#13 | |
They don't even match... its not a set. its parts.
#15 |
Sorry. Should’ve put a smiley or something- I was being a smart ass about a truck that may or may not have been overpriced and caused a small ruckus.
#16 |
72 C20 Custom Deluxe Custom Camper w/cap (a really TALL cap)
![]() https://bend.craigslist.org/cto/d/19...752292070.html 68 C20 Custom Camper Longhorn $3500 https://inlandempire.craigslist.org/...753238600.html 70 K10 w/557 paint(so, of course, it's from GREENville ![]() https://greenville.craigslist.org/ct...753201867.html Last edited by jocko; 11-19-2018 at 09:51 PM. |
#17 |
67 4x4 step side. Pictures aren't the best but appears to be a short box. Its a Minnesota truck, so rust is a given, but it might be worth a look.
https://minneapolis.craigslist.org/w...753410452.html |
#18 |
![]() Join Date: Feb 2016
67 short step side. Fair amount of mechanical stuff done, but a lot left to do. Please correct me if I am wrong. $15500 seems a bit steep. Or maybe I need to reevaluate what my truck is worth.
https://salem.craigslist.org/cto/d/6...715167084.html This truck has a .30 over350 ci with an 87 tuned port injection intake with a FAST controler. HEI ignition. Of the three factory cams available for the tuned port motors, this one has the higher performance one w/new lifters, double roller timing set, headers, dual exhaust, backed by an 87, 700r4 overdrive transmission, mild shift kit new torque converter, trans cooler, backed by 3.73 12 bolt open rear end. New rear brakes, wheel cylinders and hubs, new front brakes, new master cylinder, power booster and proportioning valve, new radiator w/electric fan and aluminum shroud. New 110 amp alternator. New starter. New front bumper w/fog lights. Headlights are H4s. Rebuilt speedometer. All gauges work. New outer heater box w/new fan and heater core. New heater, radiator hoses and new serpentine belt. The front steering and suspension are all new including the steering box. The rear suspension has not been redone. Fenders front and rear are 68 because I like the clearance light look and they are hooked up. Louvered tail gate. New front windshield w/new seal, new rear windshield is a tinted slider w/a new seal. New under dash wire harness as well as all front new wire harness from American auto wire. New reapolstered diamond stiched seat, new dash and arm rests. The doors are the only body parts I haven't dealt with. They are just next on the list to referbish. The wheels are 15x8 powder coated by les schwab w/ new chevy caps and the tires are new in the rear, 275x60x15, the fronts are fairly good, 255x60x15. It has a recent front end alignment when the front end was rebuilt. The truck has keyless entry electric door locks w/remote start as well as cruise control. All side glass is good. It has the common rust areas , rockers,cab corners and kick panel but not terrible. All the items mentioned in this post have no more than 6800+ miles on them right now. I drive this daily. It's dependable. It's not a show truck by far. I wanted the, on the edge rat rod, look and for the most part, it is. It needs new window and door seals. Not a big expence issue. I have a clear, unbranded title in my name. I do not have to sell this truck. I have a 67 4x4 that I'm real happy with and this little toy is starting to take a back seat so maybe it's time to let it go. If you are serious about purchasing this truck please call or text, show contact info only. No emails please. I can't answer them. My phone won't let me. I'm asking $15,500.00 Or best cash offer. No tire kickers please. Both yours and my time is valuable. Thank you for taking the time to read this long post. I just wanted to get as much info to you without you calling or texting what I could have put here. Thanks again.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#19 |
#20 |
![]() Join Date: Jan 2017
https://www.ebay.com/itm/1971-GMC-Si...Bb30-r&vxp=mtr
I really like this custom color. I'm one of those green lovers on these trucks. |
#21 | |
#22 |
Me too and I like it. I don't like the 72 door panels as I prefer the scroll flat panels. I like this combo and it gives me strength to redo my 72 the way I like it. I'm starting on a frame off tomorrow. I appreciate this guy that built this going off path as its perfect in my book. If not then close.
#23 |
![]() Join Date: Nov 2014
I'm pretty sure this has been on here before but here it is again loaded 71 Camper Special in Colorado. https://cosprings.craigslist.org/cto/6755284803.html
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#24 | |
![]() Join Date: May 2001
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
#25 |
Nice finds
