69 C10 stepside trans/drive shaft questions
I recently traded for this 69 C10 short stepside and it came without a trans and driveshaft. I picked up 2 700R4's recently and was considering putting one behind the I6 as had been suggested previously. The questions being:
1-Driveshaft length. Has anyone done something of a similar configuration? Would you have dimensions for the driveshaft? 2-A 700R4 behind an I6. Will that pair up correctly? Will I need to modify anything to make this work? 3-Future considerations. I don't plan to keep the I6 in the truck forever. I would like to keep it as simple as possible for a later swap. What I have in mind is a 350/TH350, or possibly a 383/TH350. What are your thoughts on this? And again thanks in advance for any help!
1988 Suburban V10 350 TBI 1969 C10 Stepside inline 6 250 (new project) 1977 C30 3+3 Camper special 454 |
Re: 69 C10 stepside trans/drive shaft questions
I have a 67 with a 355/350 combo. I don’t care for the 350 trans. 3:73 gears and at 70 mph I’m at 3200 rpm. I’m looking to get rid of the 350 and find a better tranny with overdrive. You have the 700, so putting that behind the 350/383 would be better since it has overdrive. Keep in mind that the crowd is split on the 700 being a reliable tranny, especially when compared to the 350.
Customization is what you want it to look like -- not what other people think it should look like |
![]() Join Date: Feb 2016
Due to all of the variables like coils or leafs, lowering, yoke lengths, shortened frames and such I would recommend measuring your particular truck and having the drive line built to your truck. Look into the TV cable options before committing to the 700r4 with the I6. It maybe expensive in view of your long term plans
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I also have a 69 stepwise with a 250 and a 3 speed automatic. I have rebuilt a 292 to install along with a 200R-4. The 200R-4 is the same length as the current trans, just need to slide the mount back therefore you can also use the same driveshaft. This will give us a 4-speed overdrive and better mileage.
