Old 10-28-2018, 08:35 PM   #1
smbrouss70
smbrouss70's Avatar
Re: Palf's 1981 GMC
Glad you and Jan came Bill! I had a great time!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-12-2019, 04:36 AM   #2
Grizz1963
Grizz1963's Avatar
Re: Palf's 1981 GMC
Happy Birthday Bill
Here’s to a great year.
Thanks for your forum input everywhere
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-12-2019, 09:57 AM   #3
Re: Palf's 1981 GMC
Originally Posted by Grizz1963 View Post
Happy Birthday Bill
Thank you Grizz, haul'n some recycling, then looking at some car parts to start the day
Old 01-16-2019, 02:29 AM   #4
Grizz1963
Grizz1963's Avatar
Re: Palf's 1981 GMC
Progress?
We are all watching.
Old 01-16-2019, 08:12 AM   #5
Whamo
Whamo's Avatar
Re: Palf's 1981 GMC
While I am late, I see that Happy Birthday is in order!
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 10-29-2018, 06:58 AM   #6
LT7A
Re: Palf's 1981 GMC
You have been getting some good travel and use of the rig. That Offy intake is cool!
Old 10-29-2018, 03:33 PM   #7
MrFinland
MrFinland's Avatar
Re: Palf's 1981 GMC
You have nice Truck Bill. By the way, you have also nice "license plate"!
MrFinland is offline   Reply With Quote
Old 11-12-2018, 05:51 PM   #8
Re: Palf's 1981 GMC
While I had some downtime, I decided to get to the electrical (again). Pulled out the dash and started the setup on the replacement gauge cluster. Cleaned the gauge bucket up, painted the inside and the back of the front panel gloss white. I also added some LEDs to replace the stock bulbs. Fixed a few issues with the circuit board, found a bad splice joint on the power feed from the fuse box to the gauges and a bad headlight switch. I also had to readjust the ignition switch position so when it is off it isn't supplying ACC power to the ign leads.
While I was working on the cluster I decided to move the stereo to the stock location since it was already behind my radio delete panel. I did tweak the position some and trimmed the bezel so I could remove the bezel without having to pull the stereo.
Everything is back in place and seems to work. I need to replace the oil pressure sensor and I think the gauge will respond right.
Man, finding broke grounds and power leads took me a week, but things seem to be good again. Clean her up tomorrow, and back to driving it some more.
Old 11-12-2018, 09:14 PM   #9
OutlawDrifter
Re: Palf's 1981 GMC
Nice work Bill, looks like a great improvement!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-13-2018, 12:51 AM   #10
Greenlee
Greenlee's Avatar
Re: Palf's 1981 GMC
Nice work! Those LED bulbs make a huge difference. One of the best mods you can do to these trucks. I could barely see the gauges at night before.
Greenlee is offline   Reply With Quote
Old 11-22-2018, 03:15 AM   #11
Grizz1963
Grizz1963's Avatar
Re: Palf's 1981 GMC
Morning from my still warm bed here in England, Bill.
Been awake since stupid-0-clock, and reading threads I missed before or have not been on for a while.
My new to me 79 Blazer thread is almost up to date on here now too, last few days reporting updates to go. http://67-72chevytrucks.com/vboard/s...d.php?t=774451
But reading your thread, I am wanting a Square body stepper, but also realised that I may have to remove my carpets and refresh the rotted insulation and sound deadening.
I love the way you approach the Stepper. Bit by bit.
Lessons learned every day.
Old 11-23-2018, 03:21 PM   #12
Re: Palf's 1981 GMC
Finally, I have all gauges working and dash functioning. I had to replace front turn signal/park lamp socket as it would noit ground the circuit. With that fixed this morning, I decided to replace the super faded side marker lenses also. Then it was drive time. Roaming around the bayous and all was nice and peaceful. So the 81 seems to be all together (for now), so now I have to troubleshoot/fix some heater and coolant issues on Whitey. It never ends
Old 11-23-2018, 03:34 PM   #13
OutlawDrifter
Re: Palf's 1981 GMC
It's always nice to get the "little things" done!
