03-23-2018, 11:17 PM | #1 |
Exhaust ideas?
Hi all,
I need the change it my exhaust as it is just rusted through. I'm thinking that I'm going to put in a 2.5" exhaust. I'm considering the borla xs mufflers with an H pipe. Any thoughts about this idea? Also I'm thinking that I'll change the exhaust manifolds to 2.5" ram horns. What do you think about this? Any recommendations of which horns to buy and where to get them? I got a 72 GMC Jimmy 4x4. |
03-27-2018, 08:40 AM | #2 |
Re: Exhaust ideas?
I replaced my headers with the 2 1/2” rams horns and went from 2 1/4” to 2 1/2” exhaust at same time. No balance pipe on mine and I have what used to be called the Dynomax Hemi Turbo mufflers with 20” case. I have been very very happy with this setup which is 10+ years old now.
The last ramshorns I bought came from Speedway motors but I’d bet they are all made in same factory.
03-27-2018, 11:25 AM | #3 |
Re: Exhaust ideas?
I'm tempted to do what you've done. Since I've posted I have come across a few threads that scares me... Tales of broken bolts in the engine block when removing the exhaust manifolds. I got to think this through to see if the rewards are worth the risk.
...or am I being overly cautious? Last edited by parb; 03-27-2018 at 02:29 PM. |
03-27-2018, 12:43 PM | #4 |
Re: Exhaust ideas?
Parb - I have corvette 2.5" manifolds I was going to run on my Blazer but went headers instead. I cut off the accessory brackets and painted them both with high temp "cast" paint.
They looked like this before I cut off the bracket: https://www.speedwaymotors.com/Corve...fold,9133.html Actually you can see them here also mounted to my engine. Never ran - look great still. http://67-72chevytrucks.com/vboard/s...&postcount=122 I'd sell them to you for $100. Can get you pics tonight. I'm local and will be in mountain view on Friday/Saturday. |
03-27-2018, 02:31 PM | #5 |
Re: Exhaust ideas?
I checked your thread. cool! What made you change your mind on the exhaust manifolds vs. headers?
In your thread it looks like you had to change the motor mount by 1.75"? Did i read that right? I'm trying to buy something that will fit without me having to make any changes. Last edited by parb; 03-27-2018 at 02:44 PM. |
03-27-2018, 02:52 PM | #6 |
Re: Exhaust ideas?
I'm running a 700r4 Trans so I moved the crossmember forward to accommodate the longer trans length. These manifolds will fit in the stock location as well.
I went headers because they look better in my opinion. |
03-27-2018, 02:53 PM | #7 |
Re: Exhaust ideas?
Ah, so since my truck is bone stock engine and transmission the manifolds should fit without any changes?
03-27-2018, 02:57 PM | #8 |
Re: Exhaust ideas?
If you're already going to replace the rest of your exhaust system yes. These manifold have a straight down exit - i think the stock manifolds have an angled exit. Could be wrong.
Either way any exhaust shop should be able to get you the correct down pipe to make it all come together. |
03-27-2018, 03:02 PM | #9 |
Re: Exhaust ideas?
Its worth $100 to figure it out. I'm out from wednesday to monday (in new york).
Are you around next weekend? Or if you prefer, I have teenager who is watching over my dogs, i can ask him to meet with you in mountain view and get the manifolds and give you money if you prefer anytime Wednesday to Monday. par Last edited by parb; 03-27-2018 at 03:11 PM. |
03-27-2018, 03:56 PM | #10 |
Re: Exhaust ideas?
I'll send you a PM.
03-27-2018, 05:46 PM | #11 |
Re: Exhaust ideas?
What were you running before that is now rusted through? I have true dual thru short flowmasters exiting sideways before the back tires. Cool 19 years ago when I was younger & running a stroker. Thinking about adding an H pipe now...
'72 K5, known as 'the Fox.' |
03-27-2018, 06:19 PM | #12 | |
Re: Exhaust ideas?
03-28-2018, 02:14 PM | #13 |
Re: Exhaust ideas?
Headers will give you nothing but grief, and will not do anything to improve performance on a stock engine. Stick with cast manifolds. The H-pipe will be difficult to fit in the Blazer if it's 4WD. I made my own exhaust from 2 1/2 304 stainless and could not find anywhere to get that H pipe in without having it interfere with something or hanging too low.
03-28-2018, 04:49 PM | #14 |
Re: Exhaust ideas?
my thoughts were to bend it under the torque converter, between the 2 pans. The H pipe doesn't get too hot, does it?
03-28-2018, 05:23 PM | #15 | |
Re: Exhaust ideas?
I'm hoping adding in the H pipe will make the exhaust sound more uniform and not as much as like a loud motorcycle. Also, I used the hooker header back system. I wouldn't recommend using this. The rear sections are the only pieces that fit correctly. Had to figure out my own way by the transfer case.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
03-28-2018, 05:33 PM | #16 |
Re: Exhaust ideas?
Do some research on where to put it. If I recall, there is a sweet spot to locate it. Not too sure about the heat, but I do agree the exhaust note is a bit nicer.
03-28-2018, 06:37 PM | #17 |
Re: Exhaust ideas?
before i tore my Blazer apart there was an H pipe that went under the rear Tcase output. I dont recall it hanging too low. Fit pretty tight up there.
Sorta crappy pic here: http://67-72chevytrucks.com/vboard/s...85&postcount=1 |
03-28-2018, 06:43 PM | #18 | |
Re: Exhaust ideas?
03-28-2018, 07:05 PM | #19 |
Re: Exhaust ideas?
Hm I think that would have to be a lot of radiant heat to soak into a ujoint and affect it, but sure. I'd be more worried about it being too close to the transmission or starter if it was in front of the trans.
When I get around to doing my exhaust I'll try to do an h pipe or x pipe just rear of the tcase again. |
03-28-2018, 10:17 PM | #20 |
Re: Exhaust ideas?
Not sure if any help (kinda tough to get pictures under there!), but here's a few of mine. '71 Blazer, manual trans.
-Bruce 1971 K5 Blazer 4WD |
03-29-2018, 01:07 PM | #21 |
Re: Exhaust ideas?
Great pics and placement for the H pipe.
03-29-2018, 02:32 PM | #22 |
Re: Exhaust ideas?
I agree, great pics and great advice.
Did you use a narrower pipe in the h connection than the rest of the system? The pics looks like the h is a smaller diameter pipe but I wanted to confirm. |
03-29-2018, 09:50 PM | #23 |
Re: Exhaust ideas?
2 1/2" pipe with 2" crossover. Why 2"? Good question.........
03-30-2018, 11:29 AM | #24 |
Re: Exhaust ideas?
Mine exits in front of the rear tires. Might my system be too short for an H pipe in that location to be any good?
03-30-2018, 10:29 PM | #25 |
Re: Exhaust ideas?
I found a set of GM truck Exhaust manifolds 2 1/2 in. put a bolt in it were the front bracket goes than cut and ground it off. Looks good cant see bolt.
