Re: SkinnyG's '61 Apache
Haven't been working on the truck at all over spring break. Largely doing things for family.
I did, however, get a pretty thorough clean on, got the '61 over to the hoist, and finally found the top of my work bench. ![]()
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Brakes are bled. Good solid pedal. Yay.
Picked up some 8th Gen Civic Coupe door seals, as I'm not delighted with the fit of the Precision door seals I installed.
Also picked up parts for SkinnyKid2's car; he just got his learner's.
#5 | |
![]() Join Date: Sep 2020
Thanks…. |
I did not order these new, I took them form 8th Gen Civics at the junk yard. Get passenger side ones, as they are less worn.
#7 | |
72315-SVA-A01ZA R side sub B at end for grey inner portion 72355-SAV-A01ZA L side |
Moved over to the hoist:
![]() ![]() The Precision door seals look better, but the doors close with the Honda Civic seals. I'm probably going to be ok with it over time. Hooked up the shifter. Poked around in the shop, tidied, and made a list of what I think I need to finish things.
Finished the zig-zag through the front X:
![]() Next the corkscrew through the rear X.
Nicely done. That's alot of patience.
First, we need to go UP from the unmuffler:
![]() Then I'll need a 6" straight to connect to the left side of this, up over the frame, and into the fenderwell ahead of the wheel. Man, this took forever. ![]()
A tricky job, beautiful welds,
they will conjure it up in the truck with their skills.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
Whoa...that last run of pipe you welded together had to have taken forever! That is awesome though!
Yes, especially since my horizontal bandsaw blade is not designed for Stainless Steel, and I had to cut about ten of the pie-cuts with an angle grinder by hand. New blades coming.
For those who have forgotten (grin) - this is at the motor: ![]()
#15 |
Christmas!
HP Tuners, AEM Wideband, Spider Caps, Plug Wires, AND a Classic Instruments panel all arrived today! I'm enjoying the selling of my '77
#16 |
Spider Caps:
#17 |
I have a stupid question for you, why do gas jobs need a waste gate and diesel don't?? nice work by the way should be a fun truck to drive. that pipe work is awsome job
#18 |
If the turbo is properly sized that you don't overspeed the turbo, you don't need a wastegate. That might be a small turbo, relatively speaking. A small turbo will spool quickly, but you'd get more power from a bigger turbo - and then need a wastegate.
#19 |
Definitely need another band clamp - there is no way this psycho corkscrew of a tailpipe can be one piece and installable.
#20 |
Line Lock arrived. Good, as I'm going to be doing the brake lines soon. More of a novelty than required, but I've never had one before, and kinda want one.
#21 |
![]() And fabricated an air filter elbow as well: ![]()
#22 |
Except I did have to cut a bit off to actually fit the filter. Just.
#23 |
Back on the fuel filler, with the vent to make filling much easier:
#24 |
Brake Brakes are plumbed from the Wilwood proportioning valve back.
![]() You have GOT to get one of these: ![]()
#25 |
Fuel and brake line clamps made from some sort of plastic I bought two years ago.
![]() Four large ones, and that one wee one on the right. Air lines and wiring dangling: ![]()
