BlahBlahBlah
Half ton vs 3/4 ton
What's really the difference in hauling capacity? Is a 3/4 ton really only good for an extra 500lbs?
Hauling stuff, towing stuff, unless you have a contracting business and haul bricks all day or pull heavy equipment, when is having a 3/4 ton really going to be that much better for most at home DIY guys and gals? For those of us that actually use our trucks as trucks that is.
Re: Half ton vs 3/4 ton
Not just 500#. The 1/2, 3/4 and 1 ton ratings go WAY back to pre-war and have little to do with payload of trucks even of the 67-72 vintage.
Within each platform, how the truck is equipped dictates what payload is as well. I had (3) 3/4 ton GMC at the same time, all 1970 models. The max payload for the C20 platform is 7500#. My big block longbed auto was rated at 7500# GVW. The 4 speed small block Longhorn truck was rated at 6600# GVW and the longbed 6 cylinder 3 speed was rated at 6200#. That's more than 1/2 ton discrepancy within the 3/4 ton platform. The longbed 71 GMC big block currently in my driveway is max for the platform of 5400# GVW and as equipped at 4400#. Some of the extra load capacity is taken up with heavier components. Frame, axles, brakes, springs etc. But even with that in mind, my 70 big block auto C2500 could carry 3000 pounds more than the 71 big block auto. So the answer to your question is the 3/4 ton can carry a BUNCH more than 500# between 1/2 and 3/4 ton. But it still depends on the options the truck came with.
BlahBlahBlah
I had a feeling it must be more than how I was picturing it.
Good info.
20' Daredevil (Ret)
![]() Join Date: May 2003
I also look at it this way: I can overload the heck out of my K20 (right or wrong, I have done it many times) and I don't worry about breaking an axle. And if I ever manage to break an axle, the wheel & tire will stay attached to the truck instead of sailing off down the mountain or into oncoming traffic.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
The 10/20/30 identification don't really tell the whole story - GVW does. I'm more of a 3/4-ton and up guy - half tons are fine for some but a lot of the stuff I do with my trucks would not be handled very well by a 1/2 ton without HD options.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
#6 | |
BlahBlahBlah
I figured the weak link in each would be the axles. So whether you had a bunch of heavy duty this and that doesn't it all boil down to the axles?
Who Changed This?
![]() Join Date: Jan 2013
I know a farmer who put 2 tons of grain in his 3/4T truck to take home to feed his cows. It was on the bump stops, so he drove home at minimum speed, 14 miles. I'd never do that. I do not know how that strain affected his truck, but it couldn't have been good for it.
The limits posted on the truck are the manufacturer's recommendation for safe usage of the vehicle. What if you have a small car like a Chevy Cobalt that is rated for four people, and they all weigh in at about 250 pounds? You know that happens. The manufacturer has to build in some margin of safety on their vehicles.
20' Daredevil (Ret)
And springs..... and brakes..... maybe more?
#10 | |
20' Daredevil (Ret)
The only thing I want my 70 C10 to do now days is go in a straight line really fast. So 1/2 ton 2wd is my preferred truck. My C10 spent 30 years being a work truck I've had it for 45 years. Now it's just a fun truck to drive.
Brian Ritter |
![]() Join Date: Jul 2015
I believe that somewhere on this site it describes the 3/4 ton rigs being made of a higher strength steel.
If your looking for real differences. |