1991 Z/28, 6.0L/T56
Old 11-30-2018, 07:09 PM   #14
moregrip
moregrip's Avatar
Re: Palf's 1981 GMC
that is one nice looking rig!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 11-30-2018, 09:55 PM   #15
Re: Palf's 1981 GMC
Thank you guys. Been using it for a daily driver lately as my 02, Whitey, quit putting out heat and was leaking at water pump. I think I got Whitey all flushed out and parts replaced so the GMC can get his house back.
Old 12-21-2018, 06:48 PM   #16
Re: Palf's 1981 GMC
Been working on other stuff and mostly just using this one as a daily driver. After spending the morning delivering several loads of Angel Tree gifts, I decided to add a bit of bling to the 81. For the GMC, they only reproduced the "M" of the original style grill letters. I kind of wanted folks to know it were not a Chebby. So I found some emblems off some newer SUVs. I picked up several, but I believe this one came off of the rear of one of the recent car style SUVs. Cleaned up the grill and I had some good 3M trim tape, so cut some up, aligned her up and now she show her lineage up front.
I am still debating on a aftermarket tube grill, but for now this should do.
Old 01-20-2019, 01:47 PM   #17
BIGglaSS
BIGglaSS's Avatar
Re: Palf's 1981 GMC
Yes! I need one of these. I've been casually checking the wrecking yards, but haven't found anything the right size. I'll keep looking. Your truck looks great. keep the stock grille.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 02-01-2019, 10:22 AM   #18
LT7A
Re: Palf's 1981 GMC
Been working on other stuff and mostly just using this one as a daily driver. After spending the morning delivering several loads of Angel Tree gifts...
Cool to hear about your involvement with Angel Tree. I got to do a ride-along to deliver some angel tree gifts when I was in college. Something I'll never forget. It was in the Central District and one of the deliveries was to an African American (which I'm not) family of two boys whose dad was incarcerated. We knocked and the mother yelled for us to come in. As soon as we opened the door the youngest boy of about 4 ran across the room to me with his arms open. Even though we were bringing them wrapped Christmas gifts, he stayed in my arms until we left. Those of you who are fathers or surrogate fathers, try to never doubt the value and impact of your presence or embrace. Now back to trucks...
Old 12-21-2018, 07:25 PM   #19
OutlawDrifter
Re: Palf's 1981 GMC
That looks good Bill! Merry Christmas to you and yours!
1991 Z/28, 6.0L/T56
Old 12-21-2018, 07:32 PM   #20
Grizz1963
Grizz1963's Avatar
Re: Palf's 1981 GMC
Still in two minds about what badge to fit to my Blazer. Chevy or fake news GMC.
Your badge is actually real subtle Bill.
Works for me.
Old 01-08-2019, 01:41 PM   #21
Re: Palf's 1981 GMC
I am guessing it did not like the run to Baton Rouge and back Saturday, as this happening today. Think the head-gasket is leaking/gone. Waiting for it to cool down and troubleshoot.
Old 01-08-2019, 01:59 PM   #22
62 short step
62 short step's Avatar
Re: Palf's 1981 GMC
Sorry to hear that Bill.
Good time for a motor swap!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-08-2019, 02:27 PM   #23
Grizz1963
Grizz1963's Avatar
Re: Palf's 1981 GMC
Poop.
Not good.
Hope it’s minimal hassle.
Old 01-08-2019, 04:02 PM   #24
smbrouss70
smbrouss70's Avatar
Re: Palf's 1981 GMC
https://www.jegs.com/i/Chevrolet-Per...622K4/10002/-1
It has almost as much torque as that straight 6!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-08-2019, 04:39 PM   #25
62 short step
Re: Palf's 1981 GMC
There ya go Bill!!
1965 c-10
86 chevy c/k 20
