01-21-2018, 02:40 PM | #51 |
Re: Project Money green
Lots of elbow grease and the frames got a fresh coat of paint. Pulled all the old brake lines out and will be installing the SS ones I have this week. Next on the list is to prep and paint firewall.
01-21-2018, 08:09 PM | #52 | |
The Older Generation
Lookin' good. Keep it up and before you know it you will be on the road..... LockDoc
01-21-2018, 08:26 PM | #53 |
01-22-2018, 02:58 PM | #54 |
Looking good man, you do nice work. Is your garage heated at home?
01-22-2018, 07:06 PM | #55 |
Thanks, I built the garage probably 6 years ago. It's 24x30 with 11' ceilings, I insulated all the walls and ceiling and hung sheetrock which made a big difference. I have a small Bottle Dawg heater but if I leave it on 50 its fine. Natural gas is awsome my bill is usually 200 bucks for the whole winter
02-18-2018, 06:35 PM | #56 |
Lots and lots of scraping and sanding this morning. Need to patch a few holes and it's ready for primer. I really want to do vintage air setup to clean up firewall
02-19-2018, 09:31 AM | #57 |
Looking good almost there. Are you going to paint the engine bay black or green again?
02-19-2018, 10:46 AM | #58 |
Firewall is going to match green, picked up base clear for that. I have to paint the new inner fenders black and might do bottom of hood black as well because it's pretty rusty and the black will hide it better
03-11-2018, 08:48 PM | #59 |
Got some work done on the firewall and installed aeromotive stealth fuel pump in tank. My vintage air setup should be here Tuesday and Ill start welding in firewall plate. Hoping to test fit motor and trans this upcoming weekend.
03-11-2018, 08:51 PM | #60 |
More pics, also started mocking up Corvette fuel filter
03-12-2018, 07:47 AM | #61 |
Looking good. That is the setup he used in my truck as well. Corvette fuel filter with built in regulator. We went with an external pump though. Can't wait to see this truck this year. Hopefully we can meet up once the weather gets nicer and my truck is actually roadworthy.
Nick |
03-12-2018, 06:56 PM | #62 | |
03-14-2018, 08:41 AM | #63 |
Nice progress!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-19-2018, 08:43 PM | #64 |
Vintage air kit came in and very pleased with the quality. Welded in the firewall plate and body worked it. Finished prep on firewall and shot some epoxy primer. Next step is to test fit motor and trans
04-01-2018, 09:12 AM | #65 |
Motor is in and test fit went well. Stands are in forward position and speed engineering plates all the way back. Headers fit great, going to need a little clearance on the belhousing where starter mounts. Also looks like I'll be able to keep the low hump floor and just trim lip between firewall and floor. Making progress
04-02-2018, 08:28 AM | #66 |
Looks great, your making some good progress now. Must be a nice feeling when everything is finally test fit and you know all the parts work together.
Is the motor stock and is it going to stay that way? |
04-02-2018, 08:57 PM | #67 |
Thanks, I upgraded to a 216/220 texas speed cam and PAC springs, trunion upgrade and new head gaskets. I wanted a mild cam as my gto has a good sized cam and driveability suffered a little. The 350 that was in the burb had maybe 175hp so the 6.0 should be much better. Excited to get the painting done and get on with putting back together
04-04-2018, 10:08 AM | #68 |
Looking good, .
04-04-2018, 12:24 PM | #69 |
sweet build! Looking forward to the progress!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold) 1969 Jimmy, 2wd swapped. bagged, body dropped |
04-18-2018, 06:17 PM | #70 |
Firewall is green now. I am by no means a body and paint guy, but I'm not afraid to try. Paint came out nice, I could have spent a lot more time on body work. I am very happy with results as it's my first time spraying base/ clear coat.
04-18-2018, 08:56 PM | #71 |
Came out nice. Good work!
04-18-2018, 10:06 PM | #72 |
Looks good. You can come and do mine now.... LockDoc
05-20-2018, 04:48 PM | #73 |
Been working on little things for the past few weekends. Got the brakes all back together and bleed, power steering lines are done. Harness is on and into cab of truck. Headers are on and I built a trans cross member this morning. Exhaust and get the front sheet metal back on is next
05-21-2018, 07:59 AM | #74 |
Looking great man, keep it up.
06-03-2018, 08:51 PM | #75 |
Looking like a truck again! Got the front sheet metal back on and installed cold case radiator and fan setup which was super easy. Drops right into the stock HD brackets and fits like a glove.
Third row seat brackets are done and installed, now I can install the fuel tank and lines for good. |
