Old 04-27-2018, 11:07 AM   #1
70GMCer
70GMCer's Avatar
AC Firewall Harness?
Trying to remove the AC harness at the firewall.
Before I go pulling on the harness at the firewall, is this a plug that goes into the firewall a socket or is it a fixed point that does not come apart?
70GMCer is offline   Reply With Quote
Old 04-27-2018, 12:36 PM   #2
v30crewcab
v30crewcab's Avatar
Re: AC Firewall Harness?
it goes all the way thru to the box and controls inside.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-27-2018, 12:43 PM   #3
gmachinz
That grommets pops out from inside to outside. GM used a moisture sealant barrier so it’ll be tuff at first then it’ll pry out easy. Just use a flatblade to pry under and out on the grommet and it will give way.
gmachinz is offline   Reply With Quote
Old 04-27-2018, 01:28 PM   #4
70GMCer
70GMCer's Avatar
